Computer switches off after 2 beeps - Computers & Internet
  • AnimaCube
    AnimaCube Nov 07, 2010
    Would you, by any chance, know which BIOS your computer runs. It should say somewhere on the screen as soon as the computer is turned on.
    -AC
    Genius:
  • 1,325 Answers
Hello
what computer model number is it ?
This double beeping issue can be caused by any of these situations.
  1. New hardware conflicting with old hardware.
  2. Bad or failing hardware device.
  3. Connections not connected or connected properly.
  4. Recent electrical storm that caused a surge that damaged computer.
  5. Other hardware issue.
Posted on Nov 07, 2010
  • 91 Answers
Dear sir,
[ls check the Ram , slot & also if u have external display card , remove it clean it & reinstall it .. But this kind of problem is mainly due to ram & if possible remove processor & reinstall it
Regards
Raj
I have a P5K Deluxe asus mother board error beeps no visuals
Two beeps is usually the video card.
Do you have a spare video card to change out?
This is why people keep obsolete PCI video cards for just such tests.
Dec 05, 2015 | ASUS P5k Deluxe Socket 775 Motherboard
Beep beep drivin me crazy
nobody can guess which switch or wire is failing.
Donna. we use the FSM, the factory service manual
we open to the page , security,
then we check each sensor for flaky ops.
either get it fixed or defeat it.
there are only 2 choices, with no fsm.
no alarm get better with age , they all this this bull.
corrosion, always wins. entropy is the cause.
you might inspect all switches (ajar switches ) here
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
see WJ
see page wiring security , for free.
i key on, and use a voltmeter at each switch
and make sure it goes to 0v each time activated
if not , its bad.
Mar 31, 2014 | 2000 Jeep Grand Cherokee
GA-H77M-D3H 6 beeps on POST and then restarts
Check timing between each beep---Make sure It's 6 Even beeps--Not 3+3--1+5--2+4 ect----Timing between beeps will tell you---let me know.
Mar 01, 2014 | Gigabyte GA-H77M-D3H Socket 1155/ Intel...
6 beeps what dose it means
Dell beep codes:
If your computer beeps during start-up:
Run Dell Diagnostics to identify a more serious cause.
Beep Codes Your computer might emit a series of beeps during start-up if the monitor cannot display errors or problems. This series of beeps, called a beep code, identifies a problem. One possible beep code (code 1-3-1) consists of one beep, a burst of three beeps, and then one beep. This beep code tells you that the computer encountered a memory problem.
Contact Dell for technical assistance.
Code Cause 1-1-2 Microprocessor register failure 1-1-3 NVRAM read/write failure 1-1-4 ROM BIOS checksum failure 1-2-1 Programmable interval timer failure 1-2-2 DMA initialization failure 1-2-3 DMA page register read/write failure 1-3 Video Memory test failure 1-3-1 through 2-4-4 Memory not being properly identified or used 3-1-1 Slave DMA register failure 3-1-2 Master DMA register failure 3-1-3 Master interrupt mask register failure 3-1-4 Slave interrupt mask register failure 3-2-2 Interrupt vector loading failure 3-2-4 Keyboard Controller test failure 3-3-1 NVRAM power loss 3-3-2 Invalid NVRAM configuration 3-3-4 Video Memory test failure 3-4-1 Screen initialization failure 3-4-2 Screen retrace failure 3-4-3 Search for video ROM failure 4-2-1 No timer tick 4-2-2 Shutdown failure 4-2-3 Gate A20 failure 4-2-4 Unexpected interrupt in protected mode 4-3-1 Memory failure above address 0FFFFh 4-3-3 Timer-chip counter 2 failure 4-3-4 Time-of-day clock stopped 4-4-1 Serial or parallel port test failure 4-4-2 Failure to decompress code to shadowed memory 4-4-3 Math-coprocessor test failure 4-4-4 Cache test failure
Aug 12, 2013 | Dell Gx620 Gx 620 Sff P4 Ht 2.8ghz 1gb...
Asus p4s800 beep codes. I get one long beep. I
The one long beep, this has something to do with the video card.
Can't really tell without the BIOS you are using !
Anyway, try removing the card and replace it. ( with anything, just to check. )
This is a good board, I have a ASUS P4C800 and you can't beet it.
P.S. Make sure all your memory is the same freq. and clock speed.
Good luck.
Oct 23, 2009 | ASUS P4S800-MX Motherboard
My Dell 100L will not switch on and battery will not charge.
since the LED is orange it might be a ram issue. try to locate the memory modules in your computer then try to reseat them. or if you have 2 ram modules try to remove 1 first then try to turn on the laptop check if it will do the same thing. then try removing 2 ram modules check if it will beep. if no beeps ask for mobo replacement. if it has beeps take note of the beep codes.
Oct 03, 2009 | Dell Latitude 100L Notebook
Beeping from motherboard
ladysharm,
Make sure that all of the plugs are plugged into the right places. Mouse ,Keyboard,etc..How does it beep? 1 time 2 times??
please post any beeps codes.
Feb 26, 2008 | Packard Bell (181379) Motherboard
Dont know how to switch computers.
Doesn't your KVM switch have numbers? Make it easy on yourself and hold down SCROLL LOCK and hit the corresponding number to which the PC is connected to. When you hold down SCROLL LOCK, you'll hear a bunch of beeping sounds, hit the number and it'll switch to the PC of your choice.
Mar 04, 2007 | Cables Unlimited SWB-9000 2-port KVM...
Computers & Internet Logo
43 people viewed this question
Alun Cox
David Payne
David Payne
