A program that reads a temperature value in degree centigrade, then converts and outputs its farhenheit equivalent. (flow chart)
  • 6,674 Answers
Here's a link.
http://manuelsweb.com/temp.htm
Posted on Nov 07, 2010
14 degrees celsius is equivalent to how many degrees faranheit
This is the most common temperature scale in the world and the simplest to understand. Put simply, 0°C is the freezing point of water and 100°C is the boiling point of water. Centigrade is an old fashioned name for Celsius.
0 degreeC = 32 degreeF
In otherwords
32DF = 0DC
https://electronicshelponline.blogspot.com/
Jan 05, 2017 | Refrigerators
What is the normal temperature to set the fridge and freezer
  • A frigidaire should have a temperature of between thirtyseven degrees farenheit (three degrees centigrade) and forty degrees farenheit (five degrees centigrade). Any higher and the food will go off, any lower and you'll lose nutrients and fresh food can be ruined.
  • The ideal freezer temperature is zero degrees farenheit (negative eighteen degrees centigrade) which will store food safely and stop bacteria forming
  • It's a good idea to buy a fridge thermometer and check the temperature if you are not sure it the thermostat is working efficiently
  • If you adjust the thermostat, it generally will take twentyfour hours to adjust the temperature
Oct 15, 2014 | Refrigerators
Fteezer not freezing not at temperature to keep
Y please convert oven degree from 1-8 to centigrade(ARISTON oven 95GT01----
0 degrees C is freezing and 100 degrees C is boiling
Jul 26, 2014 | Ovens
How to change from Celsius to Fahrenheit
To convert degrees C to degrees F, Multiply the Centigrade temperature by 9, then divide by 5, then add 32
Or, degrees F= (9/5 degrees C) + 32
Here's link to website which explains difference between Fahrenheit & Centigrade scales, & how to convert between them:
http://www.mathsisfun.com/temperature-conversion.html
Jul 11, 2014 | 1996 Buick Park Avenue
Freezer wont go below -9 degrees
This information does not mean anything to us if you didn't specify the model. In what temperature range a freezer works we knew thanks to the stars.
One star (-6 degrees centigrade) is perfect for making ice cubes and is sufficiently cold to keep food for three or four days.
** Two stars (-12 degrees centigrade) stores food for fifteen to twenty days.
*** Three stars (-18 degrees centigrade) will keep food safe for up to three months.
**** Four stars (below 18 degrees centigrade) means that the compartment provides the ideal conditions for freezing down fresh and pre-cooked foods.
Dado
Oct 27, 2013 | AEG Freezers
LG portable a/c model LP1010SNR and after running for about 15 mins it reads E4
salaams......the unit will stop and display E4, when coil sensor reads temp less or equal to 2 degree centigrade.so deforst it. orrrrr when the coil temperature greater or equal to 8 degree centigrade.its from manual.
Sep 13, 2011 | LG LP0910WNR Air Conditioner
Does a 1996 Ford Taurus 3.0 have a hot wire type mass air flow sensor or a vane type? Would spraying carb cleaner into the MAF fix the problem of hard cold engine start? Once the engine warms up does the...
TheMobilian, Yes, the Mass Air Flow is a Hot Wire type. There is a spray made for the mass called mas air flow cleaner. Regular cab cleaner is too harsh and can eat the coating inside mass air flow and it's delicate parts. Use throttle bore foam cleaner; it works like bathroom scrubbing bubbles and eats the gum and varnish. When engine warms up (closed Loop) both sensors work together giving input to ecm for output. Have someone with a live data reader read both sensors. (Let me know the readings?)
Image Mass Air Flow(MAF)Sensor
PURPOSE
The Mas s Air flow (MAT) sensor measure s the amount of air flowing into the engine.
This value is used by the Powertrain Control Module (PCM) in calculating the required
Fuel injector pulse within order to provide the desired air fuel ratio. This input can also
be used in determining Electronic Pressure Control (EPC). Shift and torque converter
clutch scheduling.
CONSTRUCTION
The MAE sensor is located directly in the airflow path between the air cleaner housing
and the throttle body. Ail air entering the intake manifold must pass through the sensor.
Located in the MAT sensor directly in the airstream are two platinum wires, a hot wire
heated by electrical current and a cold reference wire. The MAF sensor uses the air flow
across these wires to calculate its output.
OPERATION
The hot wire is maintained at 200CC (392CF) above ambient temperature as measured by
a constant cold *e. The current required to maintain the temperature of the hot wire is
proportional to the air mass flow. The MAE sensor then measures the amount of
electrical current required to maintain this temperature difference and converts this
value to an analog DC voltage. This output varies directly with the mass air flow rate.
Pay attention to the Paragraph about the torq converter.
Dec 17, 2010 | 1996 Ford Taurus
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
