Question about Refrigerators
Freezer section of Kenmore Self Defrost Refrigerator Mfg. 4/07
Food and tops of food containers are forming ice on them. For example, cool whip container top has a thin sheet of ice on it and inside the cool whip, ice had formed on the whip cream.
Temperature has been set at the manufacturer's recommended setting.
Very little food is stored in the freezer
This is a Kenmore top freezer refrigerator. The model number printed inside the refrigerator is 253.67879506 but I can't find that model number listed. Serial # is BA71805062
  • Anonymous Mar 16, 2014
    serial number oo11179178 mfg number P1317404WW How old is my refrigerator
  • Anonymous Mar 18, 2014
    condensation inside food containers in my whirlpool refrigerator
  • Refrigerators Master
  • 5,568 Answers
What you have found as a model number may in fact, be a part number for the inner lining.
Check your owner's manual for the model number.
Check to see if your unit is equipped with a setting for humid/dry climates and if it is present, it should be set to correspond to yours.
The defrost cycle melts concealed, built-up frost, with an internal heating element.
That produces water that should normally drain through a hidden path down to the evaporation tray at floor level under your unit.
If the path is blocked, the water will find its way into the interior and refreeze wherever it lands.
Gaining access to the element and the drainage path can be a real pain in some refrigerators and requires removal of the liner of the freezer for access.
Good luck.
Posted on Jun 15, 2008
How can i fix it when kenmore type JD21, model 970-432603 refrigerator not cold but freezer is cold
Ice build up on the coils can cause this. If there is ice then you need to check the defrost timer first to see if it works. Then check the defrost coil, then the fan.
Jan 23, 2015 | Kenmore Refrigerators
Why is my kenmore freezer cold, but refrigerator not even when set at highest temp?
Hello Donna;
My name is peter. I am a retired field service refrigeration technician.
You have not provided your unit model number, which is located in your fresh food section on a label, on the side wall near the top.
You only have one cooling source, and that is your freezer. Your freezer feeds your fresh food section. This is through a direct air vent.
Reach into your fresh food section where the air vent from the freezer goes into the fresh food section. Do you feel cool air? Probably not.
So, either the air vent is frozen up with ice which you can clear with a hair dryer, or you have a automatic air vent motor/ sensor assembly that is bad.
Give me more information and I will help you.
Jan 21, 2015 | Kenmore Refrigerators
Freezer ok, fridge not cooling
That could be the motor up in the freezer is not working or it could be a defrost problem. If you see frost on the back side of the freezer that is most likely a failed defrost circuit. If you cannot hear the fan motor or possibly a fan switch mounted in the door jamb. Sometimes the drain can stop p and water puddles between the top and fresh food bottom. Forms a slab of ice and blocks the cold air from getting to the fresh food section.
Jul 28, 2011 | Kenmore Top Freezer Refrigerator
Upper portion (frig not cooling properly) Lower portion (freezer) forming ice on #3 setting.
Is it forming ice or frost? It sounds like an automatic defrost problem. If the freezer frosts up it won't circulate enough air up to the fresh food compartment. Try defrosting it manually for 24 hours by shutting it down and leaving the freezer door open. Afterwards, if it resumes normal operation I would bet that there is something faulty in the defrost circuit, i.e., defrost heater not working or defrost control.
Feb 23, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The freezer is forming ice on back wall and all around the ice bins where the ice storage is, plus forming on food boxes, what could be the problem?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Aug 25, 2010 | Kenmore TRIO 77314 Side by Side Bottom...
Refrigerator section does not cool; freezer works fine
Check the settings first. They should be set to the factory settings in most cases. Otherwise check the back of your freezer to see if it is icing up, you may need to remove the back panel to see the ice. If this is the case the ice may be preventing the fan to circulate the cold air into the freezer and you will need a new defrost timer. However if there is no ice and the fan never kicks on you may need a new fan motor.
Jul 05, 2009 | Kenmore 73752 / 73754 Top Freezer...
Whirlpool Refrigerator fresh food section cool but not cold (freezer ok).
The most likely problem is in the defrost system. Behind the freezer panel there is not only an evaporator fan, but also the evaporator itself, and a defrost heater, termination bi-metal, and drain pan (or trough). You will likely find ice build-up in the evap coil. This could be caused by the defrost timer, the heater, or the termination bi-metal.
Have a service tech look at the unit.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator and freezer not cooling/freeding
Possibly a defrost circuit problem -
1) Bad defrost thermostat
2) Bad defrost heater
3) Bad defrost timer
4) Failed evaporator fan motor.
Look for frost accumulated inside the louvers at the back panel, top and bottom. If you see it, remove food from freezer and put in ice chest. Take out shelves, get hair dryer and warm the backside of the freezer, directing air down the louvers. Then leave to sit for 4-6 hours with the freezer door open. Put towels in the bottom of the freezer to catch any melted ice.
After period of time, plug unit back in and power the unit back up. Once you know it's cooling, empty ice chests back into freezer.
If there is a problem in any of the above components, then it will show up in 3-4 weeks witht he same problem again.
Jan 29, 2009 | Kenmore 53642 / 53644 Side by Side...
Fresh food section not maintaining cold temp
You're frozen up.  Defrost completely.  Then, clean your condenser.  Make sure to never leave open containers in the fridge...water condenses into ice.  If you still have problems, you may be low on gas.
Nov 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
177 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
