Question about Whirlpool Duet GHW9150P Front Load Washer
Ghw9150pwo door lock fault - Whirlpool Duet GHW9150P Front Load Washer
    President:
  • 2,468 Answers
A faulty "Wax-Motor" that they are called on these door locks that actually assists in the movement of the mechanism to lock the door is bad,this is quite common,also carefully check the wiring to the wax motor from the control board,and also carefully inspect this control board for 2 burned components a resistor #R-11 and a component called a Triac next to it,and the underside of the circuit board for signs of burns as when this wax-motor goes bad it shorts out the triac and burns the associated resistor R-11next to it,if you have any error codes,sometimes unplugging the unit will clear the codes,if these ideas won't help in your query,and the door is still in the locked position with clothes inside the washer,remove the top,then the control panel and there is a cable to manually pull to release the door....good luck and thank you,please rank.rate this info if it assists you.........daniel
Posted on Nov 07, 2010
I was trying to fix the door lock problem myself on my Whirlpool Duet Washer GHW9150PWO and I pushed the door lock mechanism down with a screw driver and it locked into place. Of course the door won't...
Did the screw driver make it out? UNPLUG THE WASHER There are 2 screws at the top of the washer that hold the top cover on. remove the screws and SLIDE the top cover back off the washer. This should expose the door lock assembly, down the right side of the door. There is 1 or 2 screws that need removed and then there is enough wiring that you should be able to pulll the switch where you can work on it.
Now here's the hard part. What probably happened was that the actuator was popped out of its cradle, possibly losing its spring tension. There are clips on on half of the plastic covers(2 halves snapped together). VERY carefully separate the assembly watching for a loose or shooting spring popping out of the covers. If the spring is still on the acauator arm, and hooked in place, good. carefully put the arm back in its cradle. hopefully it snaps in so reassembly is MUCH easier. Simply snap th e assembly back to gether. test the arm with your screw driver to make sure it is springy. Re install the lock where you removed it from the door area. Good Luck.
Jan 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Duet whirlpool ghw9150pwo
Press & hold the button on right of panel 'end of cycle' for 3 seconds, the light will go off. Child lock. <It will come on again if you dont vote me nice!!>
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Controls Locked - How to Unlock?
These are seperate problems, F 02 on whirlpool is a drain issue, this is were you need to remove the three hex screws on the kick panel below the door and using a bucket remove the cleanout on the pump and drain what water comes out and remove the filter and check the pump for damage. The other problem is a duel feature button that needs to be held for 3 seconds to unlock, I am fuzzy on the location, look carefully for the writing blends in with the panel.
Sep 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GHW9150PWO Whirlpool duet
take bottom panel under door off there 3 screws you 'll need a star tool reach on the right hand side there is a yellowgreen strap pull it and door will come open
Aug 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer GHW9150PWO Have F11 and DL errors. Have replaced the door lock 2 x and still have same error messages.
Well du is a door lock error but it can also mean an error with communication to the main control board or ccu. f11 is also a communication error in either the ccu or the mcu ( motor control board)......easiest thing to try is to unplug all your connections to the ccu and plug them back in and try it again.....sometimes a wire harness just may be loose....if that dosent work I would look at replacing the ccu ( central control unit )
Jul 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Ghw9150pwo code
you got a door lock (dl ) issue, can be caused by a bad door lock, but can also be triggered by a baad CCU (located under main top assy.. might have also have a wiring problem leading to the lock assy "popped "off by chance.
Mar 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150PWO
You must press in the control lock for a few seconds to disengage it I believe. Try unplugging and replugging the the unit if that doesn't work.
Dec 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
42 people viewed this question
Sal De
Marvin
Marvin
jimorris77
