Question about Northstar Generator 13 Hp, 8000 Watt, Trifuel
Does it have an exhaust pipe ? - Northstar Generator 13 Hp, 8000 Watt, Trifuel
  • 44 Answers
All generators have exhaust mufflers . But they do not have extentions to add to the exhaust . You should never modify exhaust systems on generators .
Posted on Nov 07, 2010
I need to remove the exhaust manifold on the right side of a 94 4.9l engine in a cadillac deville. It has a broken bolt in the exhaust. What is involved in removing the manifold?
I suggest you use all new exhaust manifold hardware and torque new bolts to 20 Ft Lbs.
4.5L and 4.9L Engines
RIGHT
Disconnect the negative battery cable. Remove the air cleaner. Remove the exhaust crossover pipe. Disconnect the oxygen and coolant temperature sensors. Remove the catalytic converter-to-AIR pipe clip bolt. Remove the upper manifold-to-cylinder head bolts. Raise and safely support the vehicle. Disconnect the converter air pipe bracket from the stud and remove the converter-to-manifold exhaust pipe. Support the engine cradle with screw jacks and remove the rear cradle bolts. Loosen the front cradle bolts and slightly lower the Engine cradle. Remove the remaining exhaust manifold-to-cylinder head bolts, the AIR pipe, and the manifold. Clean the gasket mounting surfaces.
To install:
Install the exhaust manifold and replace the AIR pipe. Tighten the manifold mounting bolts to 16-18 ft. lbs. (21-24 Nm). Install the manifold-to-converter exhaust pipe and replace the converter air pipe bracket to the stud. Raise the Engine cradle and install the rear cradle bolts. Tighten to 75 ft. lbs. (102 Nm). Lower the vehicle. Replace the upper manifold-to-cylinder head bolts. Replace the converter air pipe to AIR pipe clip bolt. Connect the coolant temperature and oxygen sensor connectors. Replace the exhaust crossover pipe. Replace the air cleaner and connect the negative battery cable. Start the Engine and check for leaks.
Mar 28, 2017 | Cadillac Cars & Trucks
Torque spec on exhaust manifold for 2000 yukon xl
EXHAUST MANIFOLD BOLT TORQUE 2000 GMC Truck Yukon XL 1500 2WD 5.3L SFI 8cyl The Exhaust Manifold Bolt Torque
Exhaust manifold bolts (first pass) 11 Lb/Ft.Exhaust manifold bolts (final pass) 18 Lb/Ft.Exhaust manifold nuts 39 Lb/Ft.Exhaust manifold stud 16 Lb/Ft.Air injection reaction (AIR) Pipe to exhaust manifoldnuts 18 Lb/Ft.(AIR) Pipe to exhaust manifold studs 4 Lb/Ft.Exhaust manifold AIR pipe studs 4 Lb/Ft.Note:To torque bolts and nuts, start in center usingcrisscross pattern working outward.
May 07, 2011 | GMC Yukon XL Cars & Trucks
My husband and I are trying to get to our thermostat to change in my 2002 rendezvous, but there is a metal pipe in the way that we can't figure out how to remove. just behind the pipe, is a metal plate...
Hello vocalviixen,
The pipe that you referred to is the exhaust crossover pipe. Below I've included removal and installation instructions.
Also, the procedure for bleeding the coolant system is critical; if you need those instructions please post the question.
REMOVAL PROCEDURE
1. Disconnect the battery ground (negative) cable.
2. Remove the throttle body air inlet duct.
3. Drain the coolant from the cooling system.
4. Remove the inlet radiator hose from the engine.
5. Remove the thermostat bypass pipe.
6. Remove the exhaust crossover heat shield bolts.
7. Remove the exhaust crossover heat shield.
8. Remove the exhaust crossover pipe studs/nuts.
9. Remove the exhaust crossover pipe.
INSTALLATION PROCEDURE
1. Install the exhaust crossover pipe.
2. Install the exhaust crossover pipe studs/nuts.
3. Tighten the exhaust crossover pipe studs/nuts to 18 lb ft.
4. Install the exhaust crossover heat shield.
5. Install the exhaust crossover heat shield bolts.
6. Tighten the exhaust crossover heat shield bolts to 89 lb in.
7. Install the thermostat bypass pipe.
8. Install the inlet radiator hose to the engine.
9. Fill the cooling system with engine coolant.
10. Install the throttle body air inlet duct.
11. Connect the battery ground (negative) cable.
Regards,
netvan
Mar 14, 2011 | 2002 Buick Rendezvous
How to replace the exhaust manifold ring in my 91 Toyota Tercel
There is a bracket that attaches the exhaust pipe to the engine block. Remove the 2 screws that hold
that bracket on. I think they are 12mm heads. Detach the 2 exhaust manifold to exhaust pipe screws,
the screws have 15mm heads. A 15mm deep socket is best. After you remove those 2 15mm screws you can pull the exhaust pipe down, remove the old exhaust flange and put the new one on.
Rettach the exhaust manifold to pipe screws, and reattach the bracket and youre done.
Mar 07, 2011 | 1991 Toyota Tercel
I have a mazda tribute 2002 .and i hit a big dip and now under the engine sounds like a go kart.it looks like the exust pipe next to the oil filter has poped off
It sounds like you cracked/broke your exhaust pipe. Best thing to do is find an exhaust shop that can go in and weld the pipes back together. If you broke one of your exhaust hangers and the pipes are lower than they should be they can take care of that for you too.
Sep 22, 2010 | 2002 Mazda Tribute
The pipe is making loud shaking noise
which pipe, i assume you are referring to an exhaust pipe, do u have a loud (more than usual) exhaust sound, if so, the exhaust pipe is cracked or split, if not, then the exhaust hangers (mahe of heavy duty rubber) are split/broken, causing it to shake OR is the engine shaking as well, or just the exhaust, too many questions, need to specify
Jun 11, 2010 | 1993 Oldsmobile Cutlass Ciera
Where do we find the o2 sensor to replace it on 1996 ford explorer v-6 4.0
Item Part Number Description 1 52 Exhaust Inlet Pipe 2 N803420-S2 Exhaust Manifold-to-Inlet Pipe Bolts
(4 Req'd) 3 5E212 Three Way Catalytic Converter 4 5230 Muffler 5 N620482-S2 Exhaust Inlet Pipe-to-Converter Nut
(3 Req'd) 6 5B266 Exhaust Converter Inlet Pipe Gasket 7 N620481-S2 Nut 8 5E269 Exhaust Converter Frame Bracket 9 N620481-S2 Nut 10 5260 Exhaust Outlet Pipe Frame Bracket 11 5E269 Exhaust Converter Frame Bracket 12 39006 Screw and Washer 13 5E241 Exhaust Converter Outlet Gasket 14 5G215 Exhaust Pipe Flange Hold Down Spring 15 N802641-S2 Nut and Retainer 16 — Rear Heated Oxygen Sensor (HO2S) A — Tighten to 34-46 Nm
(25-34 Lb-Ft) B — Tighten to 20-25 Nm
(15-19 Lb-Ft) C — Tighten to 34-46 Nm
(25-34 Lb-Ft)
Apr 03, 2010 | 1996 Ford Explorer
How do i change my thermostat on my 2001 pontiac aztek. also how do i remove the crossover exhaust pipe to get to the @#$%^ing thing?
Exhaust Crossover Pipe Replacement
Removal Procedure
89160026
  1. Remove the exhaust crossover pipe studs/nuts.
  2. Remove the exhaust crossover pipe.
  1. Remove the air cleaner and duct assembly.
  2. Drain the coolant until the coolant level is below the thermostat.
  3. Remove the crossover exhaust pipe.
  4. Remove the radiator hose from the thermostat housing.
  5. Remove the thermostat housing bolts and clean any sealer from the bolt threads.
  6. Remove the thermostat housing and gasket.
Removal Procedure
89153578
Dec 11, 2009 | 2003 Pontiac Aztek
How to replace the water pump on 1993 oldsmoblie achieva.
2.4 enigine is the harder of the 3 enignes. it will need a timing chain to be removed and a coolant tube in the back of the engine to be removed. this job on the book calls for almost 7 hours.
if its 3.3 or 3100 its alot easier.
3100 is just 4 10mm pulley bolts and 5 or 6 small 8mm water pump bolts.
3.3 is alittle more work, but same concept as 3100 engine. more owkr only cause its in a tighter area.
good luck,
michael
Apr 29, 2009 | Oldsmobile Achieva Cars & Trucks
05 susuki forenza
Removal Procedure
1. Disconnect the negative battery cable.
2. Drain the engine oil from the engine crankcase.
3. Remove the exhaust flex pipe retaining nuts from
the exhaust manifold.
4. Remove the exhaust flex pipe retaining nuts from
the catalytic converter or the connecting pipe.
5. Remove the exhaust flex pipe.
6. Remove the oil pan flange–to–transaxle retaining
bolts.
7. Remove the oil pan retaining bolts.
8. Remove the oil pan from the engine block.
Cleaning Procedure
1. Clean the oil pan sealing surface.
2. Clean the engine block sealing surface.
3. Clean the oil pan retaining bolts.
4. Clean the oil pan attaching bolt holes in the engine
block.
5. Clean the oil pan scraper.
Installation Procedure
1. Coat the new oil pan gasket with sealant.
Important : Install the oil pan within 5 minutes after applying
the liquid gasket to the oil pan.
2. Install the oil pan to the engine block.
3. Install the oil pan retaining bolts.
Tighten
Tighten the oil pan retaining bolts to 10 NSm (89 lb–in).
4. Install the oil pan flange–to–transaxle retaining
bolts.
Tighten
Tighten the oil pan flange–to–transaxle bolts to 40
NSm (30 lb–ft).
5. Install the exhaust flex pipe.
6. Install the exhaust flex pipe retaining nuts to the
exhaust manifold.
Tighten
Tighten the exhaust flex pipe–to–exhaust manifold
retaining nuts to 35 NSm (26 lb–ft).
7. Install the exhaust flex pipe retaining nuts to the
Tighten
Tighten the exhaust flex pipe–to–catalytic converter
or connecting pipe retaining nuts to 35 NSm (26 lb–ft).
8. Connect the negative battery cable.
9. Install the oil pan drain plug.
Tighten
Tighten the oil pan drain plug to 35 NSm (26 lb–ft).
10. Refill the engine crankcase with engine oil.
Jun 14, 2008 | 2005 Suzuki Forenza
Northstar Generator 13 Hp, 8000 Watt, Trifuel Logo
117 people viewed this question
Top Northstar Electrical Supplies Experts
John Trevino
Jim London
Jim London
Are you a Northstar Electrical Supply Expert? Answer questions, earn points and help others
