Question about Altec Lansing ATP 3W Computer Speakers
My ALTEC LAnsing subwoofer speaker : ACS340 not getting audio signal. However I removed speaker from box and tested it and it played outside! (But the two small desktop satellite speakers which are fed from the subwoofer ciruit board in subwoofer box are playing) What is wrong is it voice IC? Or do I have to replace whole circuit board in subwoofer box?
  • Anonymous Mar 11, 2014
    Windows after rolling down, won't roll up
  • 3,083 Answers
Well, I'm thinking like you in that only part of the circuit board in the subwoofer box is bad, since it's feeding a signal to the desktop speakers. You might take a shot at it, it's a lot cheaper than buying the whole board, I would think, but check before you change it out- sometimes the ICs are custom made and hard to get, if not impossible- hence, they make you buy the whole board (this happens a lot these days with all appliances).
The only way you can know for sure is to troublshoot it with a scope (minimum) and shematic, and possibly some other high tech equipment, if you have access to it (audio generators, etc.).
Before you change the IC out, inspect the circuit board carefully (with a loupe or magnifying glass) for bad or cracked solder joints- they can occur with time and/or heat and open up, and merely need to be resoldered.
Good luck, and hope this helps.
Posted on Nov 07, 2010
Power supply out put rating ? lost the original power adaptor that came with system acs340. trying to use a substitute
what is an acs340 ?
Is it a Altec Lansing subwoofer speaker for a computer
google search a4432 altec
13V 4A DC
If you decide to buy one check the input AC voltage matches your power outlet supply voltage 120Volt AC 60 hZ or
is it 240V 50
Hz - get it wrong and smoke may escape from the power adapter after the big blue flash occurs.
https://www.ebay.com/p/Genuine-OEM-Altec-Lansing-A4432-ACS340-Subwoofer-Power-Supply-13v-4a-AC-Adapter/664023647
Feb 11, 2018 | Power Computers & Internet
HOW DO I GET THE ALTEC LANSING SUBWOOFER MOD. NO.ACS295 TO WORK WITHOUT THE SATELLITE SPEAKERS?
You would have to design and build a box that contains the controls normally housed in one of the satellite speaker enclosures.
Nov 19, 2017 | Altec Lansing Audio Players & Recorders
Wiring diagram for altec lansing acs340 sub woofer
This is not something that you will get access to from here. Try asking a repair shop if they can get the schematics for this speaker. You could also contact A-L directly.
Not likely to happen.
Altec Lansing ACS340 Specs CNET
Furthermore these are inexpesive 2.1 speakers that can be replaced for 30-40 dollars. Not worth the effort.
Mar 09, 2015 | Altec Lansing Audio Players & Recorders
Altec Lansing ADA995 Speaker system partial speaker play
Drivers and support softwares for Dell Dimension 9100 are still very much available to Dell's website (here). Download the audio driver for your StaCruz Audio card.
Hope this helps. Please don't forget to rate.
Nov 07, 2009 | Altec Lansing ADA995 Speaker
Where can i find the driver download for altec acs340 speakers
There is no driver download for speakers, especially analog ones, justlike you don't need one for headphones or for home stereos, or a boombox, you most likely need help with the sound card you are using on your pc, or audio settings on your pc.
Aug 25, 2009 | Altec Lansing Audio Players & Recorders
Need wires for z-340
I just got one too. I guess I'll tear it apart and post the pinout. Also have a set of Altec Lansing satalites (ACS340) with the same connector (hmmmm, Z-340 -- ACS340... probably the same thing they just changed some pins)
I let you know!
Aug 24, 2008 | Logitech Z-340 Computer Speakers
Subwoofer amplifier hum on high bass boost.
Try attaching a crossover caps of 0.22mf over the inline resistor(out put). This will filter the humming sound created when no sound is played.
Roshan.
May 23, 2008 | Audio Players & Recorders
Altec Lansing ATP 3W Computer Speakers Logo
341 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Don Hart
MegaByteMe
MegaByteMe
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
