Question about Microwave Ovens
Please could you tell me what power you need to run the oven
    Brigadier General:
  • 8,909 Answers
As a rule of thumb, mutliply the total power consumed by the appliance, (see manufacturers label) by 1.5. That means a 1kW oven requires a 1.5kW supply.
Power in Watts = Voltage X Current (Ohms Law).
Current therefore is equal to Power divided by the Voltage.
In the UK that would be:
1500Watts divided by 240Volts equals approximately 6Amperes.
In the States it would be:
1500Watts divided by 110Volts equals approximately 14Amperes so much fatter cable will be required!
Hope that answers your question.
Posted on Nov 07, 2010
Change out a bad heat element in a oven
Not a good idea. Make SURE power is disconnected from the oven prior to working on it.
...and PLEASE tell me you're not attempting to change the "element" in a MICROWAVE oven (based on the category you chose)...
May 12, 2015 | In Microwave Ovens
My sensor touch buttons don't work....any ideas why?
With Power on Microwave There is Light Blinking It Means Is Normal Power Supply Supply Problem,Not Reaching Front Panel Power Supply
Feb 07, 2014 | LG LMV2015ST Microwave Oven
Lamona HJA7020
FIRST REMOVE THE POWER CORD FROM POWER SOCKET AND OPEN THE COVER OF MICROWAVE OVEN REPLACE THE BULB
Jan 04, 2014 | Microwave Ovens
Can you tell me what code F4 means? model
Code F4 means you need to repair the line to or replace the oven temperature sensor. The line typically runs from the display to the back of the oven, you'll have to trace it yourself. The oven sensor should be mounted to the back of the oven lining (Obviously on the inside) by two screws. Disconnect the power from the unit and unmount the sensor to check it, you should have around 1080 ohms of resistance but first you'll have to get that annoying plastic housing of wires through the mount hole and disconnect it so you don't lose it inside the oven. If you don't see screws from the inside of your oven than you'll have to remove the back panel to access them, but this may be a good thing as you don't have to worry about fiddling the plastic connector piece into the oven. You're measuring the resistance from one lead to the other inside that plastic housing, again at around 1080 ohms in a 70 degree environment. If you're way off, or 5 - 6 ohms off, you'll need to replace the sensor. If the error occurs while cooking you can also run the oven hot, turn off and disconnect the power and take your measurements again. If they read the same your wiring harness should be okay and replace the sensor.
Oh and btw, you'll most likely have to splice the wires to adapt to your new sensor they're never the same.. not in my experience lately anyway.
Apr 25, 2010 | Amana MVH230 Microwave Oven
Power comes on but at the end of the cycle nothing is cooked
Please check the door safety interlock switches. These are the micro switches inside the case that tell the oven the door is closed. When you open the door while the oven is running, there is an arc on the contacts in the switches and they burn a little. After a while, the switches are no longer able to report the door is closed. When the door is not closed, the heat is not turned on. Forget what you know about the door being closed.
Check the switches.
Thanks for your question at FixYa.com
Feb 20, 2010 | Maytag MMV5000 Microwave Oven
My sharp R-798 has stopped heating food and the turntable no longer rotates?
Please check your door safey interlock micro switches.
If you need help with this, please let me know.
What frequently happens is because you probably open the door while the oven is running, (like most of us do) the little micro switches get burned and eventually cannot tell the oven that the door IS, indeed, closed. When the door is "open" (forget that you know the door is closed - the MACHINE needs to know it too) the oven will not turn on the heat.
If you need more info, let me know please.
Oct 18, 2009 | Microwave Ovens
I have a 10 year old MH7130XE Whirlpool microwave oven. The oven and key pad both work, and the oven heats just fine. The problem is the oven begins running as soon as you open the door...without pushing...
I'm assuming you mis-typed and meant the oven begins running when you SHUT the door and stops when you OPEN the door. Please tell me this is what you meant! If the microwave oven runs with the door open, UPLUG IT IMMEDIATELY AND DO NOT USE IT!!!
If the oven begins running without pushing the start button then the controller is bad or the Start button is worn out and making contact without pushing it. (Most likely it is your controller.) Generally, it is not worth the cost to replace the controller on a 10 year old microwave. Probably time for a new one.
But if you want, you can call Whirlpool and see what they suggest at 800-253-1301.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | Whirlpool MH7130XE Microwave Oven
My Goldstar 1500 Micro wave no power
HEating element popped and needs to be replaced. Also check for discoloring on the sides and back of the panel. This will also tell you what is going on. Make sure that the power cord did not break either and that it is fully attached where it is supposed to go
Jun 03, 2009 | Goldstar MV-1501 Microwave Oven
REPLACING LIGHT BULB
i have a cookwork microwave the light stoped working
Sep 16, 2008 | Microwave Ovens
Siemens HF 87960 GB Microwave/Combo Oven
Please, Can somebody tell me where can I get one of this oven??? Thanks Andy
Dec 08, 2007 | Siemens HF87950GB Convection Microwave...
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
