Question about Compaq Presario Notebook
Warranty id error code 10008 - Compaq Presario Notebook
  • 3940 Answers
SOURCE: a disk read error occurred press
The hard disk drive has failed and needs replacement. If this system is under warranty, contact HP
If not, then you can buy a replacement HDD from retailers like NewEgg.COM
I checked the HP spare parts page, their prices are quite high. Here is an example of a good value:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148073
Posted on Sep 01, 2008
the_fire
  • 432 Answers
SOURCE: Failed Replace hard disk 1 warranty id code
As the error message states you need to replace the hard drive as the hard drive is most likely dead ie not working / broken.
Posted on Apr 16, 2009
SOURCE: error message: Failed- Replace Hard Disk 1
I had the same result with the "Hard disk self-test, the test status is "#10008 Replace Hard disk" on a HP Pavilion Notebook six months old.
The drive may or not be dead. I purchased the Vantec SATA/IDE to USB 2.0 Adapter. I was able to power up the hard drive using another computer & get all the data that would not load on my Notebook. A real life saver as I had 1000's of family photos.
I hope this helps anyone hoping to recover data they thought was lost. Also without having to send to a data recovery site. They quoted me $1500 to $2000. The adapter cost me $23 from Newegg.
Regards,
Stephen
Posted on Jun 20, 2009
  • 44 Answers
SOURCE: asi gave mine laptop compaq c700 pc notebook to hp
Only Hp knows what that means in their diags. Get it shipped back and take it to a Locally owned PC shop and have them take a look at it. It is possible that you have just enough file fragmentation and file structure corruption that it is fail diags. Why did you take it in to be looked at anyways?
Posted on Sep 12, 2009
  • 3940 Answers
SOURCE: showing message 'failed replace hard-disk - 1
Pretty straight up, message indicates a failure of the hard drive and time to get a new hard drive.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822116026
Posted on Dec 11, 2009
Primary hardself test shows failed hard disk 1 (warranty id-error code 10008). it runs until it's 95% complete. however i have absolutely no problems with my computer/laptop. very confusing.
Your hard disk has a damaged area. Apparently this is close to the end of the storage area. Since there are no software in that area, you will have no problem. (Because the OS not trying to access any files in the damaged area).
Try not to fill the hard disk more than 80%. If files are written in the damaged area, you will experience problems with your laptop.
Sep 11, 2011 | HP Compaq Presario C700T
I got a error code 10008 what do i need to do
Your hard drive has a problem. Contact Compaq for replacement if it is still under warranty.
May 27, 2011 | Compaq Presario Notebook
My laptob gives me error code 10008 when i turn it on what could i do ?
Glad to HELP YOU!
Usually that error [code 10008] appears when the hard drive has a SERIOUS PROBLEM!...
If your laptop [by the way... it's LAPTOP and not "LAPTOB"...] is under the warranty conditions get your hard drive replaced. If not - then buy a new hard drive for your machine.
A good and reliable hard drive is under $100 these days.
Go on Google [or any other search engine ] and check for a HARD DRIVE DIAGNOSTIC UTILITY; I've found for you a few HERE.
Download it, install it and run a test. It might be not only the HDD with problems; it could be some other components of the motherboard that might generate a hard drive failure...
GOOD LUCK!
Apr 15, 2011 | Compaq Presario Notebook
Erroor code 10008
According to Compaq tech support. That error code of 10008 indicates the hard drive has failed and should be replaced. I would recommend contacting HP/Compaq and finding out your warranty status. If it is still covered under warranty, they can replace the drive with a new one. You will need to contact them to find that out.
Apr 13, 2011 | Compaq Presario Notebook
Laptop will not boot up warranty id error code 10008
Hello my friend.This is means that your hard disk is corrupted,has bad sectors.If you can boot at all to run the disk diagnostic program then your hard drive is dead and you must replace it.Is not difficult to replace it.Usually if you turn your computer you will see a small cover with screws,there is your disk and you can take it off and go to a shop and buy another one similar.Usually is 2.5inches and you choose the capacity you want.
Feb 08, 2010 | Compaq Presario Notebook
Asi gave mine laptop compaq c700 pc notebook to hp service centre for check up. they told me that there is a hard disk problem .so the problem was "HDD test fail & check with another HDD.& all...
Sep 11, 2009 | Compaq Presario 700 470024-192 Notebook
Failed Replace hard disk 1 warranty id code 10008
Apr 16, 2009 | Compaq Presario M2000 Notebook
Compaq Presario Notebook Logo
250 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
