Question about Clothing Accessories
Which lens color is the best? - Clothing Accessories
  • 1,141 Answers
Lens color is a personal choice and doesn't affect how well sunglass lenses protect your eyes from UV light. Gray and brown are popular because they distort color perception the least.
Athletes often prefer other tints for their contrast-enhancing properties. For example, yellow lenses are popular with skiers and target shooters because they work well in low light, reduce haze and increase contrast for a sharper image.
Posted on Nov 07, 2010
Changing colored lens on glow buoy
The way I change the colored lens to the glow buoy is with three standard screw driver, about a 3/16" head good 4" shank or longer. If you look close you can see four grab tabs in the middle of the lens, these hold on to a lip on the clear lens. Twist the colored lens till you can get to three of the tabs. I couldn't get to all four do to the triangular shape of the top. Slowly wedge the driversunder the lip of the colored lens center to the tabs one by one, alternately pressing the screw drivers deeper once you get the to where they wil continue no futher, due to the bevel in the lens, take the two drivers opposite each other and push them in forcing the edge outward. The lens will pop off violently, and most likely shoot the third screwdriver across the room, but after changing them a few times the lips wear down soon you will be able to pull them off with a good pair of fingenails. Hope this helps, you may scratch the lens a little, also the covers have a bit more flexibility then I thought I was afraid to break them but now I see the give.
Jul 20, 2013 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
InFocus X3 plastic lens
If you still have the owners manual there should be an 800 number or some sort of customer support for it. Unless it's really old that is your best bet for the internal pieces
Nov 23, 2012 | InFocus X3 DLP Projector
Do I need see an eye doctor to get non prescription colored contacts?
If you have a good vision and needn't vision correction, you can buy nonprescription colored contact lenses (0.00 power lenses) directly from optical shops. According to my knowledge, Bright Eyes Contact is the best online store which provides natural colored contact lenses that are really cool contact lenses available in a variety of patterns and diameters, circle lenses can multiple effects, ranging from natural-looking to super bold look.
Sep 06, 2012 | Niles IntelliControl ICS CONTACT Color...
I have a Mitsubishi DLP WD-57831 and the dark colors are hazy/milky on the screen, and the lighter colors look normal. There's a 'ghosting' effect which makes it difficult to watch night time/dark scenes. ...
This tv require projection colors lens R,G,B clean and it coolant chemical replacement.Should check for it prices by a tv shop or shops for best prices for it services.
Feb 01, 2011 | Mitsubishi WD57831 Television
Color red seems to be more prominant...than other
I've had this problem with my projection TV recently. I would say your lens/lamp is to blame. It might be time to change it, depends on the last time it was changed, most of the time, the TV will tell you that it needs to be changed, but not always. I think your best bet is the TV lamp.
Oct 20, 2009 | Hitachi Televison & Video
Sony Cybershot DSC-S500 bad photo resolution problem
Electronic shutter in lens mechanism got bad and you need to replace complete lens assembly of DSC-S500 camera.
Of course new lens assembly would cost more then camera worth so best option is to buy new camera.
Jul 23, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
I was just given a samsung hcp4752wx/xaa. The
OK, Its always best to replace the lens assembly if its not preforming well. never dump the fluid. just replace the lens. As for the double images and the misalignment of the blue convergence line, this is caused by a faulty convergence chip that is located on the convergence board. you will need to replace this board in order to restore proper convergence performance.
May 16, 2009 | Samsung Televison & Video
Color wheel
Bid on a used Infocus 4805 on Ebay...So far thet is the cheapest and best fix for a color wheel
Jul 22, 2008 | InFocus ScreenPlay 4805 Multimedia...
I need the color adjusted
1)Remove rear cover..clean RGB lens with soft cloth....
replace cover...........
2)Remove front speaker grill & access panel.....
locate RGB screen control block.....slighty adjust RGB
for best color mix.......check B/W tracking by reducing
customer color control to minimum....does pix look gray ?
touch up RGB screen again.....then increase color to middle
of range.....how is that ?......................................T.
Feb 21, 2008 | Televison & Video
Clothing Accessories Logo
76 people viewed this question
Top Clothing Accessories Experts
Da Doc
Tom Chichester
Bill Boyd
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
