Question about Hotpoint WMA48 Front Load Washer
How do you replace the bearings in the drum? - Hotpoint WMA48 Front Load Washer
  • Hotpoint Master
  • 3,463 Answers
It involves a complete strip down of washer,literally down to the last nut and bolt.
Some models have one piece tub assy, so it is not possible to change the bearings.
Remove the top cover, and see if the drum is a one piece assy, if it is not, you should be able to see the screws securing the 2 drum halves together, if you cannot see any screws, then the whole outer tub assy has to be replaced, an expensive repair!!!!
tTo change the bearings, the whole tub assy has to be removed from the cabinet, and then the drum has to be split to gain access to the bearings.
Until you get to this stage , you will then be able to determine if the drum shaft is worn, if it is then this will have to be replaced.
All in all a long expensive repair to undertake.
Take my advice, and if the washer is more than 5 years old, then buy a new one.
Good luck.
Posted on Nov 07, 2010
Why is it now squealing when in spin mode
If your dryer is the kind with rotating drums, might be a bearing. You should disassemble it and check if can be replaced
Dryer Repair Replacing the Drum Bearing GE Part WE3M26
Dryer Repair Replacing the Rear Drum Bearing Assembly Frigidaire Part...
Dryer Repair Replacing the Rear Drum Bearing Kit Part 1 GE Part WE25M40
GE Dryer Repair Noisy or Screeching Rear Drum Bearing WE25M40
you can fine more youtube video tutoriala looking in google for terms
Youtube DRUM DRYER
Sep 02, 2015 | Dryers
Spin Cycle is very loud on front load washing machine
See here
How to fit a Bearing in a Washing Machine | Appliance Repair Help
  • If a washing machine is rumbling, and very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Loud noises when turning the drum by hand can also be caused if the drum itself splits, or the spider at the back of the drum has come away from the drum, is corroded or even broken. This would normally be a loud noise on each revolution of the drum whereas the noise when drum bearings have gone is constant all the time the drum is turning. Lifting the drum checking for excessive play can often reveal a broken or loose drum spider which sometimes only occurs at certain points round the drum (the spider has three arms and is bolted to the drum at three points)
From
DIY washing machine repairs (2)
for repairs check
Sep 04, 2008 | Washing Machines
Kenmore 86582800 drum has a high pitched squeak after been on for 5minutes. 1983 model
see this steps and fix it. God bless you
Drive Belt
If the dryer makes noise, the belt may be frayed or damaged. If the belt is damaged, it will make noise every time it travels around the pulleys. The drive belt is a long, narrow band that wraps around the entire drum, then around a tension pulley and the motor pulley.
er
Drum Roller
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers. If one is worn out replace all of them at the same time as a preventative measure.
Drum Roller Axle
Over time the drum roller axles can wear out, causing the rollers to wobble. If this happens the dryer makes noise. If the dryer is making a rumbling noise, check the rollers and axles. If any are worn out, replace them all at the same time.
Blower Wheel
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
Drum Bearing
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
Drum Support Roller & Axle
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers or axles may be worn out. After removing the drum from the dryer, inspect the rollers and axles. If one is worn out replace all of them at the same time as a preventative measure.
Drum Support Bearing
The drum support bearing is at the rear of the drum. If the dryer makes noise check this bearing. If it is worn out, replace the entire bearing.
Drum Slide, Glide, or Pad
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
Drive Motor
Although not very common, if the dryer makes noise the drive motor may be worn out and the motor bearings can become noisy. If this happens the drive motor must be replaced. The bearings are permanently sealed and cannot be lubricated.
Jul 13, 2013 | Dryers
Hi Gene, I have an Electrolux FEX831C30 stacked washer and dryer. the drum in the dryer has completely come loose and has dropped to the bottom of the dryer cabinet. there were two screws in the drum. what...
Good Morning Brian,
The reason the drum has fallen free from the rear is a defective rear drum bearing and that drum bearing that has sheared itself off of the bearing support.to repair that dryer ya would need to replace the bearing kit its part number 5303281153 and would be in stock at your local applince parts store or online at searspartsdirect.com, repairclinic.com, apdepot.com, partselect.com, or apwagner.com
Before replacing the drum the drum bearing you should also inspect the heat element since when the bearing shears off its not that uncommon for the drum to fall onto the heater shroud and also break the heat element
While this Youtube video i have included the link to shows how to replace the drum bearing in a full siz e free standing (not stacked laundry center) dryer the process of how to replace the rear drum beaqring is exactly the same and that video should help ya http://www.youtube.com/user/RepairClinic?v=67hOqSFnX8g&feature=pyv&ad=9033434261&kw=drum%20bearing
Good luck,i hope ya find it very simple to replace that bearing,
GENE
Jan 31, 2012 | Washing Machines
I have a LG washing machine Wm2277hb. it needs outer tub bearings. what is a fair cost for thi service, or can i do it myself?
It would cost about $500 to $700 to replace the bearing. It is a big job because the drum has to be replaced because the bearing may have damaged the drum shaft so it's recommended to replace the drum assembly along with the bearing assembly. If you decide to do it yourself, you will need:
The rear tub assembly which includes the bearings The tub seal Drum assembly
Good luck.
Jul 09, 2011 | Washing Machines
The bearings on my Whirlpool Cabrio WTW6400SW3 make a racket on the spin cycle. The Whirlpool parts diagrams show that to replace the bearings, the entire drum is replaced. I can see one of the bearings...
Yes you can just replace the bearings but be careful. they say to replace the entire drum as the materials they are made out of is not very strong and you can distort or damage the drum when removing the bearings.
Oct 25, 2010 | Washing Machines
My maytag model no.mav4755aww makes a whinning sound at the beginning of the spin cycle
Hi
Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.Since you hear whining it means that the bearing is damaged and the seals on bearing are gone too so it rotates without lubricant. It might be possible to hear whining while you rotate empty drum manually...
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. When the bearings have gone bad, the noise is constant the entire time the drum is spinning.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.Then replacing the bearing is suggested.
Let us know if you want something more else accept the solution.
Thanks for contacting fixya.com
May 22, 2010 | Washing Machines
Washing machine was making a loud banging/tapping niose when the drum was spinning. It doesn't sound too good when turned manually. Is it the bearings and are they easy to fix?
banging may happen due to low load also, as cloths form a ball shape at one place.
otherwise it might be bearing or bearing housing. bearings are very difficult to replace as whole drum need to open. if bearing housing got loose in drum then drum needs replacement, also very costly.
Nov 18, 2009 | Ariston Technologies Washing Machines
WATER LEAK ON REAR OF DRUM AND EXCESS MOVEMENT hOOVER1400 HPB145
If there is water leaking then you need to repalce both bearings and the seal that sits around the drum shaft and protects the bearing. Check the brass collar on the drum support thats sits in the bearing is not worn or grooved.If it is the shaft and/or the drum need replacing too
Sep 22, 2009 | Washing Machines
Drum will not rotate
im confused as to why you think no drum rotation would be caused by bearings. typically worn bearings would cause noisy spin. only if bearings were completely seized would that cause no drum rotation. can you rotate drum by hand? if so bearings are not seized. can you hear motor rotate when you select spin? if not, then likely cause is motor brushes. do these simple tests and get back to me if you want. and bearings are quite difficult to replace on this machine
Apr 26, 2007 | Zanussi F1045W Front Load Washer
Hotpoint WMA48 Front Load Washer Logo
184 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
