Question about Northstar Generator 20 Hp, 13,000 Watt, Gasoline
Can it be routed the exhaust gases to a 4 or 6 inch header and run it to an enclosed greenhouse for heat ?
  • 7,733 Answers
Yel if no human will be at site.
Posted on Nov 08, 2010
What is the efffect of green house?
The greenhouse effect is a natural process that warms the Earth's surface. When the Sun's energy reaches the Earth's atmosphere, some of it is reflected back to space and the rest is absorbed and re-radiated by greenhouse gases.
May 15, 2017 | Cars & Trucks
I have a problem!my 2005 vento zip r3i turbocam scooter is getting fire and gas but it dose not want to run? an u please help me?
It has to start if it's sparking & getting fuel. Maybe the engine is not breathing properly, is the air filter blocked? Also try loosening the exhaust at the head, often the silencer becomes blocked with burnt two stroke oil & exhaust gases can't escape. By loosening the two header bolts/nuts, it lets the gases out. This is not a fix but merely trying to determine what the problem is.
Dec 16, 2014 | GAS Motorcycles
I can't find the converter on mywinnabago moter home
There are a few converters on vehicles, to which are you referring, a torque converter or catalytic converter? If you are looking for the torque converter it is inside the bell housing of your transmissions, where the transmission bolts to the engine. The torque converter is basically a clutch for an automatic transmission. If it your catalytic converter, they are always in the exhaust system and normally close to the end of the manifold. If you are looking at your engine from the underside of the vehicle, you will see exhaust headers that are bolted onto the sides of the engine. there will be two in any v-series engine (v8), and many I6 engines. The headers converge to turn 8 pipes into 1 or 2, so mufflers can be used to quiet the exhaust. Depending on the year of the vehicle, it may have several catalytic converters. I have seen in some cases catalytic converters in the actual headers before the flange to the rest of the exhaust system, but this is rare. I am not familiar with your vehicle specifically, but generally the catalytic converters are close to the engine because they need temperature in order to do their job, which is to burn excess hydrocarbons after they leave your engine's cylinders, thus lowering greenhouse gas production. My best guess is that the catalytic converter is immediately after the exhaust headers in the main exhaust system. Just in case you don't know what you're looking for, the catalytic converter will be sort of football shaped and will have a sheet metal heat shield covering it if it hasn't been knocked off. I hope this helps.
Oct 09, 2013 | Vehicle Parts & Accessories
Crown Capital save the earth management, what causes global warming?
Scientists think that Global Warming is caused by the gases produced when humans burn coal, oil, etc. These gases trap the sun's heat in the atmosphere. Carbon dioxide is made when these fuels are burned. Percentage of carbon dioxide in the atmosphere has been rising as result of human industries since the Industrial Revolution.
Heat absorbing gases are known as greenhouse gases. The warming of the atmosphere is called the greenhouse effect. Humans add extra greenhouse gases, which gains a bigger chance in the greenhouse effect. The increase causes global warming.
Apr 03, 2013 | Air Purifiers
We have a heating/cooling system (Bryant) located outside. The heating unit runs on propane gas. The unit exhausts hot air while running. I assume this is exhaust from the burning gas. I have wondered...
Carbon monoxide would not be good for the environment of an enclosed greenhouse.
A good analogy would be venting your car exhaust into the greenhouse.
Sep 06, 2011 | Heating & Cooling
Need location of low side suction side pipe location. in order to charge AC system
Few inches from compressor
Have to remove all the plastic shields
You shouldn't work on a/c unless your trained
You have no way of knowing how much refrigerant
you need & needing any, means you have a leak
that has to be fixed first,unless your into poluting
the atmsphere & adding to greenhouse gases
Aug 11, 2011 | 2002 Lincoln LS
My suzuki backs frie on trying to start.?can the problem be
It sounds as though there is a hole in the exhaust causing air to get in, when mixture is a bit too lean air will get in and fire as gases build up in the header pipes. Check for leaks in the exhaust and also intake, lean mixture is the problem
Feb 14, 2010 | 1992 Suzuki GSF 250 Bandit
Im wanting to put headers on my 96 z71. What should i do with the tube running from the exhaust to front of intake
You need it! Thats part of the EGR system, If it doesn't have it then It will run like S***! They make headers that have provisions for the egr systems. That's the route that you need to go if you really want headers!
Nov 01, 2009 | 1996 Chevrolet K1500
Loud Exhaust leak
I wouldn't run it like that until you get those bolt holes cleaned out. The exhaust gases will leak out and burn/melt stuff nearby and you run the risk of scorching an exhaust valve requiring a head-job. And a head-job isn't as much fun as it sounds like it would be.,,
Nov 10, 2008 | 1986 Laverda GS 125 Lesmo
Engine problems
If the exhaust manifold is running that hot, it means that combustion is taking place there instead of in the cylinders where it belongs.
It may be a fire hazard as well since EGRs are designed to withstand the high heat of the exhaust manifold and if it is hot enough to damage the EGR, it is hot enough to cause other problems.
If you drive it at night, look under the hood to see if the exhaust manifold or header are glowing.
By 'siloined' I think you meant to write 'solenoid' and to my knowledge, there is no such animal.
The EGR is controlled by engine vacuum and allows a small amount of exhaust gases to be routed to the intake which is supposed to decrease the amount of noxious gases the engine produces.
It is a mechanical device whereas a solenoid is electrical.
Unfortunately, it also can reduce gas mileage by a significant amount; 5-10% in my experience, even when operating as it should.
I don't know why running out of gasoline should cause the problem but it sounds as if your ignition timing is way late and I can't imagine that the truck runs as before and is probably eating gasoline too.
I suggest you have the ignition timing checked soon since you may destroy the catalytic convertor too (if it isn't already dead) or set fire to grass or weeds.
Jul 05, 2008 | 1993 Dodge Dakota
Northstar Generator 20 Hp, 13,000 Watt, Gasoline Logo
50 people viewed this question
Top Northstar Electrical Supplies Experts
John Trevino
Jim London
Jim London
Are you a Northstar Electrical Supply Expert? Answer questions, earn points and help others
