Question about NEC MultiSync LCD1700V 17" Flat Panel LCD Monitor
I have a nec multisync LCD 4020 with a large cracked/broken screen which I need repairing/replacing asap, any ideas where I could get this fixed and a rough cost. I live in Wolverhampton west midlands. Thanks
  • 11 Answers
SOURCE: Power on Green but no display (blank screen)
In the LCD1830 the inverter for the backlight always burns out. They are fairly easy to replace when you remove the back to get inside. A new one is available from MoniServ for $69.99. http://www.lcdpart.com/Products/uhp061104mss.html
Posted on Apr 07, 2007
Rifaa
  • 99 Answers
SOURCE: nec multisync lcd 2080ux no raster no power indicator light.
If u a tech, try checking the PSU of the monitor for blown fuse or dead driver element ( typically a FET, Power transistor or an Hybrid chip) . U need to take the monitor apart, if unfamiliar, get it to a service tech.
Posted on Nov 08, 2008
SOURCE: touch system not working NEC multisync 1550v
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
Posted on Jul 04, 2009
SOURCE: NEC MultiSync LCD 1560V+ 15 '' LCD Monitor touch-screen
How do you flip the screen on this lcd computer so it's side ways
Posted on Feb 16, 2010
SOURCE: screen and colors too bright
Sorry to say, but I'm having the same problem. If it doesn't change when you press the Fn key and the hollow/right arrow sunshine, then, I doubt there's anything you can do.
Posted on Feb 18, 2011
Cost repair screen for a nec multisync lcd5220
It will cost around 2/3rd of the total cost of a new TV; including panel price + service charges.
Gopakumar Gopalan Google
Mar 27, 2014 | NEC MultiSync LCD5220-IT 52 in. LCD TV
NEC Multisync LCD 2080UX has a strip that appears on screen after 20 mins use.
Might be from overheating, monitors do overheat sometimes. I had the same issue happening to one of my old monitors and it wasn't fixable unfortunately. I had to replace it and get a new one.
Nov 05, 2013 | NEC MultiSync LCD1810X 18.1" LCD Monitor
I have a dim screen!
Probably a bad power supply or an exhausted backlight source, or both. You can pry apart the monitor shell and look at the power supply board for bulged capacitor(s). Just replace all the large ones if even one is bulged. You need soldering tools to do this job.
Mar 29, 2013 | NEC MultiSync LCD1860NX 18.1" LCD Monitor
Nec multisync 1525x need user manual. annoying menu keeps poping up on screen. any ideas ?
Here is the link for an Multisync 1525x
http://www.necdisplay.com/cms/documents/UserManuals/l1525Xg.pdf
Feb 25, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
ON /OFF SWITCH BROKEN
Better that you bring the unit for repair, to check and possible fix of the monitor.
Replacement on the switch I think has to made, to put back into normal.
For any other related concerns, let me know
Jul 29, 2009 | NEC-Mitsubishi MultiSync LCD2170NX (Black)...
Touch system not working NEC multisync 1550v
May 03, 2009 | NEC MultiSync 1550V 15" LCD Monitor
NEC 1860nx. When owering up monitor, screen lights up, then 2 seconds later goes dark. Can I repair this?
The inverter board was made using lead free solder.... thank the Europeans for that. The larger components develop cracks on their solder joints after a few months of on time. Remove the inverter board. Use 15x magnification or better in bright light and you'll see the cracks on the ends of the large resistors. Apply fresh solder and you'll be good to go. You might run into resistors where you solder one end and they lift up... that means joints on both sides went bad. Son't kow how many more fixya's I'll answer w/o free access to the other responders?
Mar 15, 2009 | NEC MultiSync LCD1860NX 18.1" LCD Monitor
NEC Multisync 1760NX malfunction
I repaired mine by replacing C807, 22uF 50V capacitor in the power supply.
Monitor Mike
Nov 07, 2008 | NEC 1760NX-1 (White) 17 in. Flat Panel LCD...
DISPLAY STAYS FOR 2 SECOND ON NEC MULTISYNC LCD 1760V
the inverter board has a problem. this is the small pcb that sends high volts to the backlights you will need to change it
Jul 12, 2008 | NEC MultiSync 1525X 15" LCD Monitor
NEC MultiSync LCD1700V 17" Flat Panel LCD Monitor Logo
54 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
