Question about Weiser Lock Powerbolt 1000 Lock
What does the flashing green light mean on the Weiser Lock 1000
  • 963 Answers
Http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Customer Support can help you further.
Posted on Nov 08, 2011
Weiser lock powerbolt only goes half way and a green light flashes 5 or 6 times with a beep, how do i fix
Brent, Try resetting initialization/ installation or contact weiser. Attached you will find links to your manual. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.weiserlock.com/pdfs/instructions/electronics/smartcode.pdf
http://www.weiserlock.com/PDFs/instructions/Electronics/5062000-Powerbolt2-Instructions-eng.pdf
http://www.weiserlock.com/en/customerservice/productsupport/supportcontact.aspx
May 26, 2016 | Weiser Lock Locks & Locksmithing
Does the green light flash all the time on my powerbolt and when I open the door from the outside there is a beeping sound this has never happened before not untill I changed the batterys.
Powerbolt is Beeping?
This is the relevant excerpt from the Powerbolt programming and troubleshooting instructions:
Why is my Powerbolt 1000 unit beeping?
To determine why your lock is beeping abnormally, please follow these steps:
Take out batteries and unplug powerstrip.
Let it sit for 1 minute, then put the batteries back in and wait another minute.
If it does not beep, the keypad needs to be replaced (17733-1).
If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish).
The complete page that I cut this from can be found by cutting and pasting this link into your browser search bar:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Since you've already gone through the battery change, this suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem, first of all to confirm that you need the part before you go through the expense. Secondly, they will be able to get the correct part on order for you.
Jul 03, 2011 | Weiser Lock Powerbolt 1000 Lock
Need to change the combination on weiser lock
Follow this link:
Which will take you to the programming instructions for your Powerbolt 1000.
Jun 27, 2011 | Weiser Lock Powerbolt 1000 Lock
I am looking for a manuals for a weiser lock powerbolt 1000 can i down lord
powerbolt 1000
Here's a link to the Frequently Asked Questions page for the Powerbolt 1000:
The instructions for reprogramming the code can be found there. Good luck!!
Apr 07, 2011 | Weiser Lock ED1460X3VKD Powerbolt 1000...
Unit is functioning o.k., but getting green light flashes about every 10 seconds. Batteries and connections are o.k.. Can't find anything in the manual or on Weiser website as to a solution.
reset all code and retry...
  1. To program the first code, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  2. To program the second code, press the reset button twice , then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  3. To program the third code, press the reset button 3 time, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
Good lock
Good unlock
Dec 31, 2010 | Weiser Lock Powerbolt 1000 Lock
Lock only flashes green and the lock is in the verticle position when oit is suppose to be locked.When its horizontal its unlocked.
The Weiser brand and Kwikset brand Powerbolt are identical (Black & Decker), so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Dec 29, 2010 | Weiser Lock Powerbolt 1000 Lock
# WED1460 X3 VT 4LS2 I changed the batteries, now I get a flashing green light when the lock is closed or unlocked. It does not turn red at all. Every thing works when keypad is used.
The Weiser and Kwikset locks are identical, so these instructions will work for you:
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
Nov 17, 2010 | Weiser Lock Powerbolt 1000 Lock
How do you reset all the codes on a weiser lock?
Oct 29, 2010 | Weiser Lock Powerbolt 1000 Lock
I installed my powerbolt today and it works but after i enter my code to unlock it, it retracts the bolt and then beats at me a couple times, but it works... and the green light keeps flashingwhats wrong...
Hello Lil Babe,
The lock is working just as it is supposed to. The beeping after it retracts is an audible signal to let you know that the lock has opened or closed.
The flashing green light is a visual signal to let you know that the lock is "open" and you are able to open the door. When the lock is "locked" the light will flash red momentarilly and then should stay solid red for a brief time.
Everything is working just fine, so congratulations on doing a successful installation of your new electronic lock!
I hope you find this Very Helpful and best regards!
Dec 11, 2009 | Weiser Lock Powerbolt 1000 Lock
Weiser Lock Powerbolt 1000 Lock Logo
1,477 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
