Question about Jura Capresso Impressa S90 Espresso Machine
Jura Capresso Impressa S9 -water won't pull into the unit
I have owned a jura Capresso S9 for 3 plus years with no problems. this morning we changed the filter just like always. But, the water won't pull through the system. The pump runs but water does not come out the steam nozzle. We tried several new filters and none of them resolve the problem. we put the old filter back in and that didn't work either. Does anyone have any idea as to how to resolve this problem?
thanks much
pam
I actually had to open the machine from the back. Had to drill the heads off the safety screws. Don't worry you can replace with real screws with real heads. on the back on the bottom find the orange pump. There is a clear tube leading to it on the right. With the fill tank in place carfully take needle nose pliers and unhook the water line so the air will clear and water will come out by gravity feed. then hook it back on when full with water. Be careful not to spill much water in the machine and of course have it unplugged when doing this. This enabled the pump to prime... I then had to clean the pipes up in the top left to get steam....solved elsewhere on this site.
Posted on May 04, 2010
We have the same problem after installing a new filter (after 5years of perfect usage & no problem or maintenan)ce. An engineer told us to take the filter out completely & try to draw off water...if it does, do a de-scale IMMEDIATELY (using only recommended product) because the machine may be calcified. If that doesn't work, it may be the sprung sensor under the water carriage which may be blocked(with limescale) or broken...OR the little mesh sensor in the main body of the machine (which is located under the water filter). I am trying this tonight, otherwise its an engineer callout for collection & repair!
Posted on Aug 11, 2008
I had the same problem and was about to take the machine apart when my girlfriend suggested I call customer service instead. Turns out when changing the filter, the air inside the new filter got sucked inside the machine causing a solenoir valve to airlock shut. You need to immerse the new filter in water before installing in the tank. All you do is keep pressing the steam button for 10 or 15 minutes at a time to jar loose the valve. Make sure you give the pump a rest every 10 minutes or so, or when the sound changes significantly so you dont burn it out. I did about 5 rounds of this yesterday and gave up, thinking I need to take it in for service....turned it on this morning for a few pushes and it worked. Be patient.
Posted on Dec 07, 2008
How do I un glog the grinder
Don't see an un-gloger listed.
http://www.shop.partsguru.com/searchquick-submit.sc?keywords=jura+s9+grinder
Sep 15, 2014 | Jura Capresso Impressa S9 Coffee...
My jura Impressa S9 chrome keeps shorting out and blowing the fuse or tripping the mains? Help
Hi.Id check the solenids and pumps. Most likely to be a pump. Their positioned under the water tank. Full disassembly of the machine panels, a must. They slide out when your there. dazza
Oct 13, 2011 | Jura Capresso Impressa S9 Coffee...
Jura Capresso Impressa S9- no steam
I had a similar problem. I took off the side and rear cover, followed the hose that comes from the steam wand to the rear of hte unit. It enters a solenoid made by ACL Italy. I dismantled the solenoid unit by disconnecting the two hose ends, removing the relay, and unscrewing the plunger unit (vertical pipe). The plunger unit internals should move freely up and down like a piston in a cylinder , powered by a small spring. In my unit, this plunger was calcified and seized. I soaked it in boiling water and pressed on it gently several times and it unstuck. I put it all back together again and presto! Good luck
Feb 13, 2010 | Jura Capresso Impressa S90 Espresso...
Hi, no coffee is coming out of Jura S9. The water comes out of steam exit - even in cleaning program rgds
This is a really strange error, but it makes some sense if you own a S9 One Touch model. Then there`s a problem with the squeezing valve located behind the steam/cappuccino outlet. If this is an older model, then it could be a problem with the ceramic valve, but normally this makes the water flud all over the frontpanel and inside. In both cases, i would recommend to send the machine to the nearest servicecenter.
Nov 10, 2009 | Jura Capresso Impressa S9 Coffee...
My Jura Impressa xs90 keeps stating fill system, even after filling the system several times for the last 3 days.
Empty the Water tank and fill it with warm water. Then keep trying for some time and the problem will get solved.
Oct 15, 2009 | Jura Capresso Impressa S9 Coffee...
Jura Capresso Impressa S90 Espresso Machine Logo
1,520 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
