Question about Refrigerators
SAMSUNG REGRIGERATOR..RL38EBMS not cooling...no sound of the compressor...changed relay and the klixon...silent ...please assist...
5 Suggested Answers
  • 1314 Answers
SOURCE: GE Refrigerator Compressor Inop.
what the good doctor is saying is check for voltage where the wires come into the ptc reley thats a great idea
Posted on Jan 22, 2008
tzweeb
  • 318 Answers
SOURCE: 18 cubic foot roper is clicking, but not freezing.
yes the "relay" on your unit has burnt out. if you shake it and pepper looking pieces come out of it that will verify that you need to replace the relay.
nice work finding the exact problem by yourself and now all you have to do is buy a relay and plug it in to get things back to normal.
also be sure to clean the coils under the unit as when the compressor gets too hot it will cause the relay to fail. it is very common and you can fix this yourself.
Posted on Jan 07, 2009
  • 15 Answers
SOURCE: compressor starts then the ptc relay or the 2tk
You can try a new relay but it could be the compressor locked up. Try the relay first if you have not let do this for a long time.
Posted on Aug 05, 2009
heatman101
  • 43501 Answers
SOURCE: I have a Maytag MZD2766GES refrigerator and it
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Feb 24, 2011
Kenmore elite refrigerator, both are "luke warm"
Sounds like your start relay/capacitor is fubar. The clicking is caused by the Klixon shutting down power to the compressor when it does not start properly. When it cools it resupplies power only to overheat and click when it shuts down again.
Jun 12, 2017 | Refrigerators
If Klixon relay attached to my compressor rattles, is it definitely no goad?
If the relay was faulty, the compressor would not start when cold. To test the relay put a continuity meter in the 2 pins for common and start. there should be no reading. Turn it upside down there should be continuity. If there is a capacitor attached to the relay as well, change it as it may be failing. Apart from these, check all else is working ok, particularly the condenser fan and gas level. if all else is ok, the compressor is overheating and siezing and will need replacing.
Apr 23, 2014 | Freezers
The compressor wont start back up. The fan runs
check the start relay and klixon, these may be burnt out.
May 15, 2010 | Refrigerators
I have split ac samsung,which has problem with no cooling.. also voltage flactuate when ac start i.e. from 240 to 188.. plz help
my friend us hould check your aircon have proper gas and may be there is a problem in your compressor u should chech power current supply of air con its possible there is aircon have short gas problem so contect to your a.c technician for further action.
Apr 25, 2010 | Samsung AW0603B Air Conditioner
I have a Haier Model BD00T0E0200 that is getting power, the compressor is warm to the touch, is clicking occasionally, but does not cool. Any suggestions?
Hi and welcome to Fixya. I am Kelly
First of all unplug the unit for at least 30 minutes and let the compressor cool off. That clicking your hearing is the "KliXon" thermal overload trying to protect the compressor because it is not starting.
Failure of a compressor to start can be caused by several things.
1. A bad PTC Relay / KliXon mounted on the compressor
2. A bad run capacitor
3 The bad news... a LOCKED rotor in the compressor.
There is one other possibility and that is that the power cord plug is not making good contact with the wall outlet terminals. (very rare that this happens)
Just make sure to unplug the unit for at least 30 minutes. Use a fan for cooling the compressor if you can by just pointing it toward rhe area of the compressor. After 30 minutes plug the unit back in and cross your fingers...... If it starts your in luck... If not then your going to need to service the unit.
Again thanks for using Fixya and if you need further assistance just reply here. We get notified of all responses. Kelly
Feb 07, 2010 | Haier BC112G Wine Cooler
Not cooling compressor go on nad off
Hi, If the compressor is going on and off or you hear a clicking sound coming from compressor that goes on and off, it is the external overload relay on the common leg of the compressor. It is a klixon relay. You need to get behind the unit and remove the bottom panel to expose the condenser fan motor, coil, and compressor. If the motor is not up and running then this is the problem, causing the compressors to have a very high head pressure in the system, and must be changed. If the motor is running, the compressor is locked up internally, and will need to be replaced which is quite expensive. Depending on the age and over all condition, you may want to check into a new unit as this can add up into $1,500 dollars or more to replace the compressor. You can call and get a estimate, but I do this everyday and a 4 hour job plus parts add up very quick. Let me know what you find out and keep me posted.
Sincerely,
Shastalaker7
PS Carefully lay your hand on the compressor and it should be quite hot. Don't burn your self. Then you will know.
Jan 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The refrigerator will not cool, same with the freezer. I here a clicking noise from the back of the refrigerator, one of my buddies took a look at it, and he thinks it sounds like it is stuck in defrost....
The clicking sound your hearing is most likely the compressor trying to start but fails to do so. This is a protection feature that is the Klixon thermal protector heating up because the compressor is not starting properly and then the audible CLICK is the Klixon opening the start circuit. Things that cause this are a bad run capacitor, a bad compressor relay or possibly a locked compressor which is by far the worst thing that could be wrong.
If the unit is 8 years old or younger I would at least allow a service tech to replace the start relay Klixon and run capacitor. If ater that process is completed and it still does not start then the compressor is locked and has failed internally the compressor rmust be eplaced. There is a Locked rotor test that the tech can do with an Amp meter. On the side of the compressor there is a LRA (Locked rotor Assy) value in amps. If after connecting the amp meter and attempting a start cycle that LRA value is reached then the compressor is locked. Oce again i.e replacement required. If the unit is over 8 years old I would seriously consider purchasing a new unit depending on the overall condition of your unit. If it is good shape then go ahead and have the compressor replaced. Mind you this is one the most costly repairs you can have done.
Jan 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator is clicking, won't run
Is this clicking happening about every three or four minutes?
It sounds like the klixon, which is a thermal/current sensing device which is under the electrics cover on the compressor. It is a metalic disc which if the current is too high, or the compressor case temperature too hot, will cause the disc to expand and will move from being convex to concave in shape. As it moves from one to the other, it makes a clicking sound. The usual cause of a cycling klixon is lack of refrigerant in the system which causes the compressor motor to cease which means when it tries to start the current rises too high and the klixon 'pops' which breaks the contact. It cools down, 'pops' again, makes the contact, tries to start, won't because it is seized, current rises, klixon pops out again, and so on. You need to get a qualified refrigeration engineer in to fix it, or if it is an old unit, bin it and buy a new one.
Aug 15, 2009 | GE Refrigerators
Not cooling, clicking sound from low
The cilcking sound is probably the klixon circuit breaker kicking out and resetting and kicking out again. If so, the unit is scrap as you have a compressor failure, electrical or mechanically related.
Jul 29, 2009 | Refrigerators
Jan 07, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Refrigerators Logo
167 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
