I will put in a vcr tape and press play and after 7 seconds of playing it shuts down..It also does it with my head cleaner tape..This unit is a vcr/dvd unit and I've only been using it for 8 months..
    Brigadier General:
  • 8,909 Answers
It has a mechanical problem. The take up spool is not going round, I suspect.
If you are competent, remove it from the mains supply and remove the top. Carefully examine the VCR section for foreign objects that are likely to stop the pulleys or cogs from rotating or meshing properly. I actually found a piece of toast in one of my customers VCR's. Its cause was a small person feeding the cartoon character!
Without a service manual, it will be difficult to decide on what is required to repair it but at least you may have saved yourself some money, if there was something stuck in there that shouldn't be.
Hope that helps.
Posted on Nov 07, 2010
The VCR is completely off track.. Does anybody has any solutions?
If by "off track" you mean it cannot track an image on the tape, it may just need cleaning. The heads, head drums, guides, and rollers in the playback mechanism require cleaning on a regular basis and, if they are not cleaned regularly, oxide particles and dirt accumulate to the point that the VCR is no longer able to play tapes.
Although automatic head cleaners are available, they're more for maintenance, and if it isn't playing tapes anymore it's beyond that. I would recommend taking the VCR to a repair shop for cleaning... shouldn't cost very much, and it should solve your problem. (Let's hope that the heads aren't worn down... bit more of an issue.... but try the cleaning first.)
Once you have the unit running again, buy an automatic cleaning tape and use it every few plays.
May 21, 2015 | Panasonic DMR-E75V DVD Player/VCR
Magnavox ZV427MG9 DVD Recorder VCR Combo plays vcr for about 5 second then stops and shut off, when turned back on it ejects the tape.
This combo has a problem with the vcr unit which take up wheel will stop working and spill the tape. the unit will stop and eject the tape. You have to replace the whole vcr assembly.
Feb 16, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
VCR shuts down when tape loaded, "play" pressed...
could be dirty play heads and or rollers, run a wet cleaner through and see if this cures the problem.
Apr 08, 2010 | Philips Magnavox DVD/VCR Dual Player
TV is on channel. VHS player has tape for playback loaded. Player is on but when PLAY is pressed 5 seconds later it turns off by itself. Model number is DVP3200V/37. Can anyone help, please.
Dirty magnetic head. Run a commercial tape head cleaner through it. You can get one at the box stores. Also, put your tape in a tape rewinder and rewind and fast forward the tape for about 30 seconds. Sometimes the tape ribbon gets wound too tight or is loose. If these fail, then you have to open the unit up and clean the magnetic head manually with some isopropyl alcohol and cotton q-tips. Also, look for capacitors on the power inboard chip that look burned and replace them.
Feb 04, 2010 | Philips VR621CAT VHS/S-VHS playback VCR
Philips DVP 3150V
saida horizontal com deficiencia faz com que a fonte aciona circuito de proteção.
Feb 09, 2008 | Philips CCB092AT 9 in. TV/VCR Combo
Vcr not playing tapes, just ejects them
Not enough info. What is the product? Brand, model, how old?
May 13, 2007 | Philips MWD2205 DVD Player/VCR
VCR functions do not work (play, record, ...)
Sounds like the idler assembly isnt working. Without this assembly, the system cannot get the tape to actually move, and most systems will shut down if the tape isnt moving to prevent damage to the tape. In truth, this can be a complicatred repair, requiring the machine to be taken apart quite a bit. I would suggest taking this kind of a problem to a repair shop, but with the cost of simple VCR's coming down constantly, and the upcoming switch to DTV making the machines tuner obsolete, it would probably be more economical to just replace the machine.
Feb 15, 2007 | Mitsubishi HS-U110 VHS VCR
Philips vr630 vhs
I get the same problem with one tape (it's about 20 minutes long) .. it also shows a '4' ... when you press the power button it ejects the tape... some tapes are fine ...
Jul 14, 2006 | Philips VR630 VHS VCR
The unit will fast forward and rewind, but won't play
This is a problem with the process called 'tape loading' - pulling the tape loop out of the cassette and wrapping it around the spinning video drum, engaging the capstan and pinch roller and reel rotation. Check all the belts above and below the deck. Belts can appear to be firm but if they do not return immediately to their relaxed length when you stretch them 25%, they will need to be replaced. With the cover off, observe the behavior when you hit play. (You may need to put a piece of cardboard over the cassette to block external light from interfering with the start/end tape sensors). Assuming this is a basic VCR (no instant start features), you should see: 1. The video head drum begins to spin. 2. the roller guides move smoothly on the tracks, wind the tape around the drum, and stop snuggly pressed against the 'V-stopper' at the end of the tracks. 3. The pinch roller moves into position and presses the tape against the capstan. 4. The tape begins to move and is wound up by the takeup reel. 5. The picture and sound appear on the TV. With a 'rapid or quick start' (or it may be called something else) transport, the tape moves to a half-loaded position when the cassette is inserted. This is at an intermediate position partially pulled out of the cassette but not wrapped around the drum. On VCRs with a real-time counter and/or index search capabilities, the tape will be in contact with the control head. With an 'instant start' transport, the tape will fully load around the spinning drum when the cassette is inserted but the capstan will not engage and no tension will be applied to the tape until you press PLAY or REC. (After about 5 minutes, the drum will stop and it may unload to the half loaded or unloaded position.) Note that for VCRs with a real-time counter and/or index search capabilities, the tape must be in contact with the control head (but not the video heads) for all relevant modes. These VCRs (which include many modern units) must therefore pull the tape at least partly out of the cassette. In all cases, the completion of the sequence results in approximately the same mechanical configuration during PLAY. Several likely possibilities when it shuts down: 1. Everything occurs as above, picture and sound appear for a few seconds, but then the VCR unloads the tape, ejects the cassette, goes into REW mode, stops, or shuts off. Two common causes: The takeup reel does not turn and tape spills into the machine. This is sensed by the microcontroller which aborts record or play and attempts to save your valuable cassette. Most likely cause: old/dirty idler tire. As a test, turn the idler tire inside-out. The fresh surface will now work well enough to confirm this diagnosis and will continue working long enough for your replacement idler tire to arrive. See the section: "General guide to VCR cleaning and rubber parts replacement". The takeup reel is turning properly but
Nov 22, 2005 | Sharp VC-H810U VHS VCR
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
