PANDIGITAL 7" Digital Photo Frame With Interchangeable Frames Logo
Posted on Nov 07, 2010
Need a mini usb cable adaptor for pandigital model 7069MW03
Pandigital frame . tried to connect with pc and usb cable. The pc does not see the photo frame. The only way it works is with a usb stick.
Pandigital cameras typically have a USB connection that allows you to transfer photos from the camera to your computer. It sounds like the connection between your camera and computer is not working properly. Make sure that the USB cable is securely connected to both the camera and the computer. Also, check that the camera is in the proper mode for transferring photos (this will vary depending on the specific model of camera you have).
It is also possible that the problem is with your computer. Make sure that the USB ports on your computer are working properly and that the drivers for the camera are properly installed. If you are using a newer version of Windows, it may not be compatible with your older camera.
Pandigital cameras are based on old technology and it is very likely that it may not be compatible with the latest version of Windows. It is recommended to check the camera manual or the Pandigital website for the supported version of windows.
What type of USB cable do I need to upload picture to my computer
Hi U need a mini USB cable to STD USB U can buy them on E/BAY COST aprox $2-99 cheers
How do I connect s3 mini to hdmi cable
Make sure you're using both data and power USB cables
2answers
USB port for iphone sync
The iPhone will sync to iTunes on a computer. If the display has a USB port, there must be another USB cord to the computer. The iPhone will go through it to get to the computer.
1helpful
No usb cable in the accessaries for my Koolatron digital photo fame,where can I get one?
IT WOULD ALL DEPEND ON THE TYPE OF USB CABLE ORIGINAL MINI MICRO BUT MOST RADIO SHACKS BEST BUY EVEN WALMARTS WILL STOCK ALL THREE TYPES IF YOU NEED FURTHER HELP PLEASE LET ME KNOW
Forgot password
Go to Barnes & Noble's website on your computer and select the option to create an account. Enter your full name, email address, debit or credit card information and select a user name and password when prompted.
If you have a Barnes & Noble account, skip this step.
Power on the Pandigital Novel and tap "Settings" on the home screen.
Tap "General, and select the "B&N Account" and "Password" fields and enter your Barnes & Noble account login information.
Reading ebooks is not the only activity you can enjoy with the Pandigital Novel.
The multi-functional device will also allow you to listen to music, watch videos and browse through your favorite images.
The Pandigital has a speaker located in the back of the device and an earphone jack to accommodate your listening needs.
To get started, you will need to either download media from a computer or purchase ebooks from Barnes & Noble online.
Downloading Media
Connect the Pandigital Novel's USB cable into the compatible mini USB port on the right side of the device. Plug the other end of the USB cable into the computer's USB port.
Click on the computer's desktop "Start" menu.
Choose the "My Computer" or "Computer" folder in the desktop Start menu.
Double-click to open the "PD_Novel" drive in the My Computer/Computer folder.
Inside the drive there are four separate folders "eBooks," "Photos," "Music" and "Videos."
Drag compatible media files stored on the computer to the compatible folder inside the "PD_Novel" drive with your mouse.
For example, drag audio files to the "Music" folder.
The Pandigital is compatible with text formatted as ePub and PDF, audio files formatted as MP3, AAC, WAV and OGG, video files formatted as MPEG-4 and images formatted as JPEG, BMP, PNG and GIF.
Disconnect the Pandigital Novel from the USB cable.
Playing Media
Press and hold the "Power" button, located on the left side of the device until the boot up message appears on the screen.
Select a media option in the "Application Quick Launch Bar" at the bottom of the screen: Reader, Music, Videos or Photos.
Tap the desired song, video or image and tap "Play" or "View."
Tap the "Pause/Play" and "Previous/Next" options to control the file or go to the next listed file.
Setting Up Wi-Fi
Turn the "Wi-Fi" button, located on the top of the device, to the "On" position.
The Pandigital Novel will automatically scan for local Wi-Fi Networks.
Tap the desired network from the list of found networks.
Enter the network password, if prompted. Then tap "Connect." When connected, tap "Next" to continue.
Purchashing eBooks
Tap to go back to the home screen.
Select "Bookstore" from the home screen.
The Barnes & Noble bookstore will open in the Pandigital Novel screen.
Search the website for ebooks to purchase.
Tap on the book cover and select either "Buy Now" or "Get Free Sample."
Tap "Yes" to download the media cover to "My Library" when prompted.
Go back to "My Library" on the home screen and tap on the media cover.
Confirm to download the ebook to your Pandigital when prompted.
The entire media file will download.
http://www.pandigital.net/userfiles/file/Downloads/UG_PRD07T-1_v3.4_09-10-10.pdf
Barnes & Nobel
http://www.bn.com/
What Auxillary cord model will fit in my alpine cda-9853 stereo model?
Peripheral stereo mini plug cable (3 foot cable, male to male miniplug). around $20
Monster portable music player cable (stereo mini-to-RCA adaptor) around $20
Arista stereo mini-to-RCA adaptor (6 foot cable with mini and dual RCA plugs) around $5
Hope that helps.
2helpful
2answers
I need a car adaptor
You'll either have to query your model number on amazon, or you can purchase directly from nextar here.
Can't find my usb cord to download more pictures. Can I buy a ne
I am certain you will need what's called a USB mini b cable. You can find it at any electronics store.
Rob
2answers
Need Adaptor connect DJ Tech Turntable to Sony Mini Hi Fi MHCRG495
The USB turntable is likely a USB data connection and not a USB audio connection, so you will need to take the audio output from your Mac G4 to your Sony Mini Hi Fi...
You will likely need a stereo mini-plug (3.5mm or 1/8-inch) to stereo RCA plug cable (red and white RCA plugs). This is often referred to as a "stereo Y-cable."
Top PANDIGITAL Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a PANDIGITAL Audio Player and Recorder Expert? Answer questions, earn points and help others
