Question about Vehicle Parts & Accessories
Went to hospital parked car came out key fob not working opened key fob two of the sensors had come off.Managed to get it working to get home.went out to car with spare key fob but did not work opened key fob all fine inside changed battery still not working. took battery out pressed open and lock alternitivly put battery back in key fob worked ignition worked tried to lock car with fob wouldnt work and no flashing light,locked car with key.Came back out next day key fob not working but red light is back but can get in car by using key but cant start car as immobiliser is on please help mrs is 8 1/2 mnths pregnant and have no car mot and tax running out.
    Genius:
  • 1,098 Answers
Im not sure there is any easy fix for this so I will just give a little advice.
Can you give me the make and model of the car? and is the alarm and immobilizer a standard factory one? Will do my best to help you once I know the make and model, and the year please.
Regards
Dan
Posted on Nov 07, 2010
  • 2 more comments
  • smudger03 Nov 07, 2010
    its a rover 216sli the alarm/immobiliser is factory fitted standard cheers dan
  • Dan Doherty
    Dan Doherty Nov 07, 2010
    Hi
    Right I thought it was a rover, theres 2 way to do this, firstly you can remove the door panel, quite easy then inside the door near the lock you will see a switch, small black thing, they often cause this issue, pull it out with wires complete so still attached replace the door card then each time you unlock the door with the key you press in the little switch and the car should start.
    Not all rovers have this but it certainly sounds like the right model. the other thing is leave the switch where it is and there is a imobilizer unlock code with comprises of, turn key left hold for 2 seconds, turn right hold for 2 seconds and it goes on like that, you might need to get the number of your ecu and phone rover they will or at least should give you the code to do this. alternatively, I'm just trying to help here, go to honestjohn.co.uk and ask on the forum someone in there will know the excat code for your type of ecu. I am sorry I dont have the specifics but I have had this fault myself and had to get help as well, so this is just advice mate, I understand the predicament so hopefully this will at least guide you in the right direction.
    these are a nightmare but a good Rover expert will know the right way to do it. I know you can disable it somehow. also is it a rover engine or a honda, you will need to know which it is.
    I hope this helps and good luck with the fatherhood. Sorry I don't know more.
    Regards
    Dan
  • smudger03 Nov 08, 2010
    thanks mate will give it a go.Probably been the best help i have had so far. thanks again craig smith
  • Dan Doherty
    Dan Doherty Nov 08, 2010
    No problem, if you need anything else let me know.
    Regards
    Dan
2007 Pontiac Grand Prix when parked if I open trunk a while later the trunk will pop open. Lights flash.
Is this an aftermarket key opener. ? The brain box for this unit is some times mounted behind the left kicker panel by the left foot of the driver. And they get wet from foot water ie snow. Rain. The yr of ur car sounds like this unit could be water damaged. Have a look. Is u see green stuff allover the contracts thats ur issue. As well some times older cars remote fob controller is not isolated from other sigs. Ur truck does it only pop open when parked in one location ie home or work u might be picking up a similar radio req as ur button for truck lid as they have different radio freqs to control different things
Feb 21, 2018 | Pontiac Grand Prix Cars & Trucks
Central locking system not working
Could be your key fob needs a battery, or the electronic sensor is failing to either receive or recognize the signal from the key fob. May want to contact dealer to have fob or sensor checked.
Mar 07, 2015 | Cars & Trucks
When we use our key fob to lock the doors, i know we must use the key fob to unlock the doors to avoid the alarm from going off. Recently I parked in a parking garage at an airport (left key fob at home)...
You should be able to just unlock the door with the key, and even if the alarm is still going of try to start it the key should override the alarm.
Sep 15, 2010 | 2001 Toyota Tundra
All windows on my 2000 S-Type were fully open
some models are supplied with a system that when you press a button on the key fob all the windows go down(to let out very hot air when parked in sun) only chassis no/factory data will confirm if this is fitted.no, you cant buy a key fob to make this work....onboard computer has diagnostics though.
Feb 17, 2010 | 2001 Jaguar S-Type
Neither key fob is working to open the car with
open door. when alarm goes off put key in ignition and turn it on start car. this should disarm the factory alarm.
Feb 08, 2010 | 2005 Chrysler Crossfire
2006 Chevrolet Uplander Parking Lights Stay On
My 2006 Uplander would not shut off the parking lights. I came here for a solution. I saw the answer here, actually the question, and I used the key fob to lock the vehicle. The lights went off. That was a temporary solve. Now, is this a "glitch" or a "feature"?
Sep 04, 2009 | 1996 Chrysler Town & Country
96 buick key fob
press the unlock & lock button @ the same time.Hold down for 30 to 45 seconds.Should reset.
Oct 27, 2008 | 1996 Buick Park Avenue
Vehicle Parts & Accessories Logo
1,434 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
