Question about LG KG800 Cellular Phone
LG Chocolate the touch pad will not work when the phone is slid up, it will only work when it is slid down and i press the volume key twice. y is this?
  • xdaisiex Jun 18, 2008
    thanks 4 ur help........not
    y did u put tht on there
    i came on here to get an answer not supid **** like tht!!
LG Chocolate - a91ac87.jpgRsrss
Posted on Jun 17, 2008
I have a ZTE Boost Mobile phone and my screen will not let me swipe it to unlock it and I would like to know what to do to fix the problem. My volume and power button works but that is it.
first check your TOUCH pad working or not if not than its Hardware problem, replace Touch pad and check it out. if not working than try to hard reset by switches
  1. Turn off your phone.
  2. Press and hold Volume Up + Power at the same time for a few seconds.
  3. Release held keys when you see Recovery Mode.
  4. Then press Volume Down to select option "Wipe Data/Factory Reset", and press Power button to confirm.
  5. Well done!
Apr 17, 2016 | ZTE Cell Phones
How do I complete a factory reset
Depends on the model of phone but this is for the Android based Motorola's
How do I reset my phone to factory settings?
Factory Data Reset is a tool used to remove everything that was imported, added or installed on the device.
WARNING: When using this feature; everything is deleted. Nothing stored on the MicroSD will be affected.
Important Note: Your contact and email information is automatically backed up to the Gmail server. Your information will be restored when you login with your user name and a password.
To Perform a Reset
  1. Open the Applications Tray. (arrow pointing up located in the middle at the bottom of the display screen)
  2. Touch Settings
  3. Touch Privacy
  4. Touch Factory data reset
  5. Touch Reset Phone
  6. Touch Erase Everything
Note: You cannot reset/clear your phone remotely if it is lost or stolen.
To Manually Reset
If there are significant problems with your device or you are not able to follow the steps above please use the following process to manually reset the phone:
  1. Turn off phone
  2. Press Power key + "x" (on the hardware keyboard) to power on the phone and bring up the recovery screen.
  3. Press Volume Up + Volume down key for 10 seconds then press and release the volume down key..
  4. Using the volume keys scroll to Wipe data/factory reset
  5. Press the center of 5-way navigation pad
  6. Using the Volume keys, select Yes -- delete all user data
  7. Press the center of 5-way navigation pad
  8. Using the Volume keys select Reboot system now
  9. Press the center of 5-way navigation pad
Aug 05, 2014 | Cell Phones
Phone is muted...No one can hear me when I am calling, or answering a call. I can hear them fine. Phone shows "muted"?? How do you "un" mute?
Receiving Calls
1. To answer a call, touch or open the slide.
 If the slide is closed, simply slide it up.
 If the slide is closed, press the Voice
Commands key twice, then touch .
 If the slide is open and the touch buttons are
lit, touch .
NOTE If you touch Left Soft Key [Quiet] while the
phone is ringing, the ringing or vibration is muted
for that call.
NOTE If you touch Right Soft Key [Ignore] while the
phone is ringing, the call will end.
Mute Function
The Mute Function prevents the transmission of
your voice to the caller. To quickly activate Mute
touch Left Soft Key [Mute], then to unmute
touch Left Soft Key [Unmute].
NOTE! while doing this you must call someone then while talking with him touch Left Soft Key [Unmute] to Unmute
Hope it help you out ^_^
try download the manual if you loose it
http://www.cellphones.ca/upload/manuals/lg-vx-8500-manual.pdf
Jul 03, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Calling Problems with LG Chocolate
Make sure the Volume is turned up. The Side Key(if it has 1) will turn the volume up.
Jul 01, 2009 | LG CHOCOLATE VX8500 Cellular Phone
White screen!!
my lg's camera started to turn my phone off, i do tech work for a wireless company and when i was trouble shooting my own phone as a test i went to my camera and my screen went blank! i tryed every thing, but the master reset. because my screen is blank i need to know the number i will have to enter to get it reset from the key pad.
Sep 30, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Screen and touch-pad buttons
1-Check the battery status of u r mobile , charge atleast 6 hours
2-There is problem in display.Than contact LG care center
Nov 08, 2007 | LG KG800 Cellular Phone
their is nothing you can do it sounds like the board is warped cant you take it into a phone repair shop maybe the shop can get it repaired their is no easy fix as this is an internall problem if you brought the phone new you should be able to get it replaced no matter where you are try giving them a ring sorry i cant be any more help.....................
Oct 26, 2007 | LG KG800 Cellular Phone
Forwarding txts from my chocolate
Press the lefts soft key
Press 2
Scroll down to the message you want (even though you can't see, take a quess)
Press the right soft key
Press 2
Press Right soft key then 1 to go to your contacts (type in the name, press done then the left soft key)
To send to your email, press the left soft key, press 2 then enter in the address.
Clicking 1 twice gives you the @ sign and clicking 1 once will give you a .
You're phone guide gives you most of this information. I'm having the same problem, except my key pad is a bit messed up as well, makes it more difficult for me.
Sep 11, 2007 | LG CHOCOLATE VX8500 Cellular Phone
LG KG800 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
