Question about Garmin nuvi 205W GPS Receiver
Garmin Nuvi 205W won't switch on. My 205 will only switch on if I remove the battery, reconnect it, then switch on. It will only allow me to switch on once. Then I have to go through the procedure again. Battery is fine, screen is fine GPS is fine, No error codes, to hidden menu error codes. What's up?
  • dawid_pretor Nov 07, 2010
    I did a number of resets including erasing all user data.
    Battery voltage 4.03V tested and displayed in GPS maintenance pages.
    Battery indicates full green bars when disconnected from power.
    Only way to turn the unit on is to disconnect the battery. Reconnect it. Then power the unit.
    Then unit would then act normal. I move the switch left and it powers up.
    If I tried to switch the unit on after the battery reconnect, then it will not come on until I apply ext power.
    This means the unit remembers that the switch was made under bat power only.
    If I leave the unit on Ext power and switch it off, it does so normally by indicating it is charging the batteries on the screen for a few seconds before the display blanks. Moving the on switch to the left and the unit switches on. Remove the ext power and the unit asks to stay on or off. If selected on, it stays on battery. If selected off, it will not come on again. Then I have to disconnect the battery first.
    I do not have a spare battery to test if it is a battery fault. I do not want to spend money before I know which of the parts are broken, the board, or the battery.
    President:
  • 1,216 Answers
In your Garmin Nuvi 205W won`t switch on, is pluged to power but won`t turn on or you all ready try to reset the unit
slide on switch to the left and hold 10 to 15 seconds it should power on while your holding it.
but still no power there can be many reasons for an Garmin Nuvi 205W not powering. Reasons like software faults, battery faults or even charging connector faults.
Posted on Nov 07, 2010
  • Aviral Saxena
    Aviral Saxena Nov 07, 2010
    Are you sure battery is fine?
    it appears to me a faulty battery if soft reset didn't worked.
    else connectors may be faulty
How to remove battery from garmin 205 ?
they are fixed in you have to take the hole thing to bits
Jul 27, 2014 | Garmin nuvi 205W GPS Receiver
Tip
Download Nuvi 205 Manual Models: Garmin Nuvi 205, 205T, 205W, 215,...
Models: Garmin Nuvi 205, 205T, 205W, 215, 215T, 255, 255W, 265, 265W, 275
Have you lost your User's Manual or the Quickstart Guide for your Garmin Nuvi 205, 205T, or 205W GPS?
Would you like a digital copy for easy searching of terms and quick reference?
Both manuals are available in pdf format, just follow the photo links below:
I hope that helps.
on Apr 16, 2010 | Garmin nuvi 205 GPS Receiver
Tip
Download Nuvi 205W Manual Models: Garmin Nuvi 205, 205T, 205W, 215, 215T,...
I hope that helps.
on Apr 16, 2010 | Garmin nuvi 205W GPS Receiver
Garmin 205 how to charge on computer?
follow the steps below:
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disappear.
Good luck.
May 27, 2010 | Garmin nuvi 205W GPS Receiver
Garmin Nuvi 205 continues to state Loss Satellites
If your Garmin NUVI 205 can be recognized by your computer when plugged in, I recommend you backup your favorites.
Then I suggest a hard reset. This correct some problems.
Finally, replace the firmware and system software using webupdate. Replacing the firmware should allow it to find more satellites more quickly and keep them more successfully after the update.
I hope that helps.
Mar 14, 2010 | Garmin nuvi 205W GPS Receiver
Tip
How to Download your Garmin Nuvi 205 or 205W Users Guide. Models: Garmin Nuvi...
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Have you lost your User's Manual or the Quickstart Guide for your Garmin Nuvi 205 or 205W GPS?
Both manuals are available from the Garmin website, or just follow the photo links below:
I hope that helps.
on Jan 17, 2010 | Garmin nuvi 205 GPS Receiver
Tip
I hope that helps.
on Jan 17, 2010 | Garmin nuvi 205W GPS Receiver
Remove a map to make space on my garmin nuvi 205
I would reset the whole unit to factory specs & then load map.
Jul 06, 2009 | Garmin nuvi 205W GPS Receiver
Tip
How to Perform a WebUpdate of the Garmin Nuvi 205 and 205W System Software
Does your Garmin Nuvi 205 or 205W get stuck or freeze at startup or when loading maps?
One trick to try when your GPS is acting up is to perform a Hard Reset.
Occasionally, your GPS may not start properly at all, and display a 'System Software Missing" message. Today's tip will describe how to restore your Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your PC and update the system software of your GPS.
Your Garmin Nuvi should be running as good as new.
Tip
How to Perform a Hard Reset of your Garmin Nuvi 205 and 205W
Does your Garmin Nuvi 205 or 205W Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data)has been known to resolve unit quirks and strange behavior after firmware updates. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit. It's also one of the first things that Garmin will have you do when contact tech support regarding quirky unit behavior.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will beread from 'temp.gpx' into the non-user accessible memory area on theNuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 205 and 205W.
I hope that helps.
_______________________________________
Download Garmin Nuvi 205 Manuals here.
Garmin Nuvi 205 Favorites Backup here.
Garmin Nuvi 205 WebUpdater here.
on Jan 15, 2010 | Garmin nuvi 205 GPS Receiver
Garmin nuvi 205W GPS Receiver Logo
461 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
