Question about Samsung YP-P2JAB (4 GB, 1000 Songs) Digital Media Player (YP-P2JAB/XAA)
I have a bad connection where you plug in the earphones, resulting in crackling noise or no sound at all. how do i get this repaired.
  • 4 Answers
You either need new earphones for this or you will have to contact either a manufacturer or a repair shop near you, they would be able to tell you exactly whats wrong
Posted on Nov 07, 2010
The sound on my Dell W4200 is crackling some times even when the sound is on mute. Sometimes the sound is fine, other times no sound and other times the crackling noise. Any idea what problem may be?
Hi There,
Crackling sound is often an indication of bad connections to the speakers. Are you listening with the built-in speakers or through an external amplifier?
If you are listening through an external amplifier or speakers, check all of the connections to make sure the cables are properly inserted, and wiggle the cables from each end and the middle to see if that reproduces the symptoms. Sometimes a cable can become damaged from being squashed or bent, and it may be as simple as replacing the faulty cable with a new one.
If you are listening with the built-in speakers the situation might be harder to identify and correct. Sometimes it is as simple as nearby wireless devices or radio towers causing interference with the speaker. You can try repositioning wireless devices such as computer routers, cordless landline phones or radios to see if that helps.
However, over time the solder used to connect the internal components can wear and sometimes break the connection. For this type of situation repair is usually the only option. If the warranty of your TV has expired you may have to take it to a local TV service center. Typically a loose solder joint is easy to identify and fix, so the repair bill should not be high.
Please post back with your results.
May 26, 2011 | Dell W4200 42 in. HD-Ready Plasma...
My Aiwa powererd sub-woofer TS-W50U) has crackling sound.
Crackling is an unusual noise but typically indicates a bad capacitor in the amplifier board. This can be a rather costly repair but first we will go through basic trouble shooting steps.
Reduce the volume on the sub and see if the noise remains and changes with the volume.
Unplug the sub and disconnect interconnect cables. With both hands push softly on the speaker cone to move it in, let it back out and do this a few times. If you hear a scraping noise and some resistance your driver is misaligned and you need to recone or replace the driver.
Check all your interconnect cables, there may be a bad internal connection (usually causes pops and cut-outs).
Let me know how things workout. If it makes the crackling noise at all volumes and the driver seems fine then I would seek a professional to repair it, or replace.
Cheers,
Kevin
Feb 09, 2010 | Aiwa Audio Players & Recorders
I got same clacking noise my vaio cs17g/w so pls help to sort this out thanks
the clacking noise could be coming from the fan blades touching the main frame .
have a look and see if the cooling fan is rotating properly and not making noises
Oct 01, 2009 | Sony VAIO VGN-CS110E/W NoteBook
My ipod crackles and my hearing seems to be getting damaged
Id say you should go see a doctor. But for now id say that you should do your best to not listen to it for a while as it can affect hearing. try to use full on speakers if you can. On you tube there are a few Sub-Woofer sound tests you can do. Try playing one (low volume) and repeat. (not a song one)
http://www.teenbuzz.org/ also to hear which frequencies are out of range to you click here. ( click the second icon on the list further down the page)
But yeah go see a doctor. Perhaps some ear drops.
Sep 01, 2009 | Apple iPod touch
When i play music there is crackling and popping noises inside the speakers
Check to make sure it isn't the speakers with earphones. If it doesn't make the sound you have a bad speaker or a bad amplifier.
Aug 30, 2009 | Acer Audio Players & Recorders
I get a crackling noise from the sound card when playback
try updating the drivers for your sound card. if you get the same problem with earphones plugged it then you have a sound card problem and need to be repaired, if not then it is your built in speakers. Run diagnostics on it and it will check this for you. Then call HP if it is still under warranty.
Jul 15, 2009 | Compaq Evo N610C Notebook
Gateway Computer 710X Speakers are crackling/popping
It sounds as if the card itself may be physically bad. or you may have a microphone connected/something in your mic jack and you are picking up noise.
Nov 26, 2008 | Gateway /Creative SoundBlaster Sound Card
Crackling
either you have a short in the wire of your earphones or were the female plug is in the player needs to be soldered inside the player
Feb 09, 2008 | SanDisk Sansa e250 MP3 Player
Samsung YP-P2JAB (4 GB, 1000 Songs) Digital Media Player (YP-P2JAB/XAA) Logo
64 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
