Question about U-Line 1075WC
No lights or cooling. Unit is receiving power but does not go on. Is there some sort of reset for it?
No panel lights other than a blinking yellow light at top right.
Did you ever get this figured out? I am having the same issue :(
Jul 30, 2015 | Dell 5130cdn Color Laser Printer
Overheating light flashing. How do I reset
Sounds like youprobably have a short in the amp that will need to get repaired
Nov 11, 2014 | Marantz SR7008 9.2 Network Home Theater...
How do i reset avr-1705 denon amp?
Before you reset, are you doing this because the amp went in to some sort of protection mode?
Resetting will allow the amp to redo the self diagnosis. But if the problem remains then the amp will shut down again. Resetting doesn't fix things like bad wiring or blown output transistors. So only reset once you are sure you've checked through the system for any problems.
As a safety measure, disconnect your speakers before doing the reset. If the amp goes in to protection again then it is an indication that there are either shorted speaker outputs inside the unit.
Unplug the unit from AC power for 30 minutes, and disconnect all of the speakers and other associated equipment. Upon plugging back in, press and hold the power button at the same time for 5-10 seconds to force a hard reset.
If the unit starts up normally start connecting the speakers one at a time (shutting the power down before connecting each one), until one of the speakers causes the receiver to shut down. This speaker is faulty and would need to be replaced.
If the unit does not power up with NO speakers connected, then it needs the output transistors replaced inside the unit. These directly drive the loudspeaker outputs on the receiver itself, and one or more of them being shorted (closed circuit), will trigger the error on the display of the receiver, and it will not go off until the problem is repaired. They are not user-replaceable as they are PCB mounted, and thermally coupled to a heatsink. In this case, the unit is in need of service.
Sep 02, 2014 | Denon Audio Players & Recorders
Kenwood VR 605 power light flashes
CHECK FOR CLEARED COOLING VENTS & FOR PROPERLY WORKING COOLING FANS. THIS WILL CAUSE SHUTDOWN OF THE UNIT. IF ITS ALL CLEAR, YOU PROBABLY HAVE A POWER SUPPLY ISSUE.
Dec 10, 2013 | Kenwood VR-605 Receiver
Pioneer vsx-521-k power goes on then off
Sounds like a short in the amp that will need to be repaired before the unit will stay powered on.
Feb 25, 2013 | Pioneer VSX-455 Receiver
When the receiver powers up just the fan seems to go on. Resetting by holding the i/o will turn the yellow light off but doesn't turn the fan off and comes back on after you release the i/o...
Hello Joe, my name is Becki, with DISH Network. You will want to make sure that the receiver is in a well ventilated area, and that there is nothing heavy sitting directly on it. The receiver's fan can start running constatntly if the unit starts to overheat. You may also want to try putting the receiver out on the floor for a few hours to cool down. You can also try to unplug the receiver from the power source for 10 seconds, that can be a more thourough reset than holding the power button down. The fan will run while starting the receiver up, for about 5 minutes, then it should stop running loudly. If you continue to have problems, please let me know!
Becki Barned
DISH Network Customer Service
becki.barned@dishnetwork.com
Jul 13, 2011 | DISH Network ViP 612
I have a VSX-1015-TX ,I powered it on but have no control from either the remote or the receiver itself,changed remote batteries,unplugged/replugged in receiver still no control,the receiver works as all...
to complete reset, it need pressing couple buttons by combination. if all buttons mulfunction, no way to do this function. does unit have front panel display?
Mar 19, 2011 | Pioneer VSX-1015 Receiver
Reason red light turns on on dual xdma6630 receiver
I had this problem and had to do a reset. (remove faceplate, turn on the power to aux for the car, press the 'reset' button with a pin or paper-clip for about 7 seconds, release. Put the faceplate back on and power on. I'd say it's a computer bug of some sort, at least in my case - the reset did the trick.
Mar 17, 2011 | Dual Car Audio & Video
Sirpnp2 reciever gets hot and loses signal.
I had the exact same problem with Sirius radios. I bought two Kenwood DTS-7000S receivers and both were sent back for warranty. Of the two, they only fixed one but by the time I figured out the other was bad, it was out of warranty. Kenwood, along with the repair community state they do fix such units, they toss them out. The thing that gets hot hot hot is the part that receives the Sirius antenna inside your unit. If you're like me and have nothing to lose then I recommend doing some cutting with a dremel and adding a small computer fan. It just takes a light breeze to keep that part cool enough (but it does take some sort of breeze, convection is out). For a home unit, find an old A/C power supply and match it to an old computer fan of equal or less voltage. For car, find a fan that uses 12 volts or less. It's an easy fix, really!
Nov 04, 2008 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Blinking red power light
I think Denon designed in a "bug" as mine just "went east" today
May 25, 2008 | Denon AVR-1906 Receiver
U-Line 1075WC Logo
20 people viewed this question
Top U-Line Refrigerators Experts
billconfused
Marvin
Marvin
Ilia Bichin
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
