Question about LG 42LG30 42 in. LCD HDTV
Telly will not switch on, blue light comes on for 3 secs than goes to red..
  • 4,889 Answers
The problem you have described is called protection fault. When an overload is detected on one of the lines the tv will be shutdown to prevent damage. The cause of the failure is usually component level(resistor, voltage regulator IC etc.,) and the location is power supply board. You may want to take the assistance of a qualified tech to resolve this problem, as its not a good idea to work on high voltage electronics without prior experience.
Posted on Nov 07, 2010
Www rockauto com
hi Robert
do this procedure and your Nissan will be OK
switch ignition ON till airbag light goes OFF briefly ( approx. 7 sec) immediately after light goes out turn ignition OFF for 3 sec,
repeat this 3 times, after you switch ignition OFF 3rd time for 3 sec
switch ignition ON for 1 sec then OFF, again switch ignition on and start the car, the AIR BAG light will goes OFF.
let me know how it goes
good luck
Feb 04, 2014 | Nissan Armada Cars & Trucks
I have a Sceptre X7G-Naga VI 17 inch LCD Monitor When I turn the monitor on and boot the computer I get the red light for a sec then the blue light comes on I will also see windows booting up but the...
try with restarting computer & press F8 at the same time. u will see a menu where choose "safe mode" & start the computer. in safe mode see the display properties, set the refresh rate & resolution according to monitors specifications, apply & restart again. if that does not work, replace the main board of lcd monitor.
Aug 25, 2011 | Sceptre 17" LCD Monitor
Aug 25, 2011 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
2 switch system. 2 black wires and 1 red wire in the switch. I have hooked up black wire from the switch to the red wire in the box. green wire from switch to black wire from the box and red wire from the...
You posted under ST01C and are wiring timer to replace 3-way switch.
Open following link for specific illustrations:
http://waterheatertimer.org/ST01C-program.html#ST01C
http://waterheatertimer.org/pdf/ST01C-explanation.rtf
1) The timer replaces one of the 3-way switches. The other 3-way switch remains, but must be rewired.
2) The timer must replace the 3-way switch that receives power from breaker box. It cannot replace the other 3-way switch. This is because the timer Black wire must always receive power.
3) The timer blue wire must connect to Load (light)
4) The ST01C red wire is only used when wiring for 3-way.
5) When the red wire and blue wire are connected together, they reverse the timer program. When timer red and blue are disconnected, the timer resumes programming. Connecting and disconnecting the red and blue wires is how the timer mimics 3-way operation.
6) The remaining 3-way switch must be wired so it will connect and disconnect the red and blue timer wires. So the remaining 3-way switch has to be rewired to meet specific timer wiring.
Jul 03, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have just brought ps3 and when i plug the leads into the tv ie red white and yellow leads i can not find the channel on my tv i have tried other tvs and same thing so i done away with the lead and just...
Hi, try not using the hdmi lead and plug the other lead back into the ps3 the normal av lead with the 3 color wires, now plug it into your telly now switch the ps3 on at the back so the red light is on at the front, now hold down the one button and it will bleep once then bleep twice and keep holding it down till it switches back off
so basically you switch it on at the back then press and hold down the on button until the ps3 turns itself back off, now what this does is reset the video mode so its not set to hdmi settings, now press the on button again and wait for it to come on if you still dont have picture on the telly make sure the video lead is fitted correctly and then get the telly remote and find one of the following buttons
av
source
input
or a rectangle with an arrow facing to the right.
once you have found this button make sure the ps3 is on and then press this button on the tv remote, you may need to press it more than once depending on how many inputs the telly has on it.
now when you press the button on the tv remote press it once then wait 5 sec before pressing it again just to give it chance to pick the signal up.
hopefully now you have the ps3 working through the normal av lead
let me know how you get on or if you need further assistance ok
please rate this solution as i have a whole page of unrated posts, thanks
Nov 28, 2010 | Sony Playstation 3 (PS3) Console
They Won't Charge!
Try to press the power boton in the same time you plug the charger, after this action mine is working and charging perfectly, maybe this is the "reset" solution... Hope this helps you.
Nov 17, 2009 | Motorola Mobility S9 Headphones
Philips 42pf9956/37
when the light goes red it should be blinking a two digit code and repeat itself continuosly. slow blinks are the first digit and fast blinks are the second digit
Sep 25, 2007 | Philips 42FD9954 42 in. Plasma HDTV
LG 42LG30 42 in. LCD HDTV Logo
Steve Allison
Steve Allison
