Question about Maytag MSD2436GR Side by Side Refrigerator
Maytag MZD2766GEW side-by-side - one side is not cold
I have a 3 yrs old maytag side-by-side. The freezer side is still working; however, the other side is not getting any cold air at all. what could be the problem ? thanks for all your advices
  • 2 more comments
  • jerald_wolf Jul 04, 2008
    I have similiar problem, the refrigerator is not getting cold and freezer is working correctly. The evaporator motor is not running and not sure about the defrost control board.
  • Anonymous Aug 01, 2008
    I have just experienced the exact same problem, except I have some cooling but no fan to move the air
  • Anonymous Aug 04, 2008
    My same Maytag is almost 7 yrs old and this is the 2nd time I've had this problem. The first time it happened 4 yrs ago it was still under warranty. I'm not sure if I should get rid of ths side by side. Nothing but problems. Comments?
    Gail M.
    Rhode Island
  • byor7 Sep 20, 2008
    In my Maytag side by side the refrigerator will not get cold, the freezer side is working fine, fans are working fine and there is no ice clogging the air passage, there is just no cold air in the fridge. What could be the problem?
MyMZD2766GEW just turned 5 years old and the freezer worked fine, but the fridge wouldn't cool. Couldn't get it to 40 degrees F. Defrosted whole unit, including freezer, hoping to defrost all the lines, but it still wouldn't get below 45-50 degrees. Just had the repair man out...cost me $200 labor to install a new defrost switch because the old one was all frosted up again (in just 3-4 days). Maytag is aware of this issue and offered to pay for the parts, but I still had to pay for the labor to install it. The part cost through the repair company was $87.06. I made the mistake of also buying from them the little support button for the shelf above the bottom drawer. They charged me $25.63 for a part that should work (but I don't think will) and I have just located the actual part on line for $3.95. If you need parts, I suggest you check online first. Not to mention, I'm sure that my husband could have replaced the defrost unit as well.
Posted on Jan 08, 2009
I have a fridge that is 4 years old and the fridge quit but the freezer still works. the fan and motors are still running. the repair man will be out friday...could this still be under a warranty?
Posted on Sep 18, 2008
No enfria muy bien del lado del refrigerador
Posted on Jul 15, 2008
WE JUST HAD THAT SAME PROBLEM AND IT WAS THE DEFROST BOARD. $50.00 REPAIR...
Posted on Jun 27, 2008
Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
Oct 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer not freezing at all
the gas maybe gone,check with you're supplier
Sep 07, 2009 | Maytag MSD2732GR Side by Side Refrigerator
We have a 8 year old Maytag Side by side model MZD2766GEW and the fidge side doesn't stay cold, just cool. The freezer works fine and there isn't any frost. Any idea what we need to do? Thank you, Greg
For those who had the control board replaced or are experiencing the frig side warming while the freezer side continues freezing; The problem may (still) be a faulty control board. I fixed the issue by replacing a $1.00 capacitor on the board. I'm not a techy and it wasn't too difficult to solder. More info on what to do here; DIY Chatroom
In the mean time, there is ice forming behind the back panel in the lower section of the freezer. This blocks airflow to the frig side.
I use a pump pressure garden sprayer with hot water to defrost the coils. Gets the job done in 20 minutes and I don't have to worry about defrosting items in the freezer.
Jul 17, 2009 | Maytag MZD2766GES Side by Side...
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
Freezer is cold, but refrigerator is warm
Sounds like you have a defrost problem... is there a large build up if frost in the freezer section on the back wall??
Aug 20, 2008 | Maytag Refrigerators
Black Maytag Side by Side MSD2756AEB 7+ yrs old? Won't stay cold...
Your condenser where the heat is removed from the refrigeration system may be plugged with dust. The condenser is more than likely located in back of the refrigerator behind a removable panel. Remove the panel and clean it out. Reinstall the panel after you have cleaned the condenser.
Check the back wall of the freezer for frost buildup. If there is frost buildup on the back wall it indicates that there is a problem in the defrost circuit.
Note: The proper term is "More mature individual" , not old.
May 31, 2008 | Maytag MSD2756GES Side by Side...
Maytag refrigerator Model MZD2766GEW
Check the evaporator fan motor located abocve teh cooling coils in the freezer side.
Jun 05, 2007 | Maytag MZD2766GES Side by Side...
Freezer just not getting cold enough. Freezer fan is running. Gasket, I thought was the original problem, has been re aligned. Light switch works and the light goes off when freezer is closed. Cold air is...
The defrost heater element is bad, Do you know enough engineering to tackle the job ? You will need some hand tools and a spare Saturday afternoon .. Alternaively you could call a technician...
May 05, 2007 | Maytag MBF2556HEW / MBF2556HEB /...
Maytag MSD2436GR Side by Side Refrigerator Logo
396 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
