Question about Hotpoint Washing Machines
The Hotpoint aquarius WF720 machine when switched on shows test in the panel, and will not allow change back to washing sequences.
SOURCE: How to remove top panel and front facia on a Hotpoint Aquarius WDF451 washing machine
This is for everyone out there who has a Hotpoint Aquarius WF210 and has trouble removing the top to replace the drive belt. Ignore all the tips you've had in the past as they are innacurate. It is actually quite easy to remove the top. Once you have removed the two rear screws you will be able to lift the lid up from the back, but only a couple of inches or so as it is attached to the front panel by clips. THERE IS NO NEED TO TRY REMOVING THE FRONT PANEL. The top panel actually comes off by moving it back towards the rear of the machine. However the clips are quite tight. All you have to do is go round to the front of the washing maching and give the top a firm tap backwards with the heel of your hand. Don't worry about hitting it firmly as you won't break it. It will come off the clips and hey presto, the top is free. It is as easy as that.
I spent a day and a half trying to get the top off our machine until a friend showed me how it was done. I felt a right tw*t as you will now I've told you the solution.
Replacing the belt is quite tricky. You will have to get someone to help you hold the drum forward as far as possible while you put the belt back in place on the wheel and spigot. You will see that the bottom spigot is notched to take the belt. However, it is much wider than the belt and finding the corrrect position is tricky. It's a case of trial and error, I'm afraid. Place the belt on the bottom spigot (roughly central) and then thread it onto the top wheel. If it is too far over one way and catches the plastic drum you will have to take it off, move it forward a notch and try again. You will probably not have to purchase another belt. Ours came off, didn't look at all worn, so I placed it back on and it has gone okay ever since.
Hope this helps.
Posted on Jul 14, 2008
localwonder
  • 6784 Answers
SOURCE: lights flashing / flickering on face on controls-machine not work
This is normally a signal that is for a control fault. you will need to pull the power and shut this unit down for 5 minute.. if the unit continues to flash after this reset, you will need to replace the control board/timer in this case. it has failed.
Posted on May 22, 2009
barkencoa
  • 3463 Answers
SOURCE: Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
Thanks.
Posted on May 27, 2009
SOURCE: How do I change the door boot seal on a Hotpoint Aquarius WMA31N?
Ok - I will answer my own problem seeing as though I have now fitted it!
1. remove door (2 screws)
2. There is a tensioned wire loop holding the front part of the boot seal in position. - prize off the plastic cap at the 11 o'clock position, all will become clear and you will be able to remove the wire loop.
3. Remove top of washing machine (2 allen screws behind caps at the front.
4. Remove soap dispenser draw and any screws holding the front control panel and top of the door.
5. Remove bottom front plinth (just pull it off) underneath are a couple of screws holding the front panel part of the machine, remove these.
6. Remove front of machine giving you access to the steel band which locks the other end of the boot seal in position. Slacken this band right back using a nut-spinner screwdriver. Pull off the old boot and clean the lip ready for fitting of the new boot.
7. Fit new boot seal using a squirt of washing up liquid as lubricant if needed (mine didn't) to reseat the seal.
8. Refit and tension steel band.
9. Re-assemble front panel, ease boot back into front lip position then refit wire loop using a suitable pair of pliers/molegrips to crimp the retaining plastic cap back in situ.
Posted on Nov 02, 2009
SOURCE: control panel lights ALL flashing on hotpoint aquarius washing ma
my lights are all flashing on my control panel, its takes water in then pumps out straighaway doesnt wash or spin i have changed the brushes so i know it isnt that please help it only about 3 years old
Posted on Feb 16, 2010
How to put in the circuit board on hotpoint aquarius wf440 ?
this may be of some help good luck
otpoint control module configuration for selfix - YouTube
? 9:21
https://www.youtube.com/watch?v=cHpz2OcbHAY
16 Sep 2011 - Uploaded by Selfix UK
Hotpoint control module configuration for selfix ... How to change the display pcb on an Ariston Washing ...
How To Replace A Washing Machine PCB - YouTube
? 4:19
https://www.youtube.com/watch?v=vskrPU9zU5M
27 Apr 2013 - Uploaded by Selfix UK
How To Replace A Washing Machine PCB ... Repair HotpointWF541 WF540 WF740 with flashing lights ...
Modules & Control Boards ' Washing Machines ' Spare Parts ' Hotpoint
parts.hotpoint.co.uk/.../washing-machines/...boards/.../C8-RIC-LVTRC-...
Have you lost complete control of your washing machine? ... If your PCB assembly (printed circuit board) is faulty then replace today for an efficient and effective ...
How to Replace Washing Machine Control Panels - Hotpoint ' eSpares
www.espares.co.uk > Home > Advice Centre
8 Jun 2010 - Replacing any of the front panel controls on a washing machine is ... how to replace any of the knobs, buttons, printed circuit boards that sit ...
How to Diagnose Washing Machine Control and Program Problems ...
14 Nov 2013 - Watch Josh explain how to diagnose washing machine control and program problems. ... If you then suspect that the problem still lies in the circuit board ... to test the board and you'll actually just need to replace it altogether.
Hotpoint WD420 fault ' Page 2 ' DIYnot Forums
www.diynot.com > Forums > How to... > Appliances
31 Oct 2009 - 15 posts - ‎11 authors
hotpoint aquarius wf530 washing machine flash like Christmas tree when ... After reading this forum I took the PCB board out and the C17 ...
Hotpoint WF540 washing machine board issue - pics included ...
www.electro-tech-online.com > ... > Repairing Electronics
19 Mar 2011 - 14 posts - ‎9 authors
Just took the board out of the washing machine to check the c17 cap ... was gonna cost £150 just for a replacement board without fitting.
Hotpoint - EMW Electronics
https://emwelec.co.uk/index.php?l=product_list&c=13
This is the Mark 6 board fitted to late Hotpoint washing machines. The module will be programmed to your model number - ready to fit. Typical models are WF550P WF560G .... Hotpoint Arcadia PCB Modules. SKU: 256. Hotpoint Arcadia PCB ...
modules and PCB's for washing machines and washers for Candy ...
www.unifit.co.uk/washing-machine-washer-spares-parts-replacement-mo...
Hotpoint SCR, WMA, WMS washing machine pcb control board ... 1200RPM 6 KG 2003 TO CURRENT LINEN), HOTPOINT - WMA58N (AQUARIUS 1400 RPM 6 ...
  1. Hotpoint Appliance Parts‎
    Adwww.hotpoint.co.uk/SpareParts‎rating for hotpoint.co.uk
    Save £5 When You Spend £35 or More! Low Cost and Next Day Delivery.
    Price Match Guarantee · Spend £35 & Save £5
  2. Hotpoint Spares - Delivered Within 24-48 Hours.‎
    Adwww.hotpoint-spares.co.uk/Shop/Spares‎Machine Spares
  3. Dishwasher Parts
  4. Cooker Spares
  5. Fridge Spares
  6. Hob Spares
  7. Replacement Circuit Board - Fried the hard drive circuit board?‎
    Adwww.onepcbsolution.com/‎hotpoint washing machine circuit board
    hotpoint washing machine control board
    washing machine pcb repairs
    hotpoint washing machine pcb problem
    washing machine circuit board replacement
    hotpoint pcb repair
    hotpoint aquarius washing machine circuit board
    circuit board for hotpoint aquarius
1 2 3 4 5 6 7 8 9 10 Next
Nov 22, 2016 | Hotpoint Washing Machines
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
I need a switchboard for a hotpoint aquarius WF000 6kg washing machine
By switch board, I assume you mean the control module.
If you go to Hotpoint's web site, you should be able to locate the part you require.
WWW.HOTPOINT .CO.UK
Then click on-- SPARE PARTS AND ACCESSORIES in the menu on the left.
Mar 16, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
My hotpoint qasher/dryer aquarinus super silent wd640 1400 spin just says test on displays and does not let me wash :(
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} According to the manual ‘TEST’ should only appear in the display when the hardware key is inserted into the rear socket of the machine ready to commence a test sequence. The only advice I can give is to turn the appliance off and remove the plug from the power socket for at least one minute then plug it back in and try it again. These machines have 3 phase motors and the heat sink on the module retains an electric charge for some time after the appliance has been switched off so be mindful if you decide to venture into the inside of the cabinet.
Jul 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Iv got the hotpoint wt960 and it keeps saying test and will not wash anything
Your machine has gone into service engineer 'test' mode as you have pushed a couple of buttons together by mistake. Go through this sequence .. Switch Off. Switch On (all LCD lights flash). Press Start/Cancel button (LCD panel now reads On). Together press the 3 ON/OFF STARTCANCEL and SPIN buttons like you would CTRL-ALT-DEL on a PC. The screen will show "DOFF". This means you are now out of test mode and back into normal operating mode. This happened to me and I was talked thru the sequence over the phone by the Hotpoint service assistant Emma - brilliant and free.
May 14, 2009 | Washing Machines
Hotpoint washing machine Aquarius WD640
Try this sequence; Hold down start and cancel button together, TEST should disappear of display,
Then hold down START/ CANCEL, and ON/OFF at the same time.
The message D/off should appear in the display, it should then work.
If it does not then the main pcb is likely to be faulty..
That will mean calling an engineer.
Pleas rate my fixya solution.
Thankyou.
Feb 07, 2009 | Hotpoint Aquarius WD63 Front Load...
Testing Shows On Display
press and hold start/cancel button for 5 secs. Thenpress on /offbutton and start/cancel together until Doff is displayed the machine should now be ok
Nov 26, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Showing test on front of hotpoint washer/dryer aquarius
hotpoint aquaris washer/dryer, press and hold cancle and start untill all lights come on,then press and hold on/off and cancle /start untill doff appears then the test mode has been reset
Nov 26, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD645
If you by accident press the start button and the cancel button at the same time it puts the washer into demo mode.To switch it off press both buttons at the same time and hold until dEND is displayed. Sometimes you have to keep trying but it will work, it did with mine ok.
Sep 09, 2006 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
75 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
