Question about Acer Aspire 3000 Notebook
I have acer aspire 3002lci . I want restore factory settings. I won't have recovery cd.How to do? i had done with alt+f10 it doesn't work.
  • Ironman II
    Ironman II Nov 07, 2010
    Have you looked on the Acer website for recovery CD's for your model
  • 4 Answers
The ALT+F10 routine should work if the ALT key is held down and the F10 key is repeatedly depressed before and during the Acer logo display.
If you still have a working M/C then the recovery routine can be accessed from START / ALL PROGAMS and selecting Acer Empowering Technology and then Acer recovery Management.
This might differ a little because you have a netbook
Posted on Nov 08, 2010
How do you get to the recovery program on an acer aspire 1641WIMi?
To use Acer e-recovery please follow the following steps:
1-Plug in the AC adapter and battery.
2-Turn the system on
3-Immediately, press ALT on the keyboard and start tapping F10.
Continue holding ALT and tapping F10 as the unit boots up.
4-A screen stating "Starting Acer E-recovery" should appear.
(Release ALT and stop tapping F10 at this point)
There will be 4 options:
1- Restore system to factory default
2- Restore system from user backup
3- Restore system from cd/dvd
4- Exit
Apr 28, 2014 | Computers & Internet
Aspire zg5
aspire netbook to factory defaults Save any files or folders on your Acer Aspire One with flash drives. Drag and drop files onto the icon of your flash drive. Go to "Start" > "Restart" to reboot your netbook. Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load. Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen. Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted. Restore your saved files from the flash drive. or Click on the Start menu. Then, select all programs, Acer Empowering Technology and Acer eRecovery Management. If this is the first time you have opened the program it will prompt you to set up a password and create a backup CD. Click the Restore button and select the option that reads "Restore system to factory defaults". Wait for the computer to finish the restore process and reboot. Restoring for the Boot Screen If your computer will not boot up properly, you can attempt to reach the restore option by pressing the Alt button and the F10 button at the same time. When the eRecovery menu appears, choose "restore system to factory defaults". Wait for the recovery process to complete and the computer to restart Hope this helps.
Jan 21, 2013 | Acer Aspire 5720-6661 Notebook PC
Acer Aspire One D250-08K Need to restore to factory settings and i have no disc. Screen is black. On start up pressed ALT F10 then nothing happens
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
You can also create a set to Recovery disk from the recovery partition, to do so
Start Menu> All Programs> Acer erecovery management> Click Create Factory Default Disk, if you receive any error code or unable to burn the disk, please contact Acer Technical support at 1 800 816 2237 and order for an Recovery Disk.
Thanks and regards,
Jitha
Aug 29, 2011 | Acer Aspire One PC Notebook
Want to restore my Acer aspire 4720z!
From Acer direct
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Jun 02, 2009 | Acer Aspire 4720 Notebook
How do I reset my computer
According to the Acer website:
1. Turn system on
2. Immediately press ALT and start tapping F10. Continue holding down ALT and tapping F10 as the unit boots up.
3. A screen stating "Starting Acer Recovery" should appear.
(release ALT and stop tapping F10)
4. There will be 4 options;
1. Restore to factory default
2. Restore from user backup
3. Restore from CD/DVD
4. Exit
Good Luck
Mar 26, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire 3660 recovery
You can download the recovery cd files athttp://support.acer-euro.com/drivers/notebook/as_3660.html.glad to be of assistance.RICHARDM69
Dec 07, 2008 | Computers & Internet
Need to restore acer to factory settings
just boot from your backup disk. it will guide you to reload the Operating system (factory default).
FYI, if you haven't delete the recovery partition, you can use alt+f10 to reload. just press alt+f10 during boot.
Jul 31, 2008 | Acer Aspire 3000 Notebook
Computer restor back to factory set
Pressing F10 on start up, is not for acer laptops, you need to have done a back up when you first got it running and use e-recovery to recover from your 'D' drive. see this explanation http://support.acer-euro.com/drivers/notebook/as_3680.html
Apr 19, 2007 | Acer Notebook
Acer Aspire 3000 Notebook Logo
886 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
