Question about Insignia Digital-to-Analog Converter for Analog TVs
Magnavox converter box
I bought a analog converter box at walmart. the remote works, but the set up menue does not come on to program any channels
  • 1 more comment
  • pblackie29 Aug 16, 2008
    hooked up connections from my magnavox converter box to my TV. The green light comes on showing me theres power,but I can't get any channels to come on. Can you help me??? Joe email pblackie29@yahoo.com
    thanks
  • awilkinson Mar 02, 2009
    I hooked everything up following instructions and all I get on the screen is no signal.
    I hooked up my Magnavox TB110MW9 to my sanyo tv. All I get is no signal on my screen.
Call the number on the back of the remote, it is 1-800 annd they can trouble shoot for you.
Posted on Jul 09, 2008
I bought the magnavox and all my channels are
Check the converter box. Many have a volume setting that is usually set very low at the factory. On the remote control for the converter check to see if there are volume buttons. If so, change the converter box volume higher, to a level that makes the TV audio level "normal", then use the volume control on the TV for adjustment as you watch. If you set the volume on the converter box too high, you may get some distortion in the audio from your TV. So adjust the converter box to find the proper output from your TV without distortion.
Jun 20, 2009 | Insignia Digital-to-Analog Converter for...
Insignia tv, universal remote, and.....
Follows steps below to program your Insignia Converter Box:
1. Turn on your TV using your TV remote control and change its channel to 3 or 4.
2. Turn on the convert box; the blue light on the converter box is on. If you press the power button again, the red light on the converter box will be on, but do Not turn it to Red!!! Your insignia's other buttons will not response if it in red light mode!!!
3. Then press the Menu button on the Insignia remote control. A wizard will appear. The wizard does not appear if your TV is not in channel 3 or 4.
4. Follow the wizard instructions to scan channels.
Jun 13, 2009 | Insignia Digital-to-Analog Converter for...
Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Nov 21, 2008 | Zenith DBZN-311 Remote Control
Need to program a universal remote to work on Magnavox TB100MW9
Most of these are new and codes do not exist for them. You'll need a universal remote that has a learning feature so it will learn the code. Walmart has them for $16-$19.
Nov 11, 2008 | Philips Magnavox 27MS343S 27" TV
Insignia Digital to analog converter menu doesn't come up
When my Menu did not come up, I found it on the AUX channel (one below channel 3). I was able to go through the set up, but found only one digital channel available. Hope this helps!
Nov 10, 2008 | Televison & Video
Analog Pass-Through DTV Converter Box with Remote Control (3 digit code for the Remote Control
i can not get my tv to pick up a signal.I know my antena works i have tried it on other tvs.Has anyone else had this problem or know how to fix it?
Aug 04, 2008 | Philips Magnavox 20MT133S 20" TV
Universal remote code for digital converter
The code for a Magnavox Converter *Analog to Digital* to a Philips Universal Remote is 0759
Mar 21, 2008 | Televison & Video
Insignia Digital-to-Analog Converter for Analog TVs Logo
234 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
