Question about Bronica ETR-Si Medium Format Camera
Bronica Etrsi E14 extension tube is locked onto 150mm lens and I can't unscrew it. Any suggestions please?
2 Suggested Answers
SOURCE: Wanting to purchase Focus screen for Zenza Bronica
Keep an eye on ebay as they appear on there occasionally. However, you can't always get exactly what you want and it took me a while before I could find a split image version. All you have to do then is win it!
Posted on Oct 06, 2010
I can't get the lens to focus at all on any close up setting manual or auto. I have been trying to take pictures of flowers and insects with it set to close up and I have tried also with it on manual...
The 70-300mm lens won't focus closer than about 5 feet (1.5 meters). If you need to get closer, there are several alternatives. Here are some in descending order of cost (and picture quality).
A special "macro" or "micro" lens. Some lenses are designed to focus closer than others.
Extension tubes. These are tubes that fit between the lens and the camera body. By putting more distance between the camera and the lens, the focus point moves closer to the camera.
Close-up lenses. These are like filters in that they screw onto the front of the lens, but act like a magnifying glass.
Sep 04, 2011 | Nikon AF 70-300mm f/4-5.6 ED Nikkor Lens
Non availability of LR 44X4 battery for etrsi
They are still easily available online.
Here's one supplier that I regularly use. Even if the supplier is no use to you, you'll see the many other model numbers for the same battery.
Aug 16, 2011 | Bronica SQ-Ai Medium Format Camera
Inherited bronica etrsi camera, removed lens and now cant get it back on, dont have manual, please can you advise. thanks barb.
A. To attach the lens to the main body, align the red dots on the lens
and the main body and then insert the lens fully into its mount.
Rotate in the counter-clockwise direction until it stops, with an audible
click, which will indicate that it is securely locked.
http://www.tamron.com/assets/pdfs/ETRS.pdf
Aug 20, 2010 | Bronica Cameras
May 06, 2010 | Bronica ETR-Si Medium Format Camera
Which 120 backs & lenses for my ETRSi do I buy?
All ETR backs work with all ETR cameras except the ETR-C, which only uses the inserts. The early backs have a single latch and a winding key. The middle ones have double latches and a winding thumb wheel. The Ei backs have double latches and a winding crank like a 35mm has. The Ei backs also have a locking dark slide to prevent accidental film exposure wnen the back is off the camera. All inserts work with all the back frames. I the used market you will find them in any combination (frame, insert & darkslide).
I am aware of three series of lenses: MC, EII and PE. They all work fine with any body.
Jun 14, 2009 | Bronica ETR-Si Medium Format Camera
Bronica AE II E Finder Owners Manual
Since I never use a TTL flash with my Bronica's, I'll give you my suggestion for a great solution. Using your TTL Metz flash, (make sure you've connected the TTL cord for Bronica ETRsi) take 8 shots at different apertures on A (Automatic), then take 8 shots at different apertures on M (Manual). I realize this will waste one 120 roll of film, but one negative will stand out as your perfect exposure. Yes, whenever you reduce the ISO in half, your basically overexposing the film by one f/stop. Just remember that this overexposes everything your shooting from foreground to background. With flash, this may cause your highlights to wash out, but any good lab could print for the highlights and make the background go darker. I used to shoot Vericolor at ISO 125 instead of it's rated ISO of 160.
Fotobean
Jan 21, 2009 | Bronica ETR-Si Medium Format Camera
Like to fit my bronica fisheye p e into nikon f 5 camera
The lens you're refering to is the Fisheye-Zenzanon-PE 30mm, yes? As far as I'm aware no Bronica ETR > Nikon F adaptor has ever been made, and if one was to be it would be rather cumbersome.
You're probably better off selling it and using a Nikon Fisheye-Nikkor 16mm 1:2.8 in its place.
Oct 25, 2008 | Bronica PS Zenzanon (1.4x) (bq1275) Lens...
Lens does not lock into 50mm position........only to 60mm
It problably a loosen tiny piece inside the barrels. Do not attempt disassembly, you can ruin the less. In NY you can get the repair information in BH.
May 15, 2008 | Sigma APO 50-500mm F4-6.3 EX DG/HSM Lens
Bronica ETR-Si Medium Format Camera Logo
200 people viewed this question
Top Bronica Photography Experts
Tony
Tony Parsons
Tony Parsons
Are you a Bronica Photography Expert? Answer questions, earn points and help others
