Question about SanDisk Sansa m240 MP3 Player
1will not turn on. 2 will not connect to rhap.
  • trashman142 Nov 11, 2010
    open mp3 and it work. now it trying to down load most song 2x do you have a fix for that?
  • 3,530 Answers
This is a known issue for this model. Apparently, there was a batch of this model that was sent out faulty. Apparently there is no fix for this issue. But you can try this:
  • If your Sansa m240 is currently frozen, please remove the battery (to unfreeze it), then put it back in, and connect it to your Windows XP computer.
  • To format the Sansa m240 on your PC, connect the Sansa m240 to your computer on an USB port preferably located near the power hub or to an external self powered USB hub, go to My Computer, single right click on the Removable Disk associated with your Sansa m240, and select Format. Make sure that, under FILE SYSTEM, change FAT to FAT32, and then single left click Start. This will erase all data off the Sansa m240 and correct errors on it, which should make the Sansa m240 usable again. Doing this will erase everything in the player.
If these fail, contact Sansa.
North America Technical Support
1-866-SANDISK (726-3475)
8am - 7pm Pacific Standard Time
11am - 10pm Eastern Standard Time
CLOSED Saturdays and Sundays
Thank you for using Fixya!
Posted on Nov 07, 2010
IPad 1will not switch on I have tried holdig the on/off home button does not work
Step One
Open iTunes and connect the IPAD to your Mac or PC.
Step Two
Press and hold the Home button and the Sleep/Wake button at the same time.
Step Three
After exactly 10 seconds release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an IPAD in recovery mode.
May 01, 2011 | Computers & Internet
I need to know what the three wires going into the taillight work
1will be parking light 1 will be brake light and 1 will be ground
Mar 26, 2011 | Jeep Wrangler Cars & Trucks
I need to replace the driver's side brake light.
Rear Combination Light- 2007 might vary from these diagrams:
Removal & Installation 2004 (Early Production) 4 Door To Remove:
  1. Disconnect battery negative cable.
  2. Disconnect electrical connector. Rear Combination Light kia-06-18-7495.gif
  3. Remove 2 screws and 2 nuts and remove light assembly.
To Install:
  1. Install light assembly and 2 screws and 2 nuts.
  2. Connect electrical connector.
  3. Connect battery negative cable.
5 Door To Remove:
  2. Disconnect electrical connector. Rear combination light kia-06-18-7496.gif
  3. Remove 2 screws and push light assembly toward outside of vehicle. CAUTION
    Use care to not damage gasket.
  4. Pull rear combination light from vehicle.
To Install:
  1. Install rear combination light and 2 screws.
  2. Install 2 screws.
  3. Connect electrical connector.
  4. Connect battery negative cable.
2004 (Late Production), 2005-2009 To Remove:
  2. Remove 2 screws and cover inside trunk.
  3. Remove 4 nuts and disconnect electrical connector (A).
  4. Remove rear combination lamp.
To Install:
  1. Install rear combination lamp.
  2. Install 4 nuts and connect electrical connector (A).
  3. Install cover inside trunk and install 2 screws.
Oct 28, 2010 | 2007 Kia Spectra5
My mp3 player doesn't turn on even if I charge it. Do you think I need a new battery?
Make sure the player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, to switch the player to MSC mode
1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Skip this step if you think it is charged. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary. To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 30, 2010 | SanDisk Sansa m230 MP3 Player
My sandisk sansa clip 1gb wont turn on
NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
Jan 29, 2010 | SanDisk Sansa Clip MP3 Player
I need help with my f150 truck. the silnoid (sp) was replaced then the started was replaced. now it won't stop turning over! what could it be? my husband is the one working on it...
Check back the wiring connection at the solenoid. Solenoid acts as a switch between the 2 terminals. When a solenoid engages, it makes a bridge between the other 2 terminals. There are 2 possible reasons: 1-Wrong connections cause bypassing the solenoid function controlling the connection from other terminals so current could continue flowing to the starter causing it keep turning. 2- Bad solenoid with a broken spring inside causing the bridge between the 2 terminals conducting a current all the time for starter to keep turning. If checking the connection correct then replace the solenoid.
Dec 24, 2009 | 2001 Ford F150 Styleside SuperCrew
Sansa SanDisk mp3 out of power
Try these:
SOLUTION 1 - Reset the device.
SOLUTION 2 - Power cycle the device.
STEP 1 - Remove the battery
STEP 2 - Power cycle the player
1. Connect the device to the PC.
2. Leave the device connected for about 2 minutes.
STEP 3 - Turn on the device
1. Disconnect the player from the PC.
2. Insert a fresh AAA battery into the player.
3. Turn on the player.
Jan 25, 2009 | SanDisk Sansa m240 MP3 Player
Every time i try to put songs on it doesn't work
For videos you need sansa media converter here is a link to where you can get it. http://www.sandisk.com/driverdownload/download.asp?driverId=184
You also need quicktime player. http://www.filehippo.com/download_quicktime_player/
Jan 25, 2009 | Samsung YP-U3 MP3 Player
Cant remove songs
try opening it up in rhapsody or windows media player and delete the songs through there.:
  1. open either rhap or wmp
  2. the devices should be in a tab to the left (rhap) or on the top (wmp)
    1. for wmp, it might be in a tab in a tab
  3. click on the music "+"
  4. and from there delete the music
Apr 23, 2008 | SanDisk Sansa e250 MP3 Player
Protection of yamaha pc 2002
Protect delay is in the relay and not adjustable as to delay time.
I would not worry unless no sound then may have to replace relay.
GOOD LUCK
BIG RED
Feb 20, 2008 | Yamaha P2500S Amplifier
SanDisk Sansa m240 MP3 Player Logo
406 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
