Question about Bosch 18 in. SRS43C02 Classixx Slim-Line Built-in Dishwasher
Bosch Classixx dishwasher model SRS55co2GB/09. As the wash cycle finishes there is water on the floor and still in the machine.
  • 1462 Answers
SOURCE: bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Posted on Mar 20, 2007
  • 105 Answers
SOURCE: bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Posted on Feb 24, 2008
ginko
  • 19396 Answers
SOURCE: my bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Posted on Feb 07, 2009
SOURCE: Water not draining from the machine
If it IS the pump, it’s often because some relatively minor item (piece of cocktail stick/bit of nutshell/etc) has found its way past the filters and is blocking the blades of the pump. It is relatively simple to remove the inlet hose to the pump and clear the blockage (a pair of grips to pinch and remove the retaining clip, then the hose will slide off the fitting on the pump). I did this several times on my previous (Hotpoint) machine – and suspect it is no harder on the Bosch (which I now have). If that doesn’t work, you are half-way to replacing the pump, which is not a difficult DIY job and I’m surprised any competent professional repair man wanted to write off a machine where the pump had failed. A new pump should cost around £40-£50 – less than a quarter of the cost of a new machine. DIY fitting would maybe take a couple of hours; a pro ought to do it in less than an hour.
Posted on Apr 02, 2009
Bosche dishwasher Classixx E.09 fault code - what does this mean? Can I fix it myself or do I need an expert?
E:09 is a fault detected in the heating circuit. Try first tripping circuit breaker (or disconnecting power cord) for five minutes and see if this can clear the error.
If that does not work, call Bosch at the number listed on the dishwasher manual. The repair is not suitable for the home user.
About E:09 I quote the good clarificatory explanation given by
"E:09 relates to a fault in the heating circuit. This new range of bosch machines do not heat the water in the same way as the older range. There is no water pressure switch on the heater assembly as the circ pump contains the heater in one complete unit (heat-pump). The control module monitors the speed & current draw of the circ pump to ensure that there is water in the sump & it is also circulating. Your machine must be less than 2 years old, so should still be under warranty. Its not a DIY fix, it needs an engineer to sort it, as it is probably a fault with either the heat-pump or the control module."
Since I do not know your skill level I can't say if you can do this repair or not.
Dec 08, 2016 | Dishwashers
How do I resolve f17 error message on bosch classixx 7
F17 is a time out fault on drain pump. Check all water hoses and drain pump for either blockage or restriction. Failing that, check your waste pipe is clear.
May 29, 2014 | Bosch 24 in. SGS43C12 Classixx...
Bosch dishwasher gets stuck at 1 minute
New and highly targeted viral marketing campaigns can instantly place your product, service or brand in front of potential customers. See the best examples of viral marketing videos and social media strategies. Viral Marketing Company Plan Strategies and Resources Viral Shot
Mar 11, 2014 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx 1400 express
have you cleared the filter
Feb 03, 2014 | Washing Machines
Bosch washing machine does not do the complete cycle
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 05, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Dishwasher not draining after a power cut
I would run the heated dry cycle a few times to try and get rid of that residual water, then restart the cycle and see if it work now. If it still is a problem try cleaning out the drain line behind the dishwasher, this is a very common problem with draining. If not that then might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
Jul 14, 2009 | Bosch 24 in. SGS43C12 Classixx...
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Access to Bosch dishwasher pump
To access the pump, first bail and sponge out any water in the machine's tub. Then tip the machine over on its front, using a heavy blanket or pad to protect the dishwasher's finish. Remove the back service panel. The pump is usually located along the bottom. Good luck!
Aug 25, 2007 | Bosch 24 in. SGS43C12 Classixx...
Bosch 18 in. SRS43C02 Classixx Slim-Line Built-in Dishwasher Logo
231 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
