Try right click on mouse over wifi icon
any laptop should be able to search for its own wireless adaptor
or have a trouble shoot option
did you mean these downloads ?
IBM ThinkPad X31 2672C8G Drivers Download for Windows 10 8 1 7 Vista XP
SOURCE: wireless radio control problem
Try going into the Device Manager and making sure the Wireless Adapter is enabled. Click Start > Control Panel > System. Click the Hardware tab then click the Device Manager button. Now click the Plus [+] next to Network adapters then double-click the wireless adapter which is probably the Intel(R) PRO/Wireless 2915ABG Network Connection which will open the Properties dialog. Ensure the Device status reads, "This device is working properly" and Device usage shows "Use this device (enable)." If either the Device status or Device usage shows anything other than what is shown above, first try to change the Device usage, which should change the Device status. Now try again to use your wireless adapter. You might need to press Fn + F5 to turn the device on.
SOURCE: my laptop ( IBM thinkpad x31) won't turn on
GO 2 CONTROLL PANNEL .DEVICE MANERGER .MICE AND OTHER POINTING DEVICES ,RGT CLICK PROPERTIES CHECK C IF THE DRIVERS WORKING ? HAVE FUN !!!!!!!!!!!!
SOURCE: computer says IBM wireless adapters (802.11 or bluetooth) not ins
Hello Kangarootrib,
Since you bought the ThinkPad second hand and the software installation disc did not come with it, you should go to the IBM ThinkPad manufacturer's web site. Once there, look for your specific model and search for the proper drivers and download and install them on your current computer. Drivers are basically small bits of code that tell the operating system how to communicate with hardware devices, which when you purchase products new come with a CD that contains these instructions for your computer to be able to communicate with the device. Hope this helps and please let us know if you need further assistance.
P.S. If you would not mind, could you please rate my help as I would really appreciate it. Thank you
SOURCE: ibm x31 password problem
Visit: http://www.ja.axxs.net/unlock/
If you cannot boot the ThinkPad, you will have to reset the IBM ThinkPad password via hardware.
If only the power-on password is set, do the following to remove the power-on password.
If both the power-on password and the supervisor password are set, do the following to remove the passwords:
