Question about Asrock A780GXH/128M AM2+/AM2 AMD 780G HDMI ATX AMD Motherboard
My a780gxh/128M system won't resume Windows 7 X64 from sleep. The 5vsb jumper is set from 2-3 (I tried it both ways in case documentation was wrong) I've used PS/2 and USB keyboards. PS/2 keyboard powers computer back up, but it hangs at a black screen. My OP700 Silverstone power supply has 4 Amps on the 5vsb. I am running the latest P1.70 bios. I'm running a Phenom II 945 cpu overclocked to 3.5 GHZ, 8 gigs of Gskill F2-8500CL6D-4GBNQ, with a ASUS Radeon 4870 HD 1GB DDR5 Dark Knight video card. My boot drive is a 64GB Supertalent SSD drive. Not being able to resume almost instantly from the SSD is quite disappointing.
SOURCE: P4i65G - brand new want start.
What kind of P4 3.4Ghz is it? if it has 2mb of L3 cache, it doesn't work with that motherboard
Posted on Oct 25, 2007
blueextc3221
  • 15935 Answers
SOURCE: Asrock K7S41/K7S41GX problem
2 x DDR DIMM slots
- Supports DDR400/333 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
3 beeps is usually either video card related, or memory. be sure your memory is UN buffered, and DDR400 or 333 DIMM not DRam.
Remove and re-seat your video card as well.
there should be a troubleshooting guide in your install manual stating the designation of 3 beeps.
Posted on Dec 22, 2008
compdoctor20
  • 172 Answers
SOURCE: asrock p4s61, tried 1gb pc3200 to max memory to 3gb, won't boot.
you quote one of your memory sticks as being pc 2700 when earlier in your text you qoute pc3200.
Firstly pc 3200 is 400 mhz clock speed memory.Secondly, pc 2700 is 333mhz clock speed and you acnnot mix the two on the same board. Thirdly does your board support 3ghz anyway. If you are running a board at 400mhz, pc2700 memory will not run at 400mhz.
Solution, take out the pc 2700 memory and all will be well.
Posted on May 04, 2009
yboyandrei
  • 828 Answers
SOURCE: I did BIOS flash update on my ASUS P5WD2 Premium
Install the BIOS Flash update, one by one. Like for example 1.0, 2.0 or 3.0.
And if still the problem consist. I think its not your BIOS problem.
Clear the BIOS by disable the JUMPER Setting.
And one last thing change the LITHIUM BATTERY(CR2032) a new one.
If you got the problem again, put a comment so that we can easy understand what is the problem with your MB.
If i am helpful, please rate me.
Thank you very much.
Yboyandrei
Posted on Aug 10, 2009
rajeshpait
  • 542 Answers
SOURCE: getting on board vga video to work on asrock
As per discription provided by you, Suspect the physical RAM is having problem. Check and insert the RAM properly may solve your problem.
Hope the above solution may resolve your problem. Please give us the feedback on the solution to provide the best resolution in future.
Revert Back for more assistance or clarifications.
Posted on Dec 26, 2009
Hp P6653 won't shut down properly after clicking shutdown
Open Control Panel, select Power Options, select High Performance, Use this procedure to set the Advanced power settings: http://www.makeuseof.com/tag/windows-7-power-options-sleep-modes-explained/ Use these tip to speedup starts and shut downs: http://www.techrepublic.com/blog/10things/10-ways-to-speed-up-windows-7/3332 Try Freeware MALWAREBYTES at : http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install UNCHECK the TRIAL PRO version, you want the freeware version, Run a FULL scan, delete ALL results, reboot.
Mar 09, 2013 | HEWLETT-PACKARD Pavilion p6653w...
Board will not start
Just after that there was NO correct answer to fix this problem causes the problem not solved even if it is marked as solved. Me too I have this problem, I was fix it by setting jumpers to default 60 Hz AC power because I won`t have 50Hz AC power or some AC power converter before PSU, I mean this is voltage errors, it`s need to be set to default +5V(60Hz) PSU not +5VSB(50Hz) PSU, (Step1) like might be set to USBPW12 to pin 3 both USB to right side inserted jumper it`s in left side of, near ATX 12v advanced CPU power cable connection socket. Next (step 2) is set up front USB jumpers to +5V or system won`t start up, it`s on motherboard about between PCI1 and PCI2 on right side it must be set up to USBPW56 and don`t set it to USBPW78(5+VBS) because system won`t start up, the jumper must be set to right side I mean it`s last jumpers to right side need to be set up, because it`s +5V(60Hz) PSU supply. The USB wake-up feature requires a power supply that can provide at least 500mA on the +5VSB lead when these jumpers are set to +5VSB otherwise the system won`t power up. Next step if it still not starts up its BIOS fault, it`s easy to repair, just (Step3) turn off PC remove BIOS battery (it`s down to IDE cables), start it up wait a bit, then turn it off and turn it again on wait a bit again, turn it off place BIOS battery in to socket to be able save BIOS settings i mean battery is need to save them otherwise settings won`t be saved and Chassis will be broken. (Step 4) Turn PC on press del key after BIOS is load in open Power\Hardware monitoring\Chassis Intruder set to Disable, save settings exit. (Step5) If BIOS (PC won`t power up) it`s Chassis1 jumper fault, it`s need set to Default (Chassis signal, and GND(Ground)), it`s between SATA 2 and SATA1(Serial ATA connectors 7-pin it`s near and down to BIOS battery, the jumpers might be set to right side, after it`s completed repeat Step3 and Step4. CMOS is BIOS battery. If that all doesn't works Take BIOS clearing jumper in it`s clear state, near BIOS chip. Turn on PC with CMOS clear jumper turned on its work. Take beck jumper in its default state after that take bios chip out and CMOS battery out both them an two times restart PC after insert all beck if PC will be working all keyboard flashes once, after its in AC power.
Aug 18, 2012 | ASUS P4P800-VM Motherboard
No display ASUS P4P800-VM Motherboard
Check the memory and the power supply fan is spinning if not that means you have a problem with your motherboard. If the power supply is spinning monitor if you hear a beep if there is a beep that means you have a problem in your motherboard. Check also the CPU fan if spinning, if spinning in a second then stop you have a problem with your processor
Oct 10, 2011 | ASUS P4P800-VM Motherboard
No display
Just after that there was NO correct answer to fix this problem causes the problem not solved even if it is marked as solved. Me too I have this problem, I was fix it by setting jumpers to default 60 Hz AC power because I won`t have 50Hz AC power or some AC power converter before PSU, I mean this is voltage errors, it`s need to be set to default +5V(60Hz) PSU not +5VSB(50Hz) PSU, (Step1) like might be set to USBPW12 to pin 3 both USB to right side inserted jumper it`s in left side of, near ATX 12v advanced CPU power cable connection socket. Next (step 2) is set up front USB jumpers to +5V or system won`t start up, it`s on motherboard about between PCI1 and PCI2 on right side it must be set to USBPW56 and don`t set it to USBPW78(5+VBS) because system won`t start up, the jumper must be set to right side I mean it`s last jumpers to right side need to be set up, because it`s +5V(60Hz) PSU supply. The USB wake-up feature requires a power supply that can provide at least 500mA on the +5VSB lead when these jumpers are set to +5VSB otherwise the system won`t power up. Next step if it still not starts up its BIOS fault, it`s easy to repair, just (Step3) turn off PC remove BIOS battery (it`s down to IDE cables), start it up wait a bit, then turn it off and turn it again on wait a bit again, turn it off place BIOS battery in to socket to be able save BIOS settings i mean battery is need to save them otherwise settings won`t be saved and Chassis will be broken. (Step 4) Turn PC on press del key after BIOS is load in open Power\Hardware monitoring\Chassis Intruder set to Disable, save settings exit. (Step5) If BIOS (PC won`t power up) it`s Chassis1 jumper fault, it`s need set to Default (Chassis signal, and GND(Ground)), it`s between SATA 2 and SATA1(Serial ATA connectors 7-pin it`s near and down to BIOS battery, the jumpers might be set to right side, after it`s completed repeat Step3 and Step4. CMOS is BIOS battery. If that all doesn't works Take BIOS clearing jumper in it`s clear state, near BIOS chip. Turn on PC with CMOS clear jumper turned on its work. Take beck jumper in its default state after that take bios chip out and CMOS battery out both them an two times restart PC after insert all beck if PC will be working all keyboard flashes once, after its in AC power.
I was answer as well on:
Onbord cpu running is nodisplay
I just bought ASUS K61IC-x3, where is preloaded windows 7 home premium x64. Also I have 2 recovery disks from ASUS - windows 7 x64 and windows 7 x32. If I want to set up windows 7 x32, do I need to buy...
Windows 7 x32 recovery disk is used when you have to recover the Windows 7 x32 from a disaster. It works very well but when you want to install or setup Windows 7 x32you have to buy a new Windows 7 x32. Once it is setup and you use your system and you find that the Windows 7 x32 is making some serious problems then you use Window 7 x32 recovery disk. These disks are not the same.
Hope I answered the question.
Good Luck!
Jul 29, 2010 | ASUS K61ICX3 Notebook
Motherboard won't boot up cpu fan comes on hdd
May 07, 2010 | ASUS P4P800-VM Motherboard
I have had this motherboard sitting in my PC doing nothing for quite some time. I finally decided to dust the PC off, and it will not boot. When I press the power button, the fans, HDDs and the CD drive...
The user manual will give you the jumper settings but I'm surprised you haven't tried the card you have as you consider it a video problem.
Manual here
http://support.asus.com/download/download.aspx?SLanguage=en-us
Apr 11, 2010 | ASUS P4P800-VM Motherboard
PC will not resume from sleep mode
Disable the power save setting, I suspect Microsoft still havent got it right. It was also an issue on previous Win versions.
Disable it in Control panel / performance / power options.
Jan 07, 2010 | ASUS Computers & Internet
Asus A7V8X-MX SE and Sweex CR005V2 connection problem
download the latest software from the manufacturer's website, and install the software *BEFORE* plugging the usb device into the computer. the installer will tell you when to plug the usb device in. once it tells you, windows will automatically detect the device and install the proper software drivers if you are patient!
Sep 23, 2008 | Computers & Internet
Asrock A780GXH/128M AM2+/AM2 AMD 780G HDMI ATX AMD Motherboard Logo
49 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
