Question about Compaq Presario CQ60-220US PC Laptop
My screen turned 90 degrees while cleaning off keyboard. can you tell me how to correct this. thank you!
    Problem Solver:
Please go to your desktop screen. Once there, press right click on your mouse then in one of the options, you may find the proper orientation for your desktop screen. Best wishes!
Posted on Nov 07, 2010
Testimonial: "thank you! i was able to fix this with your advice."
I don't know what keys I pressed but the screen display has been rotated thru 90 degrees. How to return to 'normal' please.
Press at the same time the following keys on your keyboard
Ctrl + alt + up... or any of the direction keys until you get it the correct way up
Mar 26, 2015 | Computers & Internet
Hi can you tell me how much torque spectification to replace head gasket bolts, camshaft caps bolts, and camshaft pully bolts for 1994 GS 300 lexus Thank you very much for your help
    Cylinder head bolt tightening sequence - 1993-97
  2. Remove the head from the engine. If prying is necessary, use a protected blade; take great care not to damage the mating surfaces of the head and block.
  3. Clean the head and block of all gasket material. Take great care not to gouge or scratch the mating surfaces.
To install:
  1. Place a new gasket on the cylinder block. Make sure it is positioned correctly. Install the cylinder head in position.
  2. Lightly coat the head bolt threads and plate washers with engine oil. Install the bolts in the head.
  3. Uniformly tighten the head bolts in several passes in sequence, to 25 ft. lbs. (34 Nm).
  4. Mark the front of each bolt with a dot of paint. Following the correct order, tighten each bolt an additional 90 degrees. When complete, all the paint marks should face to the side of the engine.
  5. Again following the correct order, tighten the bolts another 90 degrees of rotation. When complete, the paint marks should face the rear of the engine, exactly 180 degrees away from the original starting point. Correct bolt torque is expressed as 25 ft. lbs. (34 Nm) + 90° + 90°.
Jan 07, 2011 | 1994 Lexus GS 300
The screen on my computer has rotated 90 degrees ,how do i get it back to normal
On your keyboard press Ctrl + Alt and then use the arrow keys to rotate your screen.
hope you find this solution helpful
Thank you for choosing Fixya
Jan 25, 2010 | Acer Computers & Internet
How do you fix a 90 degree tilted monitor sreen??
Ctrl-Alt-arrow key....try all arrows, one of them will correct it.
Dec 03, 2009 | Northgate 17" LCD Tilt Screen Innovations...
I pushed some keyboard sequence by accident and my screen turned 90 degrees counter-clockwise. How do I undo this?
To undo this, press "CTRL + ALT + Up" arrow keys together.
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Aug 27, 2009 | Televison & Video
My screen has suddenly turned 90 degrees to the right how do i fx
You may want to look into your video card settings about that. Most intel video card has that feature. You should be able to press the CTRL button and the LEFT button to change it. If thats not it then look into the control panel.
Apr 22, 2009 | Computers & Internet
Rotating screen display
click again until screen is right. then open mouse config and turn off that button or change it's function.
Jul 01, 2008 | Logitech 9311570403 Mouse
SCREEN TURNED TO LEFT WHEN I HIT KEYBOARD WITH BOOK COVER
1. If you right click on the desktop and look at graphics properties, or something similar to that, then you should get a menu for your display adapter control panel. Usually the screen rotation is right there. Sometimes it's as easy as a CTRL + arrow key combination, but I'd rather see you adjust it from a menu.
2. Ctrl-Alt-Up - right side up
Ctrl-Alt-Right - 90 degrees
Ctrl-Alt-Down - 180 degrees
Ctrl-Alt-Left - 270 degrees (If that doesn’t work, try Ctrl-Shift-R)
3. If you have the intel video chipset, I believe pressing CTRL+ALT+ one of the arrow keys should fix your problem.
I think it was ctrl+alt+right, but if that doesn't work, try the other three arrow keys.
However, if that doesn't work (especially if you do not have intel video), then right click on your desktop, go to properties, and go to the advanced tab. There you should find some setting that will allow you to reverse the rotation.
Dec 06, 2007 | Logitech Cordless Desktop EX110
Compaq Presario CQ60-220US PC Laptop Logo
128 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
