Question about Canon MVX200i Mini DV Digital Camcorder
Hi, after a long period i want to use my MV200i again. But the only thing it says it "Eject the Tape". There is a tape loaded. When i press the eject button, it makes some sound, some gears are movin, but the tape gets not ejected. Can i remove it manually? regards
    Genius:
  • 1,812 Answers
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Nov 07, 2010
When I open the tape eject it pings but does not push out the tape holder, any fixes?
hi,
please check the mechanism side, if you left your cam for a long period with cassette loaded position, the tape will stick on the head and roller of you cam, if so you have to manually loosen the cassette reel from.
Mar 30, 2016 | Samsung VP-D361 Mini DV Digital Camcorder
VCR EJECT FAILURE
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or having the belt replaced. With the cover off (be careful not to touch anything live with power) and try loading and unloading a tape. Try to find the motor and belt which operates the loading mechanism. When it "catches" as you say, try moving the belt pulley with your finger to give it a little help and see if it continues on with the operation. If it does, the belt is probably slipping. It takes more effort on the belt & pulley during an eject sequence rather than the a load sequence, so it may load fine but have trouble ejecting. Gravity and the weight of the tape is why you may not have this problem during the load sequence.
Jan 28, 2008 | Goldstar GBV241 DVD Player/VCR
Tape will not eject
sir,
If any of your electronics system not using for long period, remember this things( detach the battery or power source , take out cassette or memory card, if the unit use in built chargeable battery, charge it occasionally.
just connect to the power, you don"t power on your camera, the charging light will flicker then push the eject button, remember do not on the power of your cam, hop that this will solve your problem.
Feb 03, 2016 | Video Cameras
Vhs tape is stuck and message reads "tape
Unplug the TV/VCR/DVD Combo from the main power for a couple of minutes, the unit may eject the tape at the power ON.
You can also try openening the unit, reset the loading posts and eject the tape by manually turning gears, motors etc..You have to know what you're doing otherwise, you will do more damage or get injured and don't forget HIGH VOLTAGE CAN KILL.
Best of lock
www.aaatvservice.com
Jul 15, 2011 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
Cannot get tape to eject
It could be a couple of different issues. These things could help.
(1) Power OFF the camera, remove battery then replace the battery, power up the cam and try to eject tape again. Nothing? try...
(2) Gently press inward on the tape cover with both thumbs a few times. Then, while pressing gently inward with one hand, press the release/eject-tape function until you hear a click or release sound. Then, if it doesn't open automatically, gently "help" open the hatch.
If it remains stuck, after follwing these steps a few times it would be my guess that perhaps the camera has been dropped in a way that jammed the mechanism controlling the eject function.
TIPS that may prevent having eject problems: When loading tape, be sure to insert the tape correctly and slowly, makeing sure the tape is placed properly. Gently press on the specific location indicated to close the tape holder, and wait for the tape to "seat" properly before closing any other part of the tape cover or hatch mechanism. Taking a few extra seconds when loading the tape can save extended frustration later.
May 16, 2011 | Samsung SC-D363 Mini DV Digital Camcorder
I can't eject cassette from my Canon MV800i
The mechanical of the tape loading path is misaligned, Contact any expert for mechanical adjustment of the tape loading path, No worries it will work fine again, and this would not be expensive.
Thanks for using fixya.
Jun 16, 2009 | Canon MV800i Mini DV Digital Camcorder
My GL2 camera constantly wants me to eject tape!!  I am unable to use my camera because it forces me to eject  the tape. I've switch tapes and use new tapes and still the same  results. Only time it...
The immediate remedy may be cleaning the video heads. The head is not receiving the data from the inserted tape because it may be clogged. Use head cleaning tape for about 10 seconds but NO MORE. Try again, if not you may need to clean and adjust by trained technicians. Good luck -James. For further assistance, go to www.camerarepairjapan.com
Mar 20, 2009 | Canon GL2 Mini DV Digital Camcorder
JVC GR D247EK #140M0089 - Camera stopped loading cassettes. Remains in eject position.
Remove the battery for 30 minutes and try again. When putting the tape on camera press only where indicated by an arrow. Good luck!
Nov 20, 2008 | JVC Cameras
Samsung SCD-5000 miniDV tape deck problem
Hi, I have a SCD 5000 Samsung camera. The video plays and records. But the camera side does not show in the video screen. HELP me
Jul 06, 2007 | Samsung DouCam SCD-5000 Mini DV Digital...
Tape won't load
probobly some problem withthe load motor/ The first thing to look for is to see if the heads are spinning - or at least see if they *try* to spin, because unless they *are* spinning the tape will never load. Also, the heads *shouldn't* be spinning with no tape inserted - if they are then this suggests that the dew sensor has been activated (the heads are made to spin under this condition in an attempt to dry things out). If this gives no clues, the next step would probably be to dismantle the thing and attempt to load a tape by hand (looking for signs of jamming mechanism, etc. Anything more serious than this is one for the workshop
Mar 14, 2006 | Canon ES50 8mm Camcorder
Canon MVX200i Mini DV Digital Camcorder Logo
80 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
