Question about Amana NED7200TW Electric Dryer
Amana Model NED7200TW front load dryer just shut down, no lights anywhere, acts like total power loss, unpluged and checked outlet with meter and both legs show 199 volts. Is there a reset or fuse that could have tripped
I have the same dryer and the same problem. The machine was bought at Home Depot as a housewarming gift by my parents. It was less than a year and half old at the time it completely shut down. I have been fighting with whirlpool over their inability to fix the problem for almost 4 months now. In my opinion this is a major defect and the machine should be replaced regardless of the warranty status.
Posted on Dec 08, 2010
    President:
  • 3,074 Answers
On the backside of the dryer by the motor there is a micro-switch it is #5 in the diagram:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5176187&diagram_id=1364250#d1364250
here is a link that will assist in the dissemblance of the dryer;
http://www.partselect.com/dryer+open-cabinet+repair.htm
Good Luck Tim
Posted on Nov 07, 2010
My amana dryer model #NED7200TW turns on and the motor runs nicely but the drum wont turn on its own. It will turn easily if i turn it with my hand. only about 3 years old.
if your saying theres a motor running but the drum wont turn . then id say either the idler pulley has come off or drive belt has broken , these do go bad especially on heavy load machines
Sep 14, 2016 | Amana NED7200TW Electric Dryer
I keep getting an error code that looks like 2 C's. The dryer is still drying but it will finish and shut off and then turn back on. What does this mean?
Amana NED7200TW Technical Information - ManualsLib
www.manualslib.com > Brands > Amana Manuals > Dryer > NED7200TW
View and Download Amana NED7200TW technical information online. 27" Domestic. NED7200TW Dryer pdf manual download.
Aug 05, 2015 | Amana NED7200TW Electric Dryer
My Amana Dryer ned7200tw has been working great till the last couple months. Lights come on, I can choose setting with the knob but nothing happens when I push the button to start.
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Mar 27, 2015 | Amana NED7200TW Electric Dryer
My amana NED7200tw will not power on. Just replaced the heat coils. But now will not turn on. Help
May have a bad thermal shut off, u can test with a multi meter. Are u getting power to the unit? check door switch while ur at it
Oct 11, 2014 | Crosley Maytag Amana Dryer Hi-limit Y61886...
Drum won't turn
Mine was doing the same thing and I have replaced the Thermistor and it still acts like it done before. I am so over it! I was told it was the main control board but I don't know :/ I don't like the prices of them of what I have seen so far.
Sep 13, 2014 | Amana NED7200TW Electric Dryer
I have an Amana NED7200TW dryer that is approx. 2 1/2 years old and am having issues. The first sign of a problem was it would not come back on after running a 40-50 minute cycle. Nothing would come on,...
Open the cabinet and look for lint buildup around the motor. Lint will act like a blanket and hold to heat in on the motor which in turn will cause it to shut down by way of it's safety mechanism. Check that out and post back your findings.
Oct 16, 2012 | Amana NED7200TW Electric Dryer
My Amana NED7200TW dryer still shuts down with no power and after a couple minutes it will power up again. I checked the circuit breaker but the breakers were not tripped. Help!
Sounds like an internal over-temp thermostat is tripping. Usually, this is caused by near-zero air flow through the machine. Vacuum out the exhaust hose, the exit fitting from the house, and all of the dryer's interior air path that you can reach. Wash out the lint filter with detergent and HOT water as fabric softener deposits will plug the screen. Check the exterior vent for air flow while it's running--it should be fairly forceful (and hot!). Hope this helps!
Apr 12, 2010 | Amana NED7200TW Electric Dryer
Dryer drum won't turn. It has power, the door is shut tight
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 14, 2009 | Amana NED7200TW Electric Dryer
Amana NED7200TW Electric Dryer Logo
272 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
