Question about Samsung Black DVD Player DVDC350
HOw do I change the region code on ssamsung ak59-00104r so that I can play my english dvd's??
  • 10,421 Answers
Changing dvd region codes
You can't change the DVD coding. That part is how the DVD is recorded. However, your Mac will play DVDs from another region. It just typically defaults to one region. I have deleted the DVD player software (and preferences files) before and reloaded it to play DVDs from another region. If you plan to regularly play DVDs from multiple regions, you might want to look for special DVD software that will read DVDs from multiple regions.
Jun 30, 2014 | Computers & Internet
Tip
DVD region code
Generally, your Pioneer DVD 120K player can play any DVDs from your region. As you encounter the situation that can not play the DVD, i guess your DVD from other region. To change the region code of DVD is High-risk operation, it only can be changed less than 5 time, and you are not to recommended to do that. If only for one or several DVD Discs, just remove the DVD region code via a DVD ripper. Of course, if you bought the DVD player from other region, you can change the region code of DVD player permanently.
on Jan 18, 2014 | Pioneer DV120K Player
DVD CD's will not play in English other languages OK, also other DVD's do work but most don't. I am stumped tried everything, Menu butttons on DVD, TV (Sony) and CD's will not work on English #1 channel...
It is possible that someone has changed the region that the DVD player is in. If the menu is not in English you will need to translate the language to get it back to English in the language selection. Find the region selection in the menu and change to the proper region, this should fix the issue since some DVD work, they probably have a Region code of 0. Cheers.
Check out the Region Codes here:
http://www.hometheaterinfo.com/dvd3.htm
Feb 08, 2010 | Koss KS4110 DVD Player
DVD drive ''Free'' Region code does not play Region 1 DVD
You cannot see region 1 movies unless you change the region code, its designed this way as an anti piracy measure.
Oct 03, 2009 | Computers & Internet
I need to change the region from 1 to 4
You have to go to the device manager of the operating system. List the hardware. Right click on the actual dvd drive and select the area that you want to change the region to. It will display the region.
Aug 10, 2009 | HP Pavilion dv5-1160us Notebook
Mac book pro is currently locked to region 1,
Home Index DVD Region Codes
In order for you to view a DVD's content, the region code on the DVD and the region code for DVD Player must be the same. Your DVD drive is automatically set to a region code the first time you play a coded DVD. If the region code for a DVD does not match the current region code for DVD Player, a dialog appears for you to change the code for DVD Player.
IMPORTANT: You can set the region code for DVD Player only five times (including the original setting). The fifth time you change the code, it will be permanently set. The following map and table indicate the code for the various regions. Some DVD discs can be played in any region, and are sometimes referred to as having region code 0. These discs can be played regardless of the region to which DVD Player is set.
Mar 30, 2009 | Apple Computers & Internet
Our Sony DVD player will not playimported DVDs from the UStates
1) those DVDs are coded in Region 1(Canada, United States; U.S. territories; Bermuda)
you will have to change the region code on the dvd-rom to region 1
2) if you bought the stand alone DVD player in the U.S. it will play region 1 dvds and nothing else(some dvd players will play region code 1-6)
3) to change the code in windows vista you'll have to go under the drive property's in the device manager go to the dvd region tab and set it to what ever the number on the back of the dvd is WARNING you only get 4 changes before the drive locks you out permanently then your stuck with what ever number you put in on the 4th try you've been warned
windows xp/2000/98/me
you'll have to change the region code from your software player again your limited on how many times you can change the region code before you have to reinstall the dvd player software
Feb 02, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
I need to change the region code from asain to english
U need to decrypt your Blu-ray disc. Try this tool(http://www.pavtube.com/blu-ray-ripper/) which can decrypt and rip the m2ts files off from disc. Then u can play the m2ts files on your player. And there is no quality loss during conversion.
Jan 21, 2009 | Sony Playstation 3 (PS3) Console
Wrong region
hi!your english is good!!
please try this:hope it helps!
dvp720sa
dvd player on
open tray
(no disk inside)
1. Turn on the player.
2. Open the tray.
3. Press the following sequence on the remote: 9-9-9-9-0
4. The number 0 will appear on the lower left side of your screen.
5. Your player is now region free! Put in a DVD and enjoy!
NOTE: The 0 in the sequence above represents the region code. 0 = region free. If you want to change your player to just a specific region code, replace the 0 with the region number you want.
Nov 20, 2008 | Philips DVP 720SA DVD Player
Incorrect region codde
This is for DVP31XXX series i hope it works all on DVP31 series. It has been tested on DVP3146K /51 and it has been worked...
1. Make sure there is no disc in the player.
2. Turn power off and on again.
3. Open the tray.
4. On the remote, hit 9879 and then 0. This changes unit to Region 0, meaning it'll play all regions.
5. Hit OK on the remote.
Good Luck Guys!
Apr 27, 2007 | Philips DVD 622 DVD Player
Samsung Black DVD Player  DVDC350 Logo
366 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
