Question about Sanyo DP42746 42 in. Plasma Television
Tv cclicked off and on 6 times quickly and turned off. then i turned it back on and seemed ok for a week. then turn it on and it turned off after ten minutes and now nothing. i checked and the plug is getting power and everything else on the surge protector is working.
  • 10,515 Answers
This is an internal fault as you must have observed. There could be many causes for the same. It could be a problem with power supply board. Other than this, it could be Y and Z sustain boards. However, it needs a proper inspection and testing of these components. If you have electronics repair experience, know how to use multimeter and soldering iron, could read schematics - i would be glad to provide you with a link to purchase service manual ( if available ) and could guide you to fix the problem.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 07, 2010
Sound went off, twice now in within the first week, now tv won't come on
if it only a week old or brand new , take it back for warranty service or warranty exchange for a new one
Personally if it failed so quick I would be basking for my money back and buying a better quality unit
Dec 31, 2015 | TCL 55" Roku Ready Tv 55fs4690
Tv keeps turning off
This is probably due to failing PSU capacitors. It is fixable.
May 19, 2014 | Televison & Video
Kdf-e50a11e diagnostic codes
3 blinks is indicating the lamp has burned out. Aftermarket lamps tend to fail quickly. Only use oem replacement lamps for your sony. You can get replacement lamps from www.tvrepairworld.com
Feb 07, 2012 | Sony KDF-E50A11E TV
Periodically my 52HM95 would have some little electrical glitch where it would not come on when I turned the tv on. I would have to wait a little while before I tried again, or I could shut the power off...
I have a similar DLP TV. If you losing your new bulbs that quickly there is likely a problem with cooling. There is a fan that keeps bulb cool. Make sure the fan is working and there is nothing blocking the air passages. I have not had a problem with my fan but you should be able to find a replacement at Radio Shack or a computer/electronics store like MicroCenter. They come in standard sizes just make sure the voltage is correct typically 120 VAC or 12 VDC.
I have had the computer inside crash such that the sound would work, the bulb would come on, put no picture. Fixed by unplugging the TV for one minute then plug in and turn on.
The bulb repeatedly goes through its startup cycle but never comes on. It tries about ten times then stops. Fixed by removing the bulb housing and firmly tapping it on a counter top ten times. This was at Toshiba instructions over the phone and it actually worked.
Dec 31, 2010 | Toshiba 52HM95 52" HDTV Projection...
My Toshiba 32wlt58 cuts out every ten minutes.
I have just had that problem. Repairer said it was a chip in the power supply. Just got the set back this morning, ok for about 6 hours then cut out. Felt quite hot on LHS Will switch on again after a while, then cut out again. Suspect overheating problem took out PSU chip. Chip replaced but original fault still present
Oct 04, 2009 | Toshiba 32WLT58 32 in. LCD Television
My TV wont switch on
check horizontal transistor for short circuit,if ok try disolder audio ic or vertical ic and see which one is fault try replacement. frank massawe
Dec 28, 2008 | Sharp LC-32P50E 32 in. LCD Television
Light flashes, bulb fires, no LCD!!
Sounds like the ballast is faulty or else your lamp is getting close to needing replacement. Hope this helps.
Jan 16, 2008 | Zenith E44W46LCD 44" Rear Projection...
Sony 36" tube TV
It definitely does not seem to be a problem with the Picture Tube. More like a cold solder. It is definitley not a job for a layman. Also, get a good technician to have a look, as locating cold solders is a labourous and time consuming process. It could also be possible that the main DC filter capacitor is getting dry, and may require replacement.
Aug 15, 2006 | Sony KV-27S20 27" TV
Sanyo DP42746 42 in. Plasma Television Logo
19 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
