Question about Logitech MX500 Optical Wheel Mouse USB PS/2
My mouse pointer occasional freezes, it's not about drivers I uninstalled them, logitech mx 500. This happens when I start java program. It only then. Many people had this problem but non of them knows whats the issue. I know that it is because of java. The second thing is that this also happens when i overload the system, starting some programs that use a lot of memory, so that it become worse.
    Habit-Forming:
  • 59 Answers
Mouse cursor is one of the first things to start having problems when the system is taxed. if you are getting high cpu usage and high memory usage, that would cause crazy stuff with not just the mouse cursor to happen. next time you get a chance, pull open task manager. (right-click on taskbar) then start the Java app that you are using. look at task manager and see what is using a lot of RAM or CPU.
I've seen something similar before, where i have had to remove all previous versions of java. and re-install it..
Posted on Oct 03, 2017
Kawika-56
  • 233 Answers
SOURCE: Jumpy mouse pointer, imprecise. How do I clean it?
Laser mice don't need cleaning.
Try un-installing the driver.
Go to your "Device Manager" (Right click on ‘My Computer', select 'Properties', click the 'Hardware' tab, click the 'Device Manager' button. Click the "Human Interface devices" (If you have one). If there is some kind of a "Warning" icon superimposed on the 'mouse' icon there is your problem!
If NOT go ahead and Uninstall the drivers anyhow, It CAN"T hurt!
Uninstall the DRIVERS for THAT DEVICE only.
Click on the faulty device and hit the remove button, follow the instructions given by the program.
Do the same with the "Mice and other pointing devices"
Shutdown, restart, the device will automatically reinstall by the "Found New Hardware" program.
Posted on Dec 08, 2007
  • 6 Answers
SOURCE: My LogiTech mouse freezes constantly
Try un-install the Logitech driver and use the one provides by windows.
Posted on Oct 01, 2008
worldvet
  • 859 Answers
SOURCE: Unresponsive mouse XP unable to initialize device driver for Logitech LX8 laser mouse
Your best course of action would be to use System Restore, based on your response above. Go back to the point where everything worked for you and don't attempt to update your driver again. If it works, don't fix it.
After that if there was something you wanted to accomplish, let us know and we can help you.
Regards,
Worldvet
Posted on Oct 17, 2008
SOURCE: Logitech G7 Mouse problems
This is a well documented problem with the G7.  Which sucks b/c this is the best mouse I've ever used.  Thankfully though the problem appears to be the battery contacts on the inside of the mouse just get pushed back with changing the batteries.  Solutions I've read about is putting a few layers of tape on the back of the battery to push the battery further forward agaisnt the rear stop.  A drop of solder on each of the battery contacts would also do the trick, but getting the solder to stick is a trick.  (If you try this, it is very bad to heat up a battery with a soldering iron, so be extremely careful).  A better solution is to take the mouse apart, a brief overview of disembly can be found here,
http://www.bitbenderforums.com/vb22/showthread.php?p=441061
Although since I didn't have teflon tape laying around...if you have used the mouse enough or just push a bit on the pads, you can see the outline of the screw holes, and just cut through the pad w/ an exacto knife.  The one under the label already had scored lines which made that one easy.  Once the cover is off I just used the tip of the exacto knife to pry the contacts out a bit more (remove the battery before disembling), cleaned the scroll wheel off, and put the mouse back together.  Works like new so far, which is good b/c from what I've heard Logitech isn't very good about replacing the mice w/o a recipt (which I think I lost after a week, nevermind 3 years).
Hope that helps, this really is the best mouse.
Posted on Jan 25, 2009
SOURCE: Logitech Setpoint Uinstallation issue
In my case, the Windows Installer was not launched.
So, I change it can launch automatically by the following step.
program→administer tool→service
And then, start up of the windows Installer makes on.
This is the way I solve the problem.
I hope you can install the Setpoint.
Posted on Nov 09, 2009
My mouse keeps freezing, I have to reboot the computer to get it to work again what can I do?
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware make sure you have the correct mouse selected also under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Feb 24, 2011 | Logitech Cordless Mouse
I found my wireless mouse yesterday. A logitech M305. When I plug it into my laptop it either says that it is not recognized by windows, or that the device has malfunctioned.
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
also click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark !or question mark ? or a red x right you will have options to update driver software,disable,uninstall,scan for hardware changes and properties
in xp
hope this helps
don
Feb 13, 2011 | Logitech Cordless Mouse
Hi, I've been using my cordless mouse and keypad (logitech mk300) for 6 months. Yesterday, it suddenly broke down. Nothing strange happened, I was playing PES on the pc then, my pc froze. When I restarted...
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
also
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have a virus also select users you will see who is using your computer
you might have to many programs loading at start up or you might have a virus run your antivirus program then
click start control panel keyboard hardware then properties you should see driver details,you will have options to update driver,roll back driver,uninstall
make sure you have the driver for the keyboard before uninstalling the driver
make sure the lead is good and has a secure connection diconnect the keyboard then reconnect it then reinstall the driver
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
as for the mouse
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options also hardware under hardware you can troubleshoot or
select properties under driver you will have the options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
dont forget to vote
hope this helps
Feb 06, 2011 | Logitech Wireless Access Duo Optical...
M310 mouse stopped working,replaced battery, no good
in xp
hope this helps
Jan 29, 2011 | Logitech Cordless Mouse
My logitech v220 mouse stopped working i have changed the battery and it still does'nt work
in xp
hope this helps
Jan 23, 2011 | Logitech Cordless Mouse
Logitech mx518
To work around this problem, turn off the Enhance pointer precision feature: 1. Click Start, click Run, type control mouse, and then click OK. 2. Click the Pointer Options tab, click to clear the Enhance pointer precision check box, and then click OK.
Also see this article from Logitech.
The surface on which you use the mouse plays an important role in its tracking. The optical sensor must use the pattern on the surface to track the position of the cursor. Therefore, using the mouse on a glass or otherwise see-through surface will inhibit the ability of the sensor to track the cursor. Also, if you are using the mouse on a reflective surface, such as a mirror or shiny metal desk, you may experience tracking problems. In both these situations, try using the mouse on a mouse pad or piece of paper. By using the mouse on a white sheet of paper, you can also conserve battery life. Other surfaces that have been known to cause tracking problems are:
  • Some wood grains
  • Grooved surfaces
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 22, 2008 | Logitech MX518 931352-0403 Mouse
Mouse occasionally freezes
thats a laser mouse so its not ur mouse the problem, it is ur internet connection, try not to download anything while playin games online and hopefully it wont freeze that often, hopefully this helps U. :)
Feb 11, 2008 | Logitech MX 400 (931638-0403)
Dec 08, 2007 | Logitech Cordless Mouse
MX 510 freezing
Same problem been getting worse. Figured out that the mouseware driver is outdated and not compatible with win xp. Use logitech's setpoint for mx518 or uninstall mouseware. Now no more freezes
Oct 11, 2007 | Logitech MX510 Performance Optical Mouse...
Computers & Internet Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
