Question about Yamaha RX-V2092
Recently, lightning struck close to the house and caused a power surge. The receiver was in standby mode, since then, the unit will not turn on. Is there a breaker or fuse that can be reset/replaced?
  • 6,826 Answers
If the unit doesn't operate properly due to a power surge or lighting strike, sometimes the unit should be unplugged for a minute, and then replugged in to reset the internal microcomputer which has been frozen.
The manual did not say that there was a fuse or circuit breaker, specifically, on the unit.
I looked at the back and there don't seem to be any fuses that can be replaced.
Also check that the ac power cord is plugged in properly.
If the above doesn't solve the problem, then try the service link below:
http://usa.yamaha.com/dealers/service_locator/index.html
Good luck on this repair.
Posted on Nov 07, 2010
How do I diagnose and fix an LCD HDTV whose screen will not come on because of possible lightning strike?
needs circuit testing doubt you would actualy be able to see any damage to circuit boards doesn't take much of a power surge to knock one out tv engineer needed
Aug 25, 2015 | Televison & Video
I need an expert. I've had 3 AC men out and all 3 say they've been in the business 20-30 years and have never seen a thermostat blow up and set fire.
Trying to get your warranty to work by using statements found on fixya isn't a good idea. However, if there were no other power failures elsewhere in the house, and there were no meteorological events in the area, it was unlikely a power surge nor lightning. However, a short in the unit ITSELF could easily cause this damage, and would also explain the unit's intermittent operation.
Aug 04, 2015 | Heating & Cooling
How do I fix error message C3452?
It is most likely your fusing unit. Part number 9J06 R706 00 .
If you have had any power surges recently, meaning lightning struck your building and something else was hit. It could be the main board. You need to put a surge protector on this machine either way.
Oct 03, 2014 | Konica Minolta Office Equipment & Supplies
PS3 Power Surge.
Get a surge protector for your most loved systems, that way the worst case scenario is you will need a cord replacement. Unplugging it when it's not in use may also cool it down.
Jul 24, 2013 | Sony Playstation 3 (PS3) Console
Lightning struck my Bravia
your tv is shot ,im sorry to say that but its burnt
Jul 29, 2012 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
Got a 47 inch flat screen sanyo. tv will power on get a picture for about 10 sec and then turn off. transformer outside of house was struck by lightning
Sound like you had a power surge that has taken out the invertoer power supply capacitors...these are electrolytic capacitors that will be taken out by surges(it's a veryu common problem)..you can take the cover off the back and look for the power supply board(it will be the one with the ac line cord going to it...look at the cylindrical components on the board to see if they look bloated of have some fluid leaking out of them..this would indicate a bad capacitor...if you don't want to take the unit apart you can take to a shop and have them look at it...note: If you own your home and you have homeowners insurance..it should cover the tv if you had a close lightning strike...just a suggestion
Jan 17, 2011 | Sanyo Televison & Video
Nothing works.
Remote receiver got fried by the voltage spike. If you have pull chain controls as well, you can remove the receiver and possibly be able to save the fan, but the capacitors, may have also been fried. If the capacitors are fried, then most likely the motor experienced some seriously high voltage too, which would mean I would replace the fan. I assume you have had the house's wiring inspected? If lightning struck the house and killed the fan, then it likely ALSO damaged other electrical components. If the lightning struck your power transformer and not your home directly, you may can get the power company to pay for this ceiling fan as the transformer is supposed to have a lightning arrester on it.
Mar 31, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
Frigidaire side-by-side stopped working
I would chech the components on the compressor. Take the cover off the compressor power terminals and inspect the relay for damage.The power outage is not a concern but the power surge could definately be the cause. hope this helps.
Jul 28, 2009 | Samsung RS2578BB Side by Side Refrigerator
After my house was it by lightning my Onkyo
If your receiver was connected to any power source and that power source was not a surge protector strip there may be damage to the receiver as lighting travels. Another thing to consider is the fact that many people will put their equipment on surge protectors but the cable is still connected to the TV etc...This is just another avenue for the lightning to get into the home and blow up your system. I always disconnect any cable from my computer and TV. The power source from the wall is also unplugged when there is a storm just to be sure. Surge protectors are limited in their use as well. I don't believe they can take too many lightning hits. It is best to change them out.
Jul 18, 2009 | Onkyo HTR500 Receiver
I have the Onkyo TX-DS656. The problem is that the power is on, but I get no sound. House was struck by lightning and had a bit of a surge. All other functions seem to work just fine. Rumor has it that the...
The unit is in protect mode because a problem was detected in the output section. In all likelyhood, the output transistors have failed or a secondary power supply hs failed. Because this was the result of a power surge, I would suggest that you take this to a sericer and request a detailed repair estimate. This could be as simple as a voltage regulator gone bad to the microprocessor being fried. This is not a problem that can be diagnosed remotely.
Dan
Jun 23, 2008 | Onkyo Audio Players & Recorders
Yamaha RX-V2092 Logo
106 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
