Question about Steiner Safari 228 (10x26) Binocular
Right hand barrel hinge loose. Is there any way to tighten the hinge?
How to tighten loose display hinges on toshiba pro a10
There ares no adjustments to tighten the hinges, they need to be replaced.
Replacing a hinge, or both of them, isn't very tough. Check out this WEB site.
http://www.insidemylaptop.com/replace-br...
Jul 20, 2012 | Toshiba Satellite Computers & Internet
Tighten nb505-n500bl hinge
Laptop hinges cannot be tighten, there are no adjustments available.
The hinges need to be replaced.
Replacing a hinge, or both of them, isn't very tough this WEB site shows how it is done.
Feb 24, 2012 | Toshiba NB505N508BL 10.1" Intel Atom...
Loose hing on Gateway c140xl
Faulty hinges cannot be adjusted or tightened. If the the mounting screws are loose then these can be tightened.
These WEB site hace detailed instructions on replacing faulty hinges.
Hinges for Gateway laptops on the 'net,
http://www.laptoprepairco.com/Search/hinges/hinges.asp
http://www.insidemylaptop.com/replace-br...Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Feb 16, 2012 | Gateway Computers & Internet
Case loose round hinges
If the screws securing the hinges to the base of the laptop is loose then tighten these screws.
Hinges have no tightening adjustments and loose/faulty hinges need to be replaced.
These WEB sites can assist you to replace these hinges.
Feb 15, 2012 | Packard Bell Computers & Internet
The toilet set is loose and move around. How do you tighten it> Serial Number is 8321280870
lift flat tabes on back hinge reach under hold wing nut with hand and use a flat head screw driver to tighten down
Jun 06, 2011 | American Standard Toilet Ravenna 2646.016...
How to take the forend and barrel off a Winchester M37 410?
The old 37 has a screw about half way up the forend. Remove the screw and gently and carefully remove the forend by pulling the top down.Lay a towel or something similar down under the forend to catch any loose parts such as the forend shoe and the forend shoe retainer. Pay close attention as to how they fit together so as to make it easier to put your shotgun back together.
To remove the barrel, hold the barrel with one hand and push the barrel release on top the receiver with the other hand. This should let the barrel fall forward, allowing you to lift the rear of the barrel off of its hinge.
Good luck with your old classic shotgun and take good care of her.
Dec 26, 2010 | Rock & Ice Climbing
Our French doors aren't shutting right. You have to close the left one first, and then the right one. Even if you don't need to open the right one. It didn't used to do this.
It appears that your door hinges are loose. Open each door, take a close look at hinges at the top and bottom. You may be able to see an outline of where the hinge was and needs to be. Raise / Lower Door by hand until hinge is back in place, and tighten with a screwdriver. Pretty common.
Jun 11, 2010 | Samsung RFG237AABP (226 cu ft) Bottom...
Nikon compact binocular 25 years old. The hinge
Does this pair have two parallel tubes with a bridge in between?
If it does, then removing the caps at the eyepiece end of each hinge will reveal a grub screw. Tightening these will add tension to the hinge and give you the proper feel once more.
Feb 28, 2010 | Nikon Optics
One of the softclose buffers on the Subway toilet seat has pulled
Each soft close 'Barrel' is handed - one left - one right. (One is grey - the other white).
Most soft close errors occur because the seat hinges come loose. When this happen, the barrels slightly pull-out of the seat. (There are silver discs on the barrels - These should be tight against the seat).
Once the barrels become loose the first thing that happens is the top cover won't soft close - but the seat still does.
To rectify - puch both barrels tighly into fitting and tighten the hinges. (See below).
To tighen the seat hinges you need to get a flat headed screwdriver underneath the chrome round hinge cover - and 'flick off'. Underneath is a X head screw which id also hexagonal. You can either tighen both by spanner - or screw driver. (sometimes these can be tricky - but it will come off).
If both cover AND seat do not soft close AND the barrel silver discs are firmly located against the seat - the barrel has probably broken.
If so - spare parts can be obtained here:
http://bathroomstudio.co.uk/villeroy-boch-spares/cat_131.html
Jun 15, 2009 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
Teba Mini Kitchen (Oven & 2 x Hotplates). Left hand side hinge on oven door has come undone? Doesn't look broken, looks as if metal clasp inside has come off?
i can fix most anything. i have one of these and would love to get another. how is it today? email me at rnb3875@hotmail.com. thank you , robin
Jun 29, 2008 | Kitchen Ranges
Steiner Safari 228 (10x26) Binocular Logo
118 people viewed this question
Top Steiner Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Steiner Optic Expert? Answer questions, earn points and help others
