Question about Snap-On Welding Tools
My snap-on mig welder powers on fine, wire feeds normally, but I only get a little blue spark and a sizzle when I try to use it
  • 407 Answers
Initial setting it's wrong, you should have a vivid spark. If it just sizzle try to increase your voltage and wire speed.
Posted on Jan 12, 2011
I have a120 MW snap-on welder that the wire feed works i accidentally touched to ground clamp sparked, and know nothing. is there a fuse or breaker??? the wire feed works still
Replace your contact tip on the end of the mig gun
Sounds like youve arced it out and the wire is stuck in the end of the contact tip but steel feeding possibly spitting wire out of the drive roll like we like to say birds nest
Dec 06, 2015 | Snap-On Welding Tools
Cebora mini mig on trigger no wire feed ,power on?
Cebora mini mig on trigger no wire feed ,power on? - Fixya
www.fixya.com/.../t25810314-cebora_mini_mig_trigger_no_wire_feed
3 hours ago - Question about MIG Welders ... Weld corp mig 100 turn machine on andwire keeps feeding without ... Welder running but wont feed wire etc.
Aug 05, 2015 | Welding Tools
Wire feed problem with snap-on mig welder
There are two wires comming from the circuit board to the wire feed motor. You can try running the motor directly from a 12v battery or two for 24 volts. You might want to look at the name plate on the motor to check the normal DC current it draws. If you do not have an ammeter, you could use a fuse close to or just under the normal current. If it runs and draws too much current, then you know you have motor problems.
If it runs well and draws a fraction of normal current,you know the motor is good. Before you condem the circuit board, check that it is receiving the correct input voltage. If the welder is dual voltage,then somebodys mistake making voltage change could send 240 v to the board that is meant to receive 120v.
Hope this helps, Robert
Aug 21, 2012 | Hobart Handler 140 Mig Welder
The gun on my welder is broken and need to fine a new one the wire feedes thru gun to weld it is a cambell hausfeld mig welder
You could try Canadian Tire where you bought it.
If not there, check to see if the gun is replaceable by contacting the manufacturer through their website..
Mar 02, 2010 | Campbell Hausfeld MIG / Flux Core Wire...
Hobart handler 135 feed motor for wire doesn't feed wire. motor is ok I tested it with seperate power source. No power to motor from main board or ??????
check the SCR ,looks like a big transistor mounted
to a heat sink or some of the older units had a relay
in-line with a fuse , I have a older Hobart and it is
a great little welder. If you snap a pic of the P.C.
board and email it ill rsheehan@northernsteeldesigns.com
point out what parts to check.and replace.
Rob
Dec 06, 2009 | Hobart Handler 140 Mig Welder
Welder not welding
The contact tip is the main source of power, if the tip is bigger than the wire then you will not get a proper conection, the earth clamp is a essential part of the system make sure you have a good earth and all the conections are tight
Jan 14, 2009 | Clarke Power Products Clarke 130EN Mig 110...
Welding Tools Logo
510 people viewed this question
Top Snap-On Welding Tools Experts
littlewheel
Level 1 Expert
Lawrence Oravetz
Are you a Snap-On Welding Tool Expert? Answer questions, earn points and help others
