Question about Philips GOGEAR SA6045 MP3 Player
Broken go gear
Ever since I downloaded an update
every time i turn my go gear on it always says "waiting for usb connection" and stays there
  • dreamingm Jun 15, 2008
    my gogear will not support songs from limewire, and when I plug it into the computer, the list on thegogear will not show up. what shat i do??
  • mitran Jul 22, 2008
    I have this exact problem right after following Philips instruction "to the T" in applying the driver update.
    "ever since I downloaded an update
    every time i turn my go gear on it always says "waiting for usb connection" and stays there"
    Philips CSR: if you're monitoring this...what you we do?
  • 8,596 Answers
Taht - your USB port is not connecting with the GoGear. With GoGear connected,
go to Start -> Control Panel --> system --> hardware --> Device Manager - and find the yellow or red exclamation mark under Universal Serial bus Controllers; right click and update driver
if that still does not work, or no yellow exclamation is present, then runa Repair in Philips Device Manager
dreaming - your GoGear will absolutely support songs from Limewire if they are in mp3 format; if the songs do not show up in Windows Media Player, there is a chance that the computer does not recognize your Gogear:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Posted on Jun 20, 2008
Acer Aspire 4736z always shutdown on start-up
Try to update your BIOS. Download it here : http://us.acer.com/ac/en/US/content/drivers
You must need USB Flashdrive to update it. Please make sure that your USB Flashdrive is bootable. Here's the link on how to make USB Flashdrive bootable: http://www.makeuseof.com/answers/usb-drive-bootable/
After you make your USB FLashdrive bootable, copy that BIOS update folder in your USB flashdrive. Please also rename it in simple words so that you can easily access it using command prompt. And after that make your USB flashdrive as first boot priority. Then save and exit.
When the USB flashdrive is now booting.
Type this:
cd (name of the BIOS Folder)
cd DOS
FLASH
then wait it after it finish.
NOTE: Make sure you plugged in your AC adapter.
Hope it helps
Feb 22, 2013 | Acer Aspire 4736Z 4736G 4738ZG 4733Z...
My samsung sew-3030 won't keep the current date
To update firmware you will need a Microsoft Windows based PC and download the latest firmware on this website:
http://www.samsungsecurity.com/product/product_view.asp?idx=6404.
SEW-3030_mr8911isp-nor+spi_For US.zip (2.23MB)
Once downloaded, unzip files to your desktop and do the following sequence:
1st -> RUN file Generic_V1.0.0.0.EXE (USB firmware update driver)
2nd -> connect your wireless video monitor to power adapter
3rd -> press and hold select (enter) button in the middle of the dial.
4th -> connect USB cable to your PC. (screen will blank white instead of black) this is firmware update mode
5th -> RUN firmware update utility mr8911isp.exe , wait to USB connection (status bar will turn green) and show message ASIC: 0301 Device Connected
6th -> Press Update button and wait...
7th -> Update done! disconnect your device and voila! no more date/time issues and another bonus bugs fixed noticed: lower alarm beep volume, menu text size increased for better reading, temperature sensor more reliable
I Hope it help everyone having problems with this baby monitor
Jan 03, 2012 | Samsung Wireless Security Monitoring...
Every time I turn it on, it said ...Jet please wait...Profile requires 4MB free space. then it shuts down Why can I not get it to stay on?
go to rcaaudiovedio.com/downloads and down load the firmware then when you turn your mp3 on hold in you on button and plug it in the usb drive then check the little box on the update i just had the same problem hope this helps
Jan 16, 2011 | RCA S2001 MP3 Player
How can i downgrade my ver 6.10 software psp????
Hello there
Download MPH Downgrader and Firmware version you want(e.g 1.50) to the Windows-based computer. Connect the PSP Slim to the computer's USB port using the USB connector. Transfer the two programs to the main folder of the PSP Slim. Disconnect the PSP Slim from the computer's USB hub when the transfer is complete.
Turn on the PSP Slim. Go to the Settings/USB Connection in the Home menu and select the EBOOT.PBP file in the PSP\GAME\UPDATE update folder. Extract the MPH Downgrader zip file to the root folder of the PSP. Click OK using the X button if you are prompted that this will replace some files.
Go to Photo/Memory Stick in the Home menu. Wait as the screen goes black and numbers appear. Wait two minutes and then press and hold the power switch until the PSP Slim turns off. Release the power switch.
Wait as the PSP Slim turns on and reboots. Go to Game/Memory Stick in the Home menu and select PSPS Update version 1.50. Press the X button to start the update.
Wait as the update finishes and presents an error message. Press the O button to restart the PSP.
Oct 04, 2010 | Sony PlayStation Portable (PSP) Slim...
PS3 cod4 Downloading Game Settings
just wait it out, same thing happened to mine for two days then it stopped happening
Jan 16, 2009 | Sony Playstation 3 (PS3) Console
N73 Software update 4.0839.42.2.1 failed
remove the cable and before update make a backup then download the nokia software updater from here
http://europe.nokia.com/get-support-and-software/download-software/device-software-update# then wait about 15 minutes thats what the softare tells after that your phone is updated if
Dec 21, 2008 | Nokia N73 Cellular Phone
My gogear broken
Reset the player first. If it still occurs, then go to the Philips Device Manager, and attempt both the Repair and the Update (Warning: this will delete all songs off your player). If you do not have the Philips Device Manager, rerun your installation Cd or grab the Device Manager from the Philips website.If it still fails:
Triple Reset for GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player.
Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Jun 10, 2008 | Philips GOGEAR SA6045 MP3 Player
Cannot transfer files
go to http://www.iriver.com/support/down_view.asp?searchProductIdx=73&searchCategoryIdx=1&searchString=new+firmware&page=1&idx=844&tmpSearchProductIdx=&tmpSearchCategoryIdx=&tmpSearchString=
download the updater. unzip the file and run the installation program. after you have install the iriver firmware updater, run the program. it will automatically detect what you need. follow the instructions. if the updater stops at 50% don't worry. wait bout a min or 2 then unplug your T30 and it will update by itself
Dec 07, 2007 | iRiver T30 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
227 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
