Question about Toshiba Satellite X205-SLI1 Notebook
I was trying to install windows 7 on my laptop and it wouldnt load and gave a message about going into the bios. So I did and when I changed something not sure what it was, and now when I turn it on it goes through a phase of telling me how much ram i have and then goes to a password screen but none work. So I went online looking for answers so I got to a point where it told me to bypass the cmos battery so I have my computer all apart but don't know if the battery is removeable, maybe you can tell me by my model number if the battery can be removed or if what I'm looking at is even the correct part.
    Brigadier General:
  • 8,909 Answers
The CMOS battery is a rechargeable Lithium button cell and is best left well alone.
Underneath, near the RAM, is a jumper land, (ident 500). Short the lands together for about 15 seconds and boot up your laptop. BE VERY CAREFULL as irrepairable damge will be done very easily!
When the laptop boots, go into the BIOS menu, and find the "Restore Default Setting". Click F10 to exit and save.
That will return your laptop to a useable state again.
Hope that helps.
Posted on Nov 07, 2010
Aspire 1700 needs to be acpi compliant, to run windows 7 help needed
Advanced Configuration and Power Interface
(ACPI) specification provides an open standard for device configuration and power management by the operating system.
Windows 7 absolutely requires ACPI 2.0 for power management.
Your laptop only supports ACPI 1.0. Windows 7 will never load
I think Vista is the most advanced version you could install.
I really like XP as the speed is so much faster.
Keep Smiling :)
Oct 24, 2013 | Computers & Internet
Hard Disk Adapter
Why would you go back to XP after having 7?
Installing any operating system:
When you first boot the computer you will see a screen that says press: F1, Delete, etc to enter setup. Once you are in setup (BOIS) navigate with keyboard arrows to find 'boot sequence'. select boot from 'cd'. Remember you have to go back and set this to boot from hard drive after you load the OS (Operating System).
Make sure you save your files, everything will be gone. Also, backup all of your drivers or download them from the internet and store them on a USB flash drive. As you may not be able to access the internet to load them.
Boot from CD>going into setup>install xp>delete partition>create>partition>setup will format drive>quick is fine>will have some prompts for selections, etc.
I hope this helps.
Oct 21, 2013 | HEWLETT-PACKARD HP Mini-Notebook...
I have a IBM Lenovo r500 laptop and I am having trouble loading windows 7 on it. I have updated the bios but it has worked since then. Now I am having error messages trying to reinstall it on a clean...
Yes! it could be, is the window 7 a upgrade disc? the reason I ask it will detect the previous version and install, but if the hard drive has been completely formatted it won't install on empty hardware. If that is not the issue go into bios and reset to factory default it might make the difference.
Apr 09, 2012 | Lenovo IBM ThinkPad (2647X800C) PC...
Boot mgr missing message
I could have told you you were loading Windows 7 by the symptoms. Try running a Malware program with a register edit-register function in it. If you are switching from XP Pro. you will need to clear your register and all command and drive to . Set BIOS to boot from DVD/CD first then set the hard drive to boot second. Windows. Also if you have access to another computer ask microsoft for tech support.
Apr 01, 2012 | Compaq Presario 5000 PC Desktop
I install Xp in my NEC versapro nx series laptop when it appears this message file/i386/ntkrnlmp.exe could not loaded the error code is 7
This is a installation problem. It might be due to skipping this file during the OS XP Loading. Either repair your OS or relaod new OS. Donot escape any file during installation.
Sometimes due to your DVD Drive lens or too used CD's some files donot copies and error message comes couldnot load so and so file, try again or skip. donot skip select the try again or use another good cd t load that file..
Dec 22, 2010 | Computers & Internet
Loaded Windows 7 Tried to get as many drivers as
Install the chip-set utility first upgrade bios if needed, check ahci mode in bios
Aug 10, 2010 | HP Compaq Business nc8000 Notebook
I'm having problems installing windows XP. After it boots from the CD and trying it load the setup files it, error message comes up saying [b]"File \i386\kdcom.dll could not be loaded. The error code is...
reset bios settings, go on and change to factory settings, and try again. if not download hirem boot from http://www.hiren.info/pages/bootcd , burn to cd, reset the pc, put in the cd , seletion boot hirem cd and start some program like hard disc tools and format , then try to install again windows
Aug 04, 2010 | HP Compaq Presario 6320US (DA202A#ABA) PC...
I HAVE A LAPTOP COMPAQ PRESARIO C505TU. YESTERDAY, FOR SOME REASON, I UPGRADED THE BIOS TO F.24 VERSION AND THE MACHINE SHUT DOWN AND KEPT FLASHING A BLUE SCREEN. I TRIED INSTALLING A WINDOWS XP BUT IT...
ok I just went through this, since you have xp, you have to go into your bios and disable sata support and your machine should load just fine.
Apr 30, 2009 | Computers & Internet
MY VISTA WINDOWS WONT LOAD
Okay, I think I can help you but I need some more information. I'm assuming your Acer laptop currently has a version of Windows XP installed, yes? And Acer gave you a CD to upgrade your OS to a version of Windows Vista?
And when you mean that you go to your BIOS to access the CD, I'm assuming that you are talking about the boot options menu (selecting the cd drive vs the hard drive or floppy drive or what not) correct?
When you select the CD drive to boot from, what exactly happens? Do you get any error message? Does the computer turn off? Does it appear to try to load from the CD and then switch to your hard drive instead (and load your existing operating system)?
Nov 08, 2007 | Acer Aspire 3680 Laptop
Toshiba Satellite X205-SLI1 Notebook Logo
52 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
