Question about Optoma MovieTime DV10 Multimedia Projector
How do you get inside the Optima DV10?
I have taken the screws out of the bottom and top and canot get inside? I'm afraid to pull but any help is appreciated.
  • 1 more comment
  • smste1 Jul 03, 2008
    I have the same issue.
  • kedonley Nov 12, 2008
    need to replace the colorwheel. How do I get inside?
  • foot44 Nov 27, 2008
    I want to check on my right speaker (no sound) and i can't open the top of the DV10 even though i unscrewed the bottom screws and the screws in the dvd reader
    Problem Solver:
  • 5 Answers
Remove the two screws in dvd player and dvd player with stop and play buttons unclips
Posted on Jun 28, 2011
  • Dan Johnson Sep 16, 2011
    rewrite for above.
    " Open the DVD cover & Remove the two screws on left & right side of the player.
    gently lift the open DVD lid and pull towards the back of the machine to pop player out of case.
    - - be careful not to damage the delicate ribbon and 3 plug connectors. - -
    Problem Solver:
  • 8 Answers
I have the 800 number and the part no. Contact me for more info
Posted on Aug 08, 2008
  • Optoma MD Aug 08, 2008
    There are a couple of hidden screws. I have a mpg of me opening it.
How to remove the cover of the Swingline 48209 Optima 45
The Optima stapler does top does not remove. To reach the inside of this stapler you have to "pull it in half". Do so at your own risk!
Aug 29, 2013 | Swingline 48209 Optima ® 45 Electric...
How to remove my LG window AC's cover?
You will need to lift up the filter cover by lifting the grill door . Inside the grill is found the screws for fitting the front grill. removing the filter, remove screws of the grill inside will make the grill come off. Do not pull out but there is a latch on the top that the grill has to be lifted up and taken out. Some models have screws on side and must be taken out before the panel is pulled
Aug 31, 2010 | Heating & Cooling
Access motor
Your dryer and motor can accessed a couple different ways depending on the make and model:
1. Can be the Top (remove 2 screws near filter-pull) can slide a putty knife and screw driver and pop the top off.
2. Also, the Door must be taken off to access the motor (Screws on inside of door)
3. Bottom - panel comes off by sliding a putty knife or screw driver and dis-engaging.
After intially opening the dryer cabinet; you will most likely need to remove the front door by removing 2 screws located at the inside top corners (1/4'). ** Be sure to turn off power to unit before opening and servicing.
Whats the problem? Humming noise? Not tumbling/turning? How old? What make?
Jan 27, 2009 | Dryers
Microvent is coming loose on the bottom of mounting.
Generally, these units are held to a backing plate with a pair of screws that are accessed by removing the vent plate above the door. There are a couple of Philips screws. Inside...at each end, there is a slot head screw head on a rod. Support the unit and back these screws out. The unit will then pivot from the bottom away from the wall. Detach it and then repair the issues with the hold bracket. Warning: these units are heavy!
Dec 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool washing machine agitator removal
my whirlpool washing machine's agitator bottom is working but the top is not. How can I fix this myself?
Thank you,
Ann
Nov 24, 2008 | Estate TAWX700JQ Top Load Washer
Getting projector open to replace color wheel
You need to open the top lid of the DVD player and you'll notice 2 more screws. Those need to be taken out. Then the lid will lift off the base. You'll then need to undo a couple of the wires to completely remove the lid. After this, you will have to remove the silver lid inside to gain access to the color wheel. It's pretty simple. Assembly is reverse.
Oct 15, 2008 | Optoma MovieTime DV10 Multimedia Projector
No disc error
email me and i will send you hack to solve problem
kakool@talktalk.net
Jun 17, 2008 | Optoma MovieTime DV10 Multimedia Projector
Optima movie time DV10 not recognizing disc and making clicking sound
I have the very same issue. The dvd player makes a clicking sounds, spins, then stops...no disc. I have tried cleaning it and have also tried new dvds.
Mar 01, 2008 | Optoma MovieTime DV10 Multimedia Projector
Eureka optima 431A
Belt number is 74376, there should be screws on the bottom, take those out and the top comes off, or the top and bottom come apart. You will want to clean evrything so the brush roll will roll easily.
Dec 18, 2007 | Eureka 431A Optima Bagless Upright Vacuum
My Unishere 1 modelpe50sp Mic
if you unscrew the top part, gte a screw driver and down at the bottom where the XLR goes in theres a screw, if you undo this the insides should simply slide out
Sep 12, 2007 | Shure Unisphere 565 Microphone
Optoma MovieTime DV10 Multimedia Projector Logo
162 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
