Question about LG MG64 VHS VCR
In my LG VCR whenever I load a tape in after about 10 seconds the blue video doctor screen comes up with a "please clean". This problem started at exactly the same time I noticed the audio won't switch from stereo to mono or vice versa in the "audio options" menu. Before this problem when a tape was inserted and played the audio would automatically switch to hi fi stereo after 10 seconds but now the video doctor screen comes up instead. I've already cleaned the video heads, please help!
  • peepin_tom Nov 07, 2010
    I wiped the video drum and video heads with tissue dipped in alcohol solution. Actually this problem started after I did this. Could I have damaged the hi fi stereo audio in some way? Is there any way to fix the problem?
  • 28 Answers
How did you clean the video heads?
Posted on Nov 07, 2010
We just purchased a RCA TV MODELRT1970 and a woman's voice comes on every time we adjust anything. Terribly annoying and we can't get rid of Her! How do we erase her?
@Judy McDougall
"RCA TV Woman nattering non-stop" :)
Hi Judy
This is 'possibly' your on screen "TV Doctor" voice.
My LG VCR also has this feature.
On the VCR her name is "Video Doctor".
Phrases like "This-is-the-main-menu...".
RCA maybe similar to LG so maybe try this:
Go to menu.
Look for something like settings or on-screen voice, or something 'Doctor'.
Hope it helps.
Clive.
Edit: Just saw a similar old question, answered thanks to @Tom Chichester Nov 1, 2016.
Tom's advice:
You have the second audio program (SAP) enabled. Return to the initial set up procedure to disable it.
Oct 15, 2017 | RCA Audio Players & Recorders
When recording in any speed other than LP, picture becomes very fuzzy and eventually blue screen will come up and say "heads may need cleaning". Cleaning never helps, but in LP mode rarely have a...
most of these units use two sets of video heads on the drum===one set for sp/slp and another for lp;
Get someone to open it up and carefully wipe the video heads----You Tube used to have video instructions for this, pretty simple stuff.
Cleaning tapes never work---if cleaning does not correct it---you have a bad video head.
SD TECH
May 13, 2011 | Panasonic PV-8451 VCR
My Magnavox MWR20V6 DVD VCR Combo shuts down, after 5-10 seconds, following start-up (on/standby button). I saw "E1(rear)," on the TV screen, just before it shut down the last time. I suspect...
Before anything, I would attempt to see what the E1 code signifies. But usually when those things just shut themselves down it is because of a serious problem in the power supply. I think it is time to go shopping.
Sep 16, 2017 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My VCR won't play my movies! The tapes are fine its just when I put the tape in it just shows a scraggly screen. Everything is plugged in but my movies won't play. What do I do?
If the vcr is running the tape, your video head is probably dirty, try using a cleaning tape if you have one. The second option is use a brand new blank tape T120 and set the the machine to sp speed (2hr running time) and let the tape run the full course. The third option is to remove the lid of the vcr and carefully clean the video head with a swab dipped in rubbing alcohol rotating the head by hand as you proceed allowing several minutes to dry before loading your tape.
Dec 21, 2010 | Sharp VC-H810U VHS VCR
Why will my VCR not work with my LG LCD TV,model 47LD520?IT comes on but will not play tape.
The tv LCD screen panel reconize the VCR and have the LCD screen panel,have a LCD have a blue screen wright,that incated u hook up the VCR wright.The VCR is not playing the tape,because is the VCR have problems,Not the tv itself.
Oct 26, 2010 | LG 47LD520 47 in. HD-Ready LCD TV
Lost manual, can't get VCR to play
There are several Philips and Magnavox DVD/VCR combos that have sepearate video connectors for the DVD and VCR side. Double-check the yellow composite cable that is plugged into the back of your Magnavox - it should be plugged into an area that says either "DVD/VCR" or "VCR". If you are currently using red, green, and blue video cables, you will need to add a second video cable - a yellow composite would be easiest. The reason for this change is that red/green/blue cables will only operate the DVD side on most Philips/Magnavox players - that is just the way they decided to design them. If you happen to find a model number listed on the back of your combo unit, and have the model number of your television, I can take a second look at it, and tell you exactly which connections to make. Good luck!
-Tha Mp3 Doctor
Feb 14, 2009 | Philips Magnavox DVD/VCR Dual Player
TV SCREEN IS JUST A BLUE PICTURE,BUT HAS SOUND
Hi and welcome to FixYa,
Offhand it would appear that the VCR section of the combo unit would require a bit of cleaning. Specifically, head cleaning. The easiest approach is to use a VHS tape head cleaner.
The other post of "tv turns on then 5 seconds later shuts off" would be the auto-protect kicking in. This indicates that a likely hardware fault exists. Try to initially reset the unit by unplugging from the mains for an extended period. Otherwise it would require opening the unit for voltage measurement/diagnosis.
Pls post back updates. Good luck and thank you for using FixYa.
Jan 25, 2009 | Philips Magnavox Learning Universal Remote
SAFE
Hold down the power button (or the vcr button if on a combination remote) for six seconds. This will unlock the child lock feature of the vcr.
Aug 12, 2007 | GE VG4060 VCR
Video image problem- Blue screen?
If your unit is fairly new,your VCR part might be the problem.Take it back!
If you have this unit for awhile,two things:
1. You need a professional A/V repair guy to clean up and check your VCR head.
2. The rental VHS tape is dirty.
Jul 28, 2007 | RCA DRC8335
Try to playback the tape and the screen is all blue
your heads motor ( drum ) cable may have have come loose or is dirty - since the cleaning tape made some difference the heads were dirty or almost worn out ( cleaner tape is abrasive ) so now there isn ' t enough signal ; if your date and time display worked only in play ? ( still works for camera record video ) your guides were out of alignment - and the cleaning tape took your guides even further out of alignment ( alignment here starts at $ 50 + shipping )
Jan 24, 2007 | Panasonic PV-GS2 Mini DV Digital Camcorder
LG MG64 VHS VCR Logo
136 people viewed this question
