Question about Panasonic Televison & Video
Panasonic TH-50PZ77U Plasma is 3 years old. Picture turns mostly black and white except for some green and blue tones. The green is a lime green, the blue is a lite electric blue. these 2 colors due not vary in how they look/ The TV starts up with good color, but more and more frequently it is changing to the scenarion described above. I'v tried switching to my blu-ray player and the result is the same. Please advise
  • 4,889 Answers
The fact that the picture is coming back to normal and then going back to the black and white mode, suggests that it is a capacitor problem. I suspect the location of the capacitors to be the main board, tuner board or the sustain boards. A problem of this extent means that you can identify them visually(cracked, bulged tops, or tiny holes at the top near the X cut). Replacing it depends on your prior experience in repairing electronics. High voltage electronics are not be messed with. The several thousand volts of resident electronic charge can cause permanent disability/death if not handled carefully.
Posted on Nov 07, 2010
A black vertical bar appears on my tv screen when I turn it on?
Hey!
With Plasma screens and just screens in general, that tends to be a big problem. Here is a link that kinda goes over the problem. http://adf.ly/1fNBRK . You most likely just have dead pixels which could either be a easy solder job or requirement to replace the screen. If you go with the latter, you might just want to buy another TV screen. http://adf.ly/1fNBRK
Nov 04, 2016 | Panasonic Televison & Video
Dvd player connected to panasonic viera. picture has blue skin tones and picture isn't centered
I always try the simple things first. check the connection. if hdmi .. then try a differnt cable.
It almost sounds as if one of your connections is plugged in the wrong place.
On component.. red to red, green to green and blue to blue .. then the extra red and white go to the video part .. also may want to check the tv manual - sometimes they share those connections with regular rca connection and easy to plug in wrong place.
Rca connetions - Yellow is video - red and white audio.
S video - one big plug and then red and white audio - make sure the big plug is fully in on both devices - I've seen similar things with s-video plug not fully connected on one end or the other.
Good Luck,
Bill.
Nov 29, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
The picture on my 3 year old panasonic plasma turned green the other day. I've tryed adjusting the tint but it has not solved the problem.
There is a diagnosis on this, do a search on "dyna109_94_8750.pdf" on the net. I hope this helps you correct the problem.
Cheers!
MJ
Nov 20, 2010 | Panasonic TH-50PX75U Plasma HDTV
Have a Panasonic TH-50PX500U plasma TV. Color go's to blues
check and reseat all the connections on your T-con board which is located in the midle top of your unit there will be a cable from the mainboard and 1 or 2 from the top to the panel carful those connectors are cheap clean with rubbing alcohol
Dec 01, 2009 | Panasonic TH-50PX500U 50 in. Plasma...
Grainy and red tint on component video inputs from
Usually when you have a red tint when using the component input i'ts because the wires are switched on one end or one of the 3 video wires is bad. See if blue and green are switched.I see this all the time. Is your picture grainy on all input?
Nov 22, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
Panasonic plasma.only 18 months old and the screen seems to be filling in from the left inwards.totaly black and about 1 third of screen is gone completely now and getting worse.started about 2 weeks ago...
it is possible that either the d-board is going bad or 1 of the c-boards. try to find and authorized panasonic servicer to help with the repair. we are authorized and in dallas texas. our business is Aces Tv Service.
Nov 17, 2009 | Panasonic TH-50PZ77U 50" Class Plasma HDTV
Panasonic TH-42PD25 The picture is black with
Make sure if your using the video input jacks, that the yellow is plugged into Video 1 and the same with the audio.Red & White. If your using Component, they are color coded- Red Blue & Green along with the Audio In -Red & White. It sounds like you have the video in the wrong jack.
Oct 28, 2009 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
Plasma TV with vertical lines
chake to make sure it is hooked up right and not lose
Feb 02, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
PANASONIC TV, TH-42PX60
If it's just one video plug, then perhaps you have to set av5 as being in colour somwhere in the menus.  If you require three wires for the pictures, as blue, green, and red, then make sure they aren't in the wrong ports.
Good luck.
Jan 16, 2007 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Televison & Video Logo
60 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
