Question about Uniden Cordless Phone
One dead phone out of three
One of our 3 phones died. We tried charging it on a different base in case we had a faulty base with that phone but no luck. We got a new battery which I'll be returning today because that didn't work either. What else can I try to see if this phone will come alive again. The other 2 work fine.
  • 5,568 Answers
It may be a stupid question but you didn't state the answer; did you allow sufficent time for the replacement battery to charge?
12-14 hours may be necessary to bring a new battery up to full charge.
Instead of wasting time and gas finding, then returning the new battery pack, you could have swiped the pack from a working phone to test the dead one.
If the handsets are fitted with Ni-Cad batteries, the individual cells can short and one out of three dead = no operation.
The cost of a simple digital multimeter is now so low, ~ $10 US or less for example, it pays to have one at home to check such things before spending time to look for items you really don't need.
The meters are very simple to use and generally come with brief instructions (albeit in Chinglish) that are adequate for homeowner use.
These are available from various tool outlets, eBay, etc. or if you have Radio Shack, you can buy one there for only twice the price elsewhere.
Posted on Jun 15, 2008
How to re set phone
hi there more often than not phones like your Bt4500 have a battery that's installed inside the handset, now after long charge times and the handset being plugged in the base the battery becomes lifeless and faulty and dies, once a power cut happens as the handset has no longer got power the battery can not recover ! my best advice would be to open the back of the handset and locate the battery and replace with same from mapplins or ebay and give new battery a good charge this should get your phone working again
Mar 04, 2015 | Panasonic P-P301PA/1B Cordless Telephone...
Phone will not charge
Try cleaning the connectors (golden pins) that connects the handset to the base. It's likely that the connectors had got dirty, and electrical current wouldn't flow through them.
Or, the battery in the handset is dead, or faulty, and needs to be replaced. In most cases, you could replace the battery yourself. Batteries could be brought from your local electronics store, best buy stores, and, in some cases, RadioShack too.
Jan 31, 2014 | Uniden exi4560 2.4ghz extended range...
Vtech phones go dead when I try to use them
Now you know how they wound up at Goodwill.
Mar 06, 2017 | Vtech i6789 Cordless Phone
I've got a Bosch ps30 drill that uses bat411
Directions say green light indicates that the battery is fast charging only,it does not indicate at exact point of full charge. I let my batteries charge for 12 hours for the first time charging,found out myself the same way. Try that and you will notice the difference.
Jul 15, 2011 | Bosch PS30-2A 12-Volt Max 3/8-Inch Drill...
Hi , The problem with my phone is that even though there is full charge , suddenly all the charge is depleted and the phone dies. I am unable to figure out if there is some loose connection with the...
"The charge is depleted and the phone dies" This happens in two cases....
  1. Your batteries are dead and old. Try replacing the batteries
  2. This can also happen if there is a short-circuit somewhere in the connection.
Try exchanging your batteries with a new one or with another phone of same model. If the problem is gone then your batteries were dead but if it arises again there must be a short-circuit somewhere, get is checked....
Oct 01, 2010 | Uniden 5.8GHz Dual Cordless Phone
Bought my phone yesterday...Battery was losing charge quickly.. battery was down to half charge after about 15 minutes of fully charging.. Was trying to let the phone die completley then fully charge it,...
Ok first of all you should never let a phone die out of charge at all.IF it dies out of charge there are chances it might charge again once you charge it but in some cases it wont, you need to boost your battery just like jump start your car.It cannot be done anywhere except some service centre. If you are not taking to your service center , then you need to buy a new battery.
Oct 08, 2009 | Cell Phones
BATTERY NOT CHRGING
Three reasons. 1. The charger is bad. 2. The Battery is dead. 3. The charging circuit is faulty. To check each Use a different charger or use a different battery. If both are fine then the third fault is confirmed.
Aug 01, 2009 | Nokia N72 Cellular Phone
BT Freestyle 2200 do dial tone
I have this model of handset but as a triple. I get three beeps from the handsets if the batteries are low or flat.
Are your phones getting charged?
However,
Try putting the base station into a different phone line/ socket if you have one.
if not - Try putting a corded phone on your phone line. Maybe there is something faulty with the socket, maybe there is no dial tone due to faulty wires?
Mar 07, 2008 | British Telecom Freestyle 2200 Trio...
No dial tone and "line in use " message
Try the simple things first. Try a different phone. In my case, I had the phone company check - outside was fine. After two hours my phone worked. I figured out what happened in my case. Both phones were dead (battery). I think one died with the phone off the hook. once the phones were fully charged, the phone worked.
Feb 21, 2008 | Uniden Cordless Phone
Uniden Cordless Phone Logo
130 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
