I cant turn on the wireless lan the switch is on but still is`nt working
Check all the connections..
it should be.. ethernet cable from internet source to pc.. then ethernet cable from pc to router..
Posted on Nov 07, 2010
Hi, i have a fujitsu siemens v6535 with windows 7 ultimate & my wirless switch doese'nt work, it may be broken, i tryed every way to turn it on from windows(fn+f1 & other ways) ???? how ca
Have you tried turning it on manually? Look on both sides and in front of the laptop for the switch.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
May 10, 2012 | Computers & Internet
Can connect to router via LAN but not wireless.
Try updating wireless driver software. OR wireless driver for ur router might not installed while on LAN conn install them with UBUNTU SOFTWARE CENTER. Still nt works? check ur hardware for problems by experts.> ??? Try updating OS. OR installing another great open source OS with great hardware support.Follow the following link...
www.opensuse.org/
Dec 09, 2011 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Wireless lan not working on my acer aspire 4520
The wireless feature (Wireless LAN) on an Acer notebook allows you to connect to available networks. This convenience allows you to use the Internet with network cables, modems or network installation. Acer laptops come with a wireless switch to turn the wireless feature on or off. Once you enable the wireless feature, your Acer notebook can connect to wireless networks within range.
Instructions:
1.Locate the Wireless LAN switch located on the front of your Acer Notebook. Move the switch to the right to turn on Wireless connections.
2.Right-click the network icon located on the system tray next to the clock. You should see a list of available wireless networks.
3.Select the network you want to connect to and click "Connect."
Sep 07, 2011 | Acer Aspire 4520-5582 Notebook
The lan port is not working and the wireless also.on my networks,the lan diagram is not there,not showing at all.when i try to connect through wireless it says turn on the wireless switch,when i on the...
It could be that windows networking has become corrupted. Sometimes referred to as the IP stack being corrupted. One fix is to try and replace corrupted files. You will need your windows CD for this operation. open the 'run' prompt by pressing the windows key while at the same time pressing 'R' or click start then run. In the run prompt type 'cmd' this will open a DOS type windows. in there type SFC/scannow. This will start the system file checker, insert your windows disk if it asks for it.
Feb 02, 2011 | Acer TravelMate 2480 PC Notebook
Can't switch on my wireless lan in my hcl me netbook .where is the wlan swith located .
Usually the wireless switch is located on the sides of the system, if you cant see it there. In front. and if you already turn on the wireless switch and you cant still connect. Look for the function keys. Usually it would be FN and F6. When you press those two keys at the same time. You should see a pop up window. Check if the current status is on. If it is on and you cant still connect. Uninstall and reinstall the wireless driver and try to connect again. If this didn't work, you can contact your computer manufacturer or do a clean installation.
Jun 27, 2010 | Advent Netbook
No wireless network in range. My wireless network is set to automatic but I am getting the message above when I search for wireless networks. I know there are at least three here.
If you are so sure of three wireless networks in range then it could be the HW problem in the laptop. Is the green light indicating WiFi lighting on? May be your WiFi switch is non functional. So switch on the WiFi and then look for LAN. Login and not searching a LAN are two different problems. If you cant search the wire less LAN then how can you log into any. So it has to be HW problem as you cant locate any although there are three available. So start at the WiFI switch.
Nov 02, 2009 | Dell Latitude D510 Notebook
Where is button to turn on wireless internet connection
see the operating instruction manual here :
http://dl.owneriq.net/d/d94ab07b-788b-41ca-8def-00135155738c.pdf
or read below :
For instructions on settings for wireless LAN and cautions during use, select [start]-
[Reference Manual], and refer to "Wireless LAN".
Before using a wireless LAN, turn the wireless LAN on using the following method (at
the time of purchase, the wireless LAN is set to [Off]).
Double-click on the taskbar.
2 Select your wireless LAN adaptor and select [General].
3 Select [On] for [Switch radio].
4 Select [OK].
The icon will turn to or ��
Oct 04, 2009 | Panasonic Toughbook T2 Notebook
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
