Question about Cuisinart DLC-10S Pro Classic Food Processor
Dorn[t work. I turn it on and nothing. This happened once before when it was new. I called and they had me do something, but I don't remember what, somethng reverse. Then it worked
  • 51 Answers
I do believe those kind have a special locking mechanism. In other words, you have to be sure the bowl, the blade, and the top are all correctly positioned, and locked on, before it will start running.
Posted on Nov 07, 2010
Very frustrated with kitchenaid food processor - using any slicing disk only the first batch of food works, when you put in the 2nd batch nothing happens
Mine is older and works fine once I realized bowl has to be snapped into place before the cover and then the cover has to be locked in. This activates a small button at the base of the bowl that activates a safety switch.
Jan 03, 2015 | KitchenAid Food Processors
Cuisinart will not run
unplug it take the blades off then see if ther is something stopping it other wise the gear box is shot need to replace with new one don,t get it fixed cost more then what it,s worth
Jul 29, 2014 | Food Processors
Hamilton Beach food processor
make sure bowl and lid are on correctly. If not, it wont run. Both have safety switches where they lock onto the unit. If latch tab is broken, you will need new bowl or lid. If still nothing, switch itself is bad
Jun 28, 2013 | Food Processors
When i turn on the hobart fp41 food processor nothing happens.But when i push on the contactor with a screw driver it works.Does that mean that the switch is bad or is there something wrong between the...
have you tried to replace the contactor and see if that helps at all? If there is another issue like a bad switch contact then you can still replace that becuase some of those parts are universal
Feb 28, 2011 | Hobart FP41 16 Cups Food Processor
The motor stopped working i unplugged and replugged into a number of outlets...nothing happens is this a burnt out motor or could it be something simple?
Hi there, I just had the same problem and then found an on-line manual that says this:
An automatic, temperature-
controlled circuit breaker in
the motor ensures complete
protection against motor burnout.
If the processor runs for an
exceptionally long time when
chopping, mixing or kneading
a thick or heavy mixture in
successive batches, the motor
may overheat. If this happens,
the processor will stop. Turn it
off and wait for the motor to cool
off before proceeding. It will
usually cool off within 10 minutes.
In extreme cases, it could take
an hour.
Yayyy! Problem solved (I hope)!
Hope that helps you...
Nov 02, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Just purchased Oster 3322 food processor and cannot get it to work. Have used various brands and know that this unit has been properly assembled. Neither the 'on' or 'pulse' buttons will activate the...
Oster is a good brand. Unplug it and try to turn thhe motor by han using an attachment. Or, tap the unit with a run button depredded. Here is why. Sometimes new brushes on a motor have a coating on the conrtact surface. It is vry thin and it is not permitting a good electrical contact. If you can't turn the motor, slap it a couple of times with it on. Once it starts, let it run for 2 or3 minutes and you troubles are over once the brushesseat and clean up. Good luck and remember to unplug when hands are on or near the attachments.
Oct 27, 2009 | Food Processors
Bravetti Food Processor Model KP80B
That's alot of bad outlets.Are you sure there's nothing wrong withe the processor? Just kidding. How long have you had this processor? Any chance of taking it back?
If not, try this. With the unit unpluggedput an attachment on that you can hold onto and try to rotate the motor. Not all are tested and sometimes the motor brushes are not making good contact. If you turn it manually you may get lucky and set them to work. If you get it running, chk with power after several turns, run it constantly for abot 5 minutes to seat the the brushes. Remember to have it unplugged when you have your hand on the attach ment. Good luck. Ned
Aug 24, 2009 | Bravetti Quad Blade Food Processor
It won't turn on
The work bowl and lid must be locked together in a specific order or else the processor will act dead. If your DFP-3 has a "tower" on the back, make sure the tab on the lid connects to this tower. If your model does not have a tower, call Cuisinart to verify the correct assembly - 1-800-726-0190
Aug 16, 2009 | Cuisinart DFP-3 Handy Prep 3 Cups Food...
Light is on but blade will not turn
You have a bad sensor switch, when you put the bowl. Locate the sensor switch and replace it.
Jul 23, 2009 | KitchenAid KFP740 Food Processor
Tried to use my powerprep pluss cuisinart food processor and nothing happens. The on button lights up but nothing happens when i press the pulse button.
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
Your processor should now turn on.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 23, 2009 | Cuisinart DLC-2014 PowerPrep Plus Food...
Cuisinart DLC-10S Pro Classic Food Processor Logo
162 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Rommel Balcita
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
