Question about Saniflo Home
Saniflow system keeps frequently flushing even when the system isn't being used. the system is working normally but it keeps flushing through the day and night.
  • 28 Answers
Need to check the flapper inside the toilet tank. this is what opens when you press on the toilet handle. you may need to replace it or replace the whole flush valve assembly.
Posted on Nov 08, 2010
Saniflow runs, but not straight after flushing
Here is a nice link for your saniflow maintenance.
http://www.plumbteamltd.co.uk/sanifloguide.html
This will definately help.
Jan 30, 2013 | Saniflo Home
Saniflow macerater wont stop running
sounds like a stick float vave check this link on maintenance of your system.
Check the masserator is clear also check the outflow pipe , maybe a good clean see this link for more info
This will may help.
Dec 01, 2012 | Saniflo & Saniplus& Macerator Pump
Saniplus masorator keeps running
This will may help.
Nov 17, 2012 | Saniflo SaniPlus-Round SaniPlus Macerator...
Pump randomly runs
This problem maybe caused by a slight weep of water from the cistern the saniflow has a sensitive float system , once level is reached the unit will turn on until required level is acheaved again . So check toilet bowl to see if the is a trickle of water if so you need to take a look at the flush system in your cistern.
Nov 17, 2012 | Saniflo & Saniplus& Macerator Pump
Toilet wont flush
This will may help.
Oct 22, 2012 | Saniflo Sanicompact 48 - One Piece Toilet...
I have a saniflow for toilet and when flushed it makes a whirring noise and gradually goes to a loud crunching noise at this point i turn power supply off when turned back on its ok till next flush !p
find water pressure regulator. it will have a bolt coming out of the top with a nut at the base of it.loosen nut. while toilet is being flushed, adjust bolt till noise stops. turn bolt clockwise to adjust.
Dec 17, 2011 | Taylor Home
I have a saniflo toilet installed in my attic. The pipe runs accross under the roof and is connected to the sewerage pipe for the bathroom on the first floor. What toilet paper should I - use -2-ply or...
Any brand approved for septic should work well in the saniflow system, but the key is to use as little as reasonably possible and flush as you go. Big wads of any type will compromise the system.
Oct 03, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflow pro xr keeps running and blowing trip fuse any idea's
Mine did this, have you tried using a drain cleaner to break up any blockage? I had to unblock the outlet pipe by connecting a garden hose and flushing it out.
Mar 15, 2010 | Saniflo & Saniplus& Macerator Pump
Why does my saniflow continuously come on even
could be a part blockage alowing water to filter back never put paper or towles in it
Sep 28, 2009 | Plumbing
My saniflow saniplus has stopped pumping water i think- the toilet and bath has filled up with waste water. i have taken the top off the saniflo and blades are working fine but they keep going because the...
We had that problem but the unit was built in and I could not get at it, the outlet pipe sounds like it is blocked, I cleared mine by connecting a pipe from the cold tap to the outlet pipe and flushing.
May 11, 2009 | Saniflo & Saniplus& Macerator Pump
Home Logo
290 people viewed this question
Top Saniflo Home Experts
paulcarew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
